DT Instant Interrupts help
Results 1 to 8 of 8
    Hi. I would recommend for the sake of experimantation to increase the sampling of the count command to say 2000msec and see what happens.
    The timer1 interrupts the count every 105 msec and is obvious that there is interference since the Count also samples at 100 msec. Remember that the Interrupts are not Instant with the exact meaning. There is an overhead to save and restore the variables and program counter.
    Also at your program:
    :main
    make it as
    and
        while 1=1
         COUNT rpmIn, 100, rpm
         LCDOUT $FE,1, "PULS/S ", DEC(RPM)
         LCDOUT $FE, $C0, "RPM ", DEC(rpm)*60
        wend
    make it as:
    rpm var word
    LCDOUT $FE,1, "PULS/S ", $FE,$C0,"RPM:"
        while 1=1
         COUNT rpmIn, 2000, rpm:rpm=rpm*60
         LCDOUT $FE, $80,dec,"  ", rpm,$FE,$C5, DEC rpm,"   "
        wend
    this is much faster.
    Wink KISS Method.
    W/ no interrupts using ...
        while 1
         TOGGLE LED1
         LCDOUT $FE,2, "PULS/S ", DEC(RPM ), "            "
         LCDOUT $FE, $C0, "RPM ", DEC(rpm)*60 , "                 "
        wend
    so simple as that ... ( LCDOUT spaces avoid resetting the LCD ... which is toooooooo long ! )
    ... BTW : How many pulses per rev. ???
    Jul 2007
    Hi...
    Working fine now. Thanks for the directions.
    I know I donīt need interrupts to just blink a led (and donīt need for most of things). Just to see how it works.
    In future I expect this code will read some sensors (pressure, air temp, rpm and a pot), do some calculation and provide near exact extra fuel needed for an aftermarkt turbo charged engine runing at high revs. At this time I think that Iīll need interrups, since in this case, time is critical
    Donīt know yet... need to check. Using 1 at this time.
    Jul 2007
    Canīt figure by myself .
    Can someone explain me tachometer maths??
    Engine will run up to 5500 revs. 1 pulse for revolution.
  1. DT Instant Interrupts
    By krohtech in forum mel PIC BASIC Pro
    Last Post: - 25th February 2009, 16:33
  2. DT instant interrupts with mister_e keypad
    Last Post: - 26th November 2008, 21:02
  3. 12F683 and DT Instant Interrupts
    By jderson in forum mel PIC BASIC Pro
    Last Post: - 22nd November 2008, 13:47
  4. 18F1220 and DT Instant Interrupts
    Last Post: - 30th June 2008, 06:37
  5. Replies: 1
    Last Post: - 1st November 2006, 04:11
