DT instant interrupts with mister_e keypad
Results 1 to 6 of 6
    Oct 2008
    Oh no.
    I was hoping to use that in my gate opener and run it from a battery, that's why I need the pic to sleep for 99.9% of the time.
    In case you do find your version, please let me know. Till then I guess I'll have to forget about the battery and continually scan the keypad instead of interrupts...
    Is there any other way to do it with interrupts and have pic sleeping in the main loop? Maybe another keypad rutine or something?
    Thanks Darrel
    Tom
    Woohoo! Found it.
    http://www.picbasic.co.uk/forum/show...57&postcount=9
    The Rows and Columns may be different than yours. ?
    The "fix" was
    KeypadINT:
        @ READKEYPAD _ByteA                          ; Get the keypress
        TRISB=%11110000                              ; Reset I/O's
        PORTB=0                                      ; Set all columns LOW
    But now it sounds like that whole program is what you want. (With some sleep time added)
    Combination Gate Opener.
    Check the rest of the thread. It developed further.
    Oct 2008
    Works!!!
    Quick question, why are you enabling the interrupts after the ASM-ENDASM not inside?
            INT_Handler    RBC_INT,  _Scan,   PBP,  yes
    @   INT_ENABLE   RBC_INT     ; enable external (INT) interrupts
    Why not this?
    Also, why the funny indentation inside ASM-ENDASM? Remember, I'm new to interrupts and don't know assmebler
    Thank you Darrel,
    Tom
    Quote Originally Posted by Tomexx View Post
    Either way will work fine. But ...
    Different types of interrupts, like Timers or CCP Capture, need to have things set-up before the interrupt is enabled. I just put it that way to show that you don't have to enable it inside that same ASM block. It can be done later in the program too (if needed).
    The INT_LIST macro, or anything else that creates a label, must start in column 1.
    The rest is arbitrary and cannot start in column 1.
    It might look strange because I tried to line up the commas with the comment above the line just as a reminder of what the INT_Handler parameters are.
    Guess it didn't work so good.
  1. V 2.60 and DT Instant Interrupts?
    By jderson in forum mel PIC BASIC Pro
    Last Post: - 22nd July 2009, 07:48
  2. DT Instant Interrupts help
    By perides in forum mel PIC BASIC Pro
    Last Post: - 26th November 2008, 19:41
  3. 12F683 and DT Instant Interrupts
    Last Post: - 22nd November 2008, 13:47
  4. Keypad and DT's Instant Interrupts
    By Homerclese in forum General
    Last Post: - 27th April 2007, 07:32
  5. Replies: 1
    Last Post: - 1st November 2006, 04:11
