Stepper motor controller
Results 1 to 23 of 23
    Thumbs up
    Hi, guys....well let me describe better what the needs are, i have 2 PWM servo outputs, each one is driving each servo from left to right,..., with a 5V TTL logic level, movement from left to right is changing the pulse width from 1ms to 2ms, with 1.5ms at center position,....the movement is like 0....to...60 degrees minimum angle, or a maximum 90 degress !
    May 2008
    Italy
    DarthV, I have read your introduction to the problem. but you didn't write what your problem is.
    Al.
    Hi again, my problem is that i would like to use it but needs modifications and we only have de Hex code, so if you could do it for me that would nice, of course with the necessary cash amount for your work, if you wish so !
    thanks
    May 2008
    Italy
    Attached the PBP files in txt format. If you need to add more code then you have to change pic.
    Suggesting pic 16f628 which has the same pinout but 4K of memory. In this case you have to add these two instructions at very top of the code.
    CMCON   = 7
    VRCON   = 0
    This version is the latest so if you have in use the previous one replace it, with this one.
    More torque, better homing and high precision also with 1 single step travel command.
    Enjoy.
    Al.
    Thanks aratti !
    G.V
    Hi Al,
    1. Thanks for the nice code example / project, I will try it out !
    2. Question: It appears you have set this up as a control for a home brew CNC project, just judging from the use of limit switch inputs, is that correct, and any issues using it for that?
    Thank You
    JS
    May 2008
    Italy
    Hi Joe, the original idea was to have a handy and simple device to solve linear positioning requirement, and when you do positioning, you also need a zero point to start and limits security.
    But since you can serialy network the controllers, you can also control two or three axis and have a small open loop cnc system. The only limitation is that you will have only point to point positioning or linear interpolation but not the circular. But for simple drilling tasks, for instance, this will be ok.
    Nice to hear from you.
    Al.
  1. 18f4431; driving a stepper IN HARDWARE mode
    By DDDvvv in forum mel PIC BASIC Pro
    Last Post: - 21st January 2010, 17:49
  2. Replies: 11
    Last Post: - 6th November 2008, 11:27
  3. Controlling stepper motor with PIC
    Last Post: - 1st July 2008, 11:21
  4. Driving Stepper Motor with PBL3717
    By crhomberg in forum mel PIC BASIC Pro
    Last Post: - 8th November 2007, 21:59
  5. problem with stepper!!
    By ibra in forum mel PIC BASIC Pro
    Last Post: - 7th August 2007, 17:41
