LCD SEROUT2 help
Results 1 to 12 of 12
    The easy way would be
    tag1	Var	LONG
    If you are using PBP 2.50
    Otherwise I would say you need to store it an array.
    Nov 2008
    Fort Collins, Colorado
    This is what I tried:
    buf		VAR BYTE(10)	'Tag code stored as word
    SERIN2 rx,396,[STR buf\10]
    SEROUT2 lcd,396,[$FE,$C0,STR buf\10]
    The LCD then displays a three digit display but it's symbols and not anything readable.
    I am feeling lazy, so I will point you here.
    http://www.picbasic.co.uk/forum/showthread.php?t=544
    Oct 2010
    Default Re: LCD SEROUT2 help
    Hello all,
    since i didnt find anywhere in the forum the solutions or a thread for the following question, i would like to request your advice.
    I'm currently building an RFID reader tag with PIC16F628a and LCD 2x16.
    i'm trying to display the tag number on the LCD screen.
    My problem is that i want to use SERIN2 for getting the tag number and the SEROUT2 for displaying it to the LCD.
    Since i only know how to use 2x16LCD command as follows:
    DEFINE LCD_DREG PORTB 'define port to LCD
    DEFINE LCD_DBIT 4 'RB4 RB5 RB6 RB7 to D4 D5 D6 D7 display
    DEFINE LCD_RSREG PORTA 'RS on porta
    DEFINE LCD_RSBIT 0 'RS on porta.0
    DEFINE LCD_EREG PORTA 'Enable on porta
    DEFINE LCD_EBIT 1 'Numero Enable porta.1
    DEFINE LCD_BITS 4 '
    DEFINE LCD_LINES 2 'lines 2
    So i have connected the pic16f628 according to the above configuration for the LCD 2x16.
    I have also connected the RX pin in order to read the data from the RFID output data.
    SERIN2 portb.1, 84, [WAIT($02), Str buf\10]
    The problem is that the TX from the pic16f628a is not connected anywhere.
    How do i display the tag number with serout2 command to an LCD 2x16?
    or lets start from the very basic staff.
    first of all to display something on the LCD using the serout2 command.
    I dont understand how to use the portb.2 which is the TX port for the pic16f628a to the LCD.
    thanks for any help.
    the following is my code.
    @ device pic16f628a
    include "modedefs.bas"
    CMCON = 7
    define osc 8
    DEFINE LCD_BITS 4      '
    PAUSE 200              ' Stop 200ms
    LCDOUT $FE,1           ' power lcd
    Lcdout $FE,1,4
    lcdout $FE, 1,"  Copyright 2011"
    lcdout $FE, $C0,"Leonardo Bilalis"
    pause 2000
    lcdout $FE,1
    ' -----[ Variables ]-------------------------------------------------------
    buf	    VAR	byte [10]' RFID bytes buffer
    tagNum	VAR	Byte	 ' from EEPROM table
    idx	    VAR	Byte	 ' tag byte index
    char	VAR	Byte	 ' character from table
    lcdout $FE,1," Please use your"
    lcdout $FE, $C0,"    TAG"
    high portb.3
    serout2 portb.2,84 [STR buf] 'this pin is nowhere connected :(
    pause 1000       'Pause ,1 sec
    You don't..... you use LCDOUT. If you had a serial LCD (or back-pack) then you'd use SEROUT but since you have the LCD wired to your PIC in parallel 4-bit mode mode you use LCDOUT just like you're already doing in the code. And the STR modifier works with LCDOUT as well
    LCDOUT $FE,$C0, "Tag: ", STR buf
    Oct 2010
    DEar Mr. Henrik,
    i will try and let you know in a bit.
    P.S.
    i DID IT!!!!!!!!!!!!!
    thanks a lot!!!!!!! thanks thanks. i didnt know that is so easy.
    Now i have a tag nubmer dipslayed in LCD 2x16.
    thank you very much for your help.
    Oct 2010
    hi all again,
    this is the video from the code above.
    thanks Henrik for helping me to complete my code.
  1. Serout and 18F87J50
    By Glenn_Webber in forum Serial
    Last Post: - 20th November 2009, 14:26
  2. SLOW Serin2 and Serout2
    By dragons_fire in forum General
    Last Post: - 26th June 2009, 02:38
  3. Play with LCD on PICDEM
  5. Gps with 16f628
    By dragons_fire in forum mel PIC BASIC Pro
    Last Post: - 8th June 2006, 03:38
