Line Tracer robotics
Results 1 to 5 of 5
    Dec 2008
    philippines
    Post Line Tracer robotics
    hi, can i ask for a codes of line tracer
    or a prototype car line tracer
    if you have a assembly or C program codes for that project
    i want to study how to make the codes
    thank you, , , please help me
    http://www.parallax.com/tabid/535/Default.aspx
    Has a lot of good information. There are several examples of using IR sensors.
    The code in the examples is in parallax's verson of basic.
    Quote Originally Posted by emildownloads View Post
    Must've missed the title of this section of the forums AND the domain name too...
    Not much assembly done here (although a few do quite a bit) and even less C spoken here.
    Besides, without knowing the hardware, how can you write good software?
    Ankara,TURKEY
    hi guys everybody knows that pic basic is the easiest programing language for pic, if you are newbie you should use pic basic pro.
    Then if you want you can learn others.
    And for your project;
    you can use CNY70 contrast sensors instead of constructing IR&phototransistor circuits
    To drive motors you can use L293D motor driver.
    And pic16f84 or 16f628a
    If you are still want to do it reply this post I can help you even I can write you a simple code.
    Electrical & Electronic Engineering
    Undergraduate Student
    Ankara,TURKEY
    instead of discussing about why he use c lang., we can give pbp codes.
    Don't be so aggressive.
    Hasan
  1. Using input from Switch to control a loop
    Last Post: - 2nd February 2009, 05:02
  2. Loop with two motor and 2 sensors
  3. Need Help - Line Tracer Robot
    By pidot in forum mel PIC BASIC Pro
    Last Post: - 10th August 2007, 14:58
  4. having problems with Hantronix 20x4 lcd
    By Rhatidbwoy in forum mel PIC BASIC Pro
    Last Post: - 22nd December 2005, 12:22
  5. Line tracer robot
    Last Post: - 30th January 2005, 15:36
