Picstart plus and pic18f2331
Results 1 to 7 of 7
    Nov 2008
    Henrik,
    I have connected a 1k resistor between pin 7 and pin 11.Also, connected pin 7 to pin 20 (AVDD AND VDD pins) and pin 8 to pin 19 (AVSS and VSS pins).Then when I do a blank check I get:
    Device is NOT blank:
    Program Memory
    Configuration Bits
    IDs
    Data Memory
    Then when I do a read I get:
    Device is data protected! Data memory may be invalid.
    Device is code protected! Program memory may be invalid.
    I looked at the thread you asked me to take a look at and they show how to do ICSP.I have done that but still I have not solved the problem.
    Did you use MPLAB IDE version 8.10 and picstart firmware version 04.50.09?
    It seems that for some reason I cannot erase my pic18f2331???????
    Please let me know.
    This is from when I asked MicrChip about a similar problem .
    Customer Update 3/10/2007 8:01
    I think I fixed the problem. Placed the 18F4320 in a breadbord and jumped from MCLR, RB6, RB7, and VSS. Powered the chip with an external power supply with a 4.7uf across VDD and VSS.
    Working 100% of the time now.
    Customer Update 3/9/2007 13:37
    9 out 14 chips are programming approx 75% of the time with a 4.7uf. It is getting better.
    Thank you for your help.
    Support Response 3/9/2007 12:03
    To program the 18f4320 on the PS+ may require the placement of a 0.1uF bypass capacitor from the VDD pin to the VSS pin of the device to successfully program the device. If programming failures still arise, try increasing this value incrementally to a maximum of 10uF. A low ESR capacitor such as a tantalum is recommended.
    It's been a year or two since I actually used the PICStart+ (other hobbies to has gotten my attention lately) so I don't remember what firmware it has or what version of MPLAB I used. But I know that I wrote about the whole thing in the previously linked thread, everything I had to do is in there. If it still doesn't work for you I don't think I can help, sorry.
