I need to make H-bridge diver for DC motor ?
Results 1 to 8 of 8
    Default I need to make H-bridge diver for DC motor ?
    I have an 110 VDC motor , and i need to build a h-bridge for this motor if anyone have schematics to build or and suggestion or help
    thanks
    May 2008
    Italy
    Using one MSK 4227 200 Volts 20 Amps hbridge already assembled with Individual Logic Level Gate Drive Inputs
    should solve your problem.
    See datasheet at this link
    http://www.mskennedy.com/client_imag...les/4227rc.pdf
    Al.
    thanks alot for your information, it's a powerful chip that give us our needs, but it's availabe and how I can buy it ?
    May 2008
    Italy
    Goto mskennedy site and contact them to check if they sell direct or if they have a distributor near your place.
    Al.
    thanks for replies,
    If one can help me to build this H-bridge using Mosfets and transistors ?
    I need your help
    This might help.
    see attachment.
    May 2008
    Italy
    I still think that you should use a ready made hbridge but if you want to try to build it yourself, you can use two IR2148 (low/high side driver) to activate the N-chan & P-chan power mosfet.
    Read the datasheet to learn how to build the hbridge. You can download it @:
    http://www.irf.com/product-info/data...ata/ir2184.pdf
    I suggest you to use fuses and start experimenting at low voltage and low current to learn how easily the hbridge can be shorted.
    Al.
    Quote Originally Posted by aratti View Post
    Al.
    iugmoh,
    I agree with Al 100%!
    The article I posted is only to shoe you how to build a bridge and some of the problems with doing so.
  1. Replies: 19
    Last Post: - 27th May 2010, 04:56
  2. Controlling stepper motor with PIC
    Last Post: - 1st July 2008, 11:21
  3. DC motor parameters estimation !
    By iugmoh in forum General
    Last Post: - 6th June 2008, 18:29
  4. Info about Snubbers
    By mikebar in forum Schematics
    Last Post: - 27th April 2007, 09:56
  5. information on how to make servo motor
    By rod27cn in forum mel PIC BASIC Pro
    Last Post: - 17th December 2006, 12:59
