Need some suggestion ignition coil pulse detection
Results 1 to 9 of 9
    May 2007
    Republic Serbia
    Wink Need some suggestion ignition coil pulse detection
    Did any idea how to make ignition coil pulse detection with next :
    1. Input via CD 40106 like filter
    2. Output with LM 324.
    3. All to work at 12V.
    Function:
    When pulse come to input of CD 40106 in output of LM 324 to we have +12V.
    If pulse stop output must drop to 0V
    I was look some similar from China but it was hard to make schematic becouse
    PCB is to small and two layer SMD.
    It is basic for automatic switch from gasoline to LPG in car....
    Final end output is relay 12V 10A DC.
    I do not want full project from someone but only idea....
    Regards.
    How it is connected to the ignition coil? On the HV side (with any kind of sensor) or the LV (Tach) side?
    If on the LV side, it's plain easy, even a PIC10F would do. Just need to detect a frequency and that's it. 4Cyl tach signal at idle is around 30Hz.
    You could check on google for a Frequency To Voltage application, you find it, you're half done, add a comparator at the output of it and you have something that should work.
    May 2007
    Republic Serbia
    Red face
    LV side of coil - where is coil switched to gnd to make HV at out.
    Triger coil side 12V to 0V signals ....
    Mar 2009
    Florida USA
    Smile Interface Ignition Coil to PIC etc
    Here is what you need to do:
    From the low end of the ignition coil to the anode side of a diode 1N4002, then to Resistor 8.2K then to Resistor 3.9K, then to Basis of a NPN Transistor. A capacitor of 68nF between 8.2K and 3.9K Resistor to ground. A Resistor of 3.9k from Collector to +5Volt, Emitter to Ground. Signal from the Collector to your Circuit.
    Coil----Diode-----Resistor 8.2K------Resistor 3.9k-------| Base Transistor
                                     Cap 68nF          Resistor
                                      |                 3.9k
                                     Gnd                Gnd
    Hope this helps.
    Last edited by Darrel Taylor; - 28th April 2009 at 02:59. Reason: Added [code] tags
    Mar 2009
    Florida USA
    Default Follow up on Interface...
    My little drawing didn't work too well but you should get the idea...
    vBulletin has some tags that can help with that.
    The ASCII diagrams work best inside of a code block.
    <b>[code]</b>diagram goes here<b>[/code]</b>
    hth,
    May 2007
    Republic Serbia
    Thumbs up
    Quote Originally Posted by misterg View Post
                                     Cap 68nF          Resistor
                                      |                 3.9k
                                     Gnd                Gnd
    Hope this helps.
    Thank's I will probe and post what was as result.
    Wink Kiss method
    You also can use a small relay ( 1 Amp. Omron G5V i.e. ) , placed along the Ignition Coil;
    just scope what is going out of the coil pins of the relay ...
    oh, surprise ! ... and moreover ... no HV spikes !!!
    Mar 2009
    Florida USA
    Default code box
    Hi Darrel,
    thanks for the tip with the code box, appreciate it.
    Gunther
  1. Pulse Capture and byte building
    Last Post: - 21st July 2009, 02:59
  2. Single digit 7 Seg LED clock - PIC16F88
    By thirsty in forum Code Examples
    Last Post: - 17th July 2009, 09:42
  3. Replies: 3
    Last Post: - 13th September 2008, 18:40
