Old and beyond help ?
Results 1 to 40 of 47
Threaded View
  1. #23
    Quote Originally Posted by DavidFMarks View Post
    Thanks for that.
    My original circuit had three octal darlingtons (ULN 2803) with inputs directly coupled to Ports A, C and D I have also connected leds with 680ohms to each pin so that I can see what the ports outputs are. A test program switched on and off each led in turn thru ports D C and A in that order and worked OK. Problem arose when tryin to switch on all of the A port bits and leave them on. I have now disconnected ther darlington from port a and written the following simple test program:
    @ DEVICE pic16f887,intrc_osc_noclkout
    PORTD = 0
    PORTA = 0
    PORTC = 0
    TRISD = 0
    TRISA = 0
    TRISC = 0
     portA.0 = 1
     porta.1 = 1
     porta.2 =1
     porta.3 = 1
     porta.4 = 1
     porta.5 = 1
     porta.6 = 1
     porta.7 = 1
    I have just run this program and
    1. When Microcode studio fired up the Pickit2 the voltage Vdd had been set down to 3.3
    2. I turned up Vdd to 5 volts and programmed the chip.
    LEDs 0,1,2,3 tuswitched on and then off after the delay. LED 4 switched on and stayed on, LED 5 switched on and then off again after the delay and then LEDs 6 and seven switched on and remainedon. I can see no logic inthis although I have that horrible feeling that it is staring me in the face !
    If this is all of the code, then You have to turn off all the analog stuff to get it to work, ADCON, ANSEL, and Comparators
