LCD 4X40 Futurlec
Results 1 to 23 of 23
    Nov 2007
    South-West of Australia. A small town called Denmark. 'Where the forest meets the sea.'
    Default 4x40 futurlec display
    1. Joe S. I have not been able to get my 4X40 LCD to work - so I'm hardly the fellow to give you advice. However, I think you are right and the 4X40 is built like two 2X40 displays that have separate ENABLE pins and the rest are common. I presume one simply swaps from ENABLE1 to ENABLE2 according to what needs to be displayed.
    2. The new pin-out from Futurlec is NOT the correct one (Futurlec sheet is for a device 4004 and mine is a JHD404A1 with a different number of pins.) Adjusting/guessing the connections has yielded only fleeting black blobs - and yes, I do know that black boxes may be caused by too high contrast setting.
    3. I'm a bit irritated that Futurlec is selling a $40 odd LCD device and can't publish the correct spec sheet - and it's not to be found on the internet. There are quite a few different pin-outs for other 4X40 LCDs but none seem to work on the JHD404A1.
    4. Anyone go it to work? Futurlec must have sold a fair number of thes LCDs
    Regards Bill Legge
    Mar 2005
    Iowa, USA
    Bill - If it does happen to have 2 controllers, here is an excellent way to control it.
    http://www.picbasic.co.uk/forum/showthread.php?t=626
    Hope it helps.
    Wisdom is knowing what path to take next... Integrity is taking it.
    Ryan Miller
    Nov 2007
    Default 4X40 Display
    Rhino,
    Thanks for the info. I have got a different 4X40 (DisplayTech LTd closing down sale for $5, how's that for a bargain) and - IT ALL WORKS OK - along with the code/circuits for driving two ENABLE pins.
    I would still like to track down the pin-out for the Futurlec JHD404A1 if anyone out there has the info.
    Regards Bill Legge
    Omaha, Nebraska USA
    Thumbs up
    I use a lot of Crystalfontz displays with good (great!) success.
    http://www.crystalfontz.com/
    Russ
    N0EVC, xWB6ONT, xWN6ONT
    "Easy to use" is easy to say.
    Default Futurlec LCD working now
    Hello,
    I managed to get the Futurlec 4 x 40 LCD working. In my case, I did this with a BASIC Stamp. I hope I'm not escorted to the door from this forum. I found this forum to find a solution for communicating with an LCD. See attached photo.
    Bill's initial thread actually had the correct pin assignments that were the key to getting me started, although the Futurlec LCD has no pins 17 & 18. Internet research had consistent documentation on 4 x 40 LCD with two rows of pins having different assignments than those posted on Futurlec's site. Those are clearly WRONG! Also, A and K connections are for the back light and are straightforward.
    The second challenge was understanding how to address the 3rd and 4th lines on the display. My experience with LCD displays was limited to 2 x 16 and 4 x 20 serial units that have an entirely different way to address the screen coordinates. The 3rd and 4th lines are addressed with the second enable pin. This forum clued me in on that .. thank you. So I had to initialize both controllers in the LCD and communicate with the device as basically a stack of two 2 x 40 LCDs in one unit. The LCDCMD command in PBASIC allows me to address a set of pins in 4 bit mode while allowing some flexibility on which pin is the enable pin. This permitted me to address both sets of lines by adding the one additional connection to the LCD for the extra enable connection.
    I am not versed on PIC language, but I'm sure it's doable if I've done it with the BASIC Stamp.... code attached.
    Rick
    Nov 2007
    Rixter,
    Thanks for your message and I'm pleased to learn that the pin-outs in the first post are correct. I must have made some wiring error because they would not work for me? I will have another go.
    I have, since then, got some different 4X40 LCDs, with correct tech details, and they work well using the method posted by RHINO - a couple of resistors on the two ENABLE pins and a bit of code.
    One mistake that took me a long time to find was using the PBP command "CLEAR" after the definition on the LCD1-Enable and LCD2-Enable pins - the CLEAR command clears the definition:
    This won't work:
    LCD1-Enable VAR PORTD.1
    LCD2-Enable VAR PORTD.2
    CLEAR
    This will work:
    CLEAR
    Good luck - get off the Basic Stamps and into PICs soonest!
    Regards Bill Legge
    Default 4 x 40 LCD
    Thanks for the response Bill. Out of curiosity, what other 4 x 40 LCDs are you working with? When I ordered the Futurlec LCD I got a bit of tunnel vision and didn't pay attention to the true dimensions. Some how I didn't expect the unit to basically be twice the size of a 4 x 20, even though that would seem logical. I would rather trade for a bit smaller character size and be a smaller package overall for my implementation, which is a bicycle electronic route sheet device. Are any of the 4 x 40 LCD you've seen in smaller physical packages?
    As far as moving off of the BASIC Stamp, it would only be to take on another challenge or to address a particular issue not attainable with the Stamp rather than putting it down. As limited as they can be, they are easy to use for most of what I have asked of them. Like eating ice cream with handcuffs on, they are enjoyable to work with despite some discomfort and limitations. I am a programmer first, a fabricator second and an electronics expert last. I've learned much in the past two years on the electronics part. Despite learning many programming languages over the years, I come from an extensive background in BASIC and keep coming back to it. Does anyone remember Micro 80 magazine and the contests to solve a challenge in the fewest lines of code? Generally, one line programs won the contest. While I don't use it anymore, the "Trash 80" is still here and the spirit and fun of simple BASIC lives on. If I ever got into production level of my projects, I would definitely develop using a different platform, but that is not the case at present.
    Rick
  1. 16f688 LCD what have I done wrong
    Last Post: - 8th August 2009, 20:54
  2. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  3. Need help with LCD number display.
  4. LCD will not start
  5. 4x40 LCD control problem
    By NL2TTL in forum mel PIC BASIC Pro
    Last Post: - 5th January 2005, 12:43
