Thanks for the reply guys. This is a link to where I got the wiring for the 2.5mm jack - http://pinouts.ru/CellularPhones-Nok...t_pinout.shtml
I'm using a stereo plug and I'm using the base and middle landings which I think is correct. The output I'm using from the opamp should be a large enough signal for the Nokia.
I guess I'll just need to experiment some more to find the right connections.
Tony
