DT interrupts - High to Low
Results 1 to 3 of 3
    Sep 2006
    Venezuela - Caracas
    Default DT interrupts - High to Low
    the code works, but _B0 is started then PORTB.2 Low to High,
    i need High to Low
    i tryed
    DEFINE LVDINT = PORTB.2
    and
    DEFINE HLVDINT = PORTB.2
    but not work
    Button var PORTB.2
    INT_LIST  macro   ;IntSource,   Label,         Type, ResetFlag?
       INT_Handler    INT2_INT,     _B2,     Asm,  Yes
       INT_Handler    RX_INT,       _Rx,    Asm,  Yes
       Endm
       INT_CREATE
       INT_ENABLE INT2_INT
       INT_ENABLE RX_INT
    B2:
       IF Button    = 0 then
          hserout["0"]
          hserout["1"]
    Fim:
    @ INT_RETURN
    Rx:
       hserout["Rx"]
    Fim:
    @ INT_RETURN
    ..: Don't worry, be happy :..
    I'm not sure I understand what you mean, you mean you want the INT2 interrupt to trig on the falling edge of PortB.2?
    Anyway, one problem might be that you declare the ISRs as ASM but then you write them in BASIC. It will also be easier for people to help you if you tell us which PIC you're using.
    Sep 2006
    Venezuela - Caracas
    Default Solved
    many thanks.....
    i used
    INTCON2.4 = 0 ' PORTB.2 - Lo to Hi
    and works 100%
  1. SERIN MIDI out of Synch?
    By jncortes in forum mel PIC BASIC Pro
    Last Post: - 9th June 2009, 21:08
  2. Old and beyond help ?
    Last Post: - 11th December 2008, 16:23
  3. Pic16f84 and RC5 kode
    By terminator in forum Bluetooth
    Last Post: - 18th June 2007, 22:40
  5. sample code for M25P32
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 9th January 2007, 03:37
