Hall effect reading
Results 1 to 2 of 2
    Feb 2007
    Sao Paulo - Brazil
    Default Hall effect reading
    Hi everyone!
    IŽm in need to read a ratiometric hall effect sensor from Allegro (UNG3503), with a PIC12F675 and a minimum of components because of the space available.
    This sensor outputs half Vdd when no magnetic field is detected (i.e. 2,5V), and increase/decrease 1,3 mV/Gauss.
    Is there any "hint" to obtain readings as low as 1 Gauss only using sensor + pic, or IŽll have to use an amp.op also?
    Txs
    Wink
    Quote Originally Posted by ewandeur View Post
    Hi everyone!
    Txs
    YESS ... a 1.024 v ref. would give you only 1 unit per Gauss ...
    so, an amp is needed with a voltage translator to get the best of your ADC ...
    gain will depend on your measuring range ...
  1. Hall Effect flow meter with 16F876
    By revelator in forum mel PIC BASIC Pro
    Last Post: - 10th March 2010, 20:42
  2. Replacing Hall Effect throttle with PIC
    By idtat in forum General
    Last Post: - 22nd October 2009, 21:55
  3. hall effect
    By dragons_fire in forum mel PIC BASIC Pro
    Last Post: - 10th April 2007, 15:49
  4. Pot reading jumping like crazy!!!
    By champion in forum mel PIC BASIC Pro
    Last Post: - 20th November 2006, 21:24
  5. Reading a linear hall sensor
    By peu in forum mel PIC BASIC Pro
    Last Post: - 3rd October 2006, 22:31
