Moved from PM to MPASM and have fuse definition problems
Results 1 to 5 of 5
    Mar 2006
    Hyderabad (India)
    Quote Originally Posted by Tomexx View Post
    Before when working in PM I preset my fuses like this:
    @ DEVICE PIC16F628A, HS_OSC, WDT_OFF, LVP_OFF, PWRT_OFF, PROTECT_OFF, BOD_OFF
    Now in MPASM I'm getting "Overwriting previous address contents (2007)" error when doing this:
    @ __CONFIG _HS_OSC
    Any ideas?
    Tom
          list= p16F628A
          #include  <p16F628A>
          __CONFIG   03F2A  ;this would set to what you wanted
    in MPLAB click configure , select device and set it for 16F628A
    close and reopen the configure-- now seek "configuration bits" remove the tick on top of that page, now you can independently set every item of the list and there after, copy the configuration word. use it the way i typed incode above. this makes life easy before you get grip on mpasm.
    Sarma
    Oct 2008
    I'm not using MPLAB just MPASM under MicroCode studio.
    See this thread for your answer & then some..;o}
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Oct 2008
    Thanks Bruce!
