DT instant interrupts with mister_e keypad
Results 1 to 6 of 6
    Oct 2008
    Default DT instant interrupts with mister_e keypad [RESOLVED]
    DT instant interrupts with mister_e keypad (16F628A)
    I'm new to interrupts and tried DT instant interrupts by Darrel Taylor (thanks Darrel). The blinky works great with the INT_INT.
    I want for my program to sleep until woken up by the keypad then go to keypad rutine and flash led as many times as the number pressed.
    So I connected keypad's columns to PortB and tried to invoke RBC_INT. Spent few hours double checking everything. No luck.
    I had the RBC_INT working with a switch on PortB.6 before and that part worked. Sometimes it will work after I cycle the power but on the first press only (press 5, flashes 5 times), after that it won't till I shut power off again. Sometimes it won't flash the led at all. So when it works, the keypad works as well
    Schematic attached.
    CMCON  = 7                          ' Set portA to i/o
    DEFINE   OSC  20
    TRISA = %00000
    TRISB = %01110000
    INCLUDE "DT_INTS-14.bas"            ; Base Interrupt System
    INCLUDE "ReEnterPBP.bas"            ; Include if using PBP interrupts
    include "modedefs.bas"
    include "keypad.bas"
    ' SCAN_ONCE is set to 1 as well as proper keypad settings inside the keypad.bas
    LED_Grn     var  PortA.1
    ctr         var byte
            INT_Handler    RBC_INT,  _Scan,   PBP,  yes
    @   INT_ENABLE   RBC_INT     ; enable external (INT) interrupts
    @ sleep
    goto Main
    '---[INT - interrupt handler]---------------------------------------------------
    Scan:
      gosub KeypadScan
      for ctr = 1 to key
        high led_grn
        pause 200
        low led_grn
        pause 200
      next ctr
    @ INT_RETURN
    As always any help appreciated,
    Tom
    mister-e's keypad program wasn't written to use RBC interrupts.
    He doesn't leave the pins in the right state after scanning. Only 1 row is left active, and the rest won't trigger an interrupt.
    I think I overcame it awhile back, but I can't find the program at the moment.
    Essentialy, after doing a scan, it just sets all keypad outputs low (RB0-3).
    But it only left the one row active when a key was pressed.
    Wish I could find it.
    Oct 2008
    Oh no.
    I was hoping to use that in my gate opener and run it from a battery, that's why I need the pic to sleep for 99.9% of the time.
    In case you do find your version, please let me know. Till then I guess I'll have to forget about the battery and continually scan the keypad instead of interrupts...
    Is there any other way to do it with interrupts and have pic sleeping in the main loop? Maybe another keypad rutine or something?
    Thanks Darrel
    Tom
    Woohoo! Found it.
    http://www.picbasic.co.uk/forum/show...57&postcount=9
    The Rows and Columns may be different than yours. ?
    The "fix" was
    KeypadINT:
        @ READKEYPAD _ByteA                          ; Get the keypress
        TRISB=%11110000                              ; Reset I/O's
        PORTB=0                                      ; Set all columns LOW
    But now it sounds like that whole program is what you want. (With some sleep time added)
    Combination Gate Opener.
    Check the rest of the thread. It developed further.
    Oct 2008
    Works!!!
    Quick question, why are you enabling the interrupts after the ASM-ENDASM not inside?
    Why not this?
    Also, why the funny indentation inside ASM-ENDASM? Remember, I'm new to interrupts and don't know assmebler
    Thank you Darrel,
    Tom
    Quote Originally Posted by Tomexx View Post
    Either way will work fine. But ...
    Different types of interrupts, like Timers or CCP Capture, need to have things set-up before the interrupt is enabled. I just put it that way to show that you don't have to enable it inside that same ASM block. It can be done later in the program too (if needed).
    The INT_LIST macro, or anything else that creates a label, must start in column 1.
    The rest is arbitrary and cannot start in column 1.
    It might look strange because I tried to line up the commas with the comment above the line just as a reminder of what the INT_Handler parameters are.
    Guess it didn't work so good.
  1. V 2.60 and DT Instant Interrupts?
    By jderson in forum mel PIC BASIC Pro
    Last Post: - 22nd July 2009, 07:48
  2. DT Instant Interrupts help
    By perides in forum mel PIC BASIC Pro
    Last Post: - 26th November 2008, 19:41
  3. 12F683 and DT Instant Interrupts
    Last Post: - 22nd November 2008, 13:47
  4. Keypad and DT's Instant Interrupts
    By Homerclese in forum General
    Last Post: - 27th April 2007, 07:32
  5. Replies: 1
    Last Post: - 1st November 2006, 04:11
