There is a whole bunch of info on capacitive sensing here:
http://www.microchip.com/stellent/id...GE&nodeId=2695
Hello
Capacitive sensing is another story, for that exists ic's from Quantum that work very well. Inductive sensing is more complex, then you must prepair
the painel mechanical with a few layers.
Pedro
M'chip has a pro/con chart:
http://www.microchip.com/stellent/id...param=en535162
Hello rmteo
Not advantage, but you can't use a capacitve keyboard for blind people, in that case the capacitive sensing is not usable
Pedro
I am using a TS555 (CMOS version of the LM555) as a free-running oscillator at 1.1MHz. The touch buttons are routed through two 74HC4067 16-to-1 multiplexers to the TS555 as its timing capacitor (currently using only 24 inputs with 8 spare). The output of the TS55 is connected to TMR1 of the PIC which selects the inputs of the multiplexers and is also used to interface with 128x64 GLCD.
