Help setting up MPASM with MicroCode studio
Results 1 to 9 of 9
    Oct 2008
    1. Installed MPLAB 8.1
    2. In MCS, under View - Compile and Program Options - Click the Assembler tab.
    3. There is a check box there -- Use MPASM ---
    4. Click find Automatically. FOUND.
    Is that it, how do I use it?
    Quote Originally Posted by Tomexx View Post
    As long as the box is checked to use MPASM, when you compile a program ( F9 on the key board), MCS will use MPASAM to assemble the code, you do not have to do anything else.
    Oct 2008
    IT is, that's it then.
    So PBP is the compiler and MPASM the assembler right? Not sure what is the difference. I thought the compiler translated source into .hex file. What does the assembler do then?
    PIC Basic compiles the code into assembly language. The assembler generates the hex.
    Refer to the PBP manual section 8, for more info.
    Oct 2008
    Yeah, just read section 8,
    Thanks mackrackit
  1. PICKit2 - warning about configuration words
    Last Post: - 4th August 2009, 15:01
  2. Microcode studio loader problem
    By woodygjw in forum General
    Last Post: - 10th September 2007, 02:18
  3. Setting Fuses using Microcode Studio Plus
    By NO2K in forum mel PIC BASIC Pro
    Last Post: - 19th May 2007, 00:14
  4. MicroCode Studio Plus won't use mpasmwin
    By sjohansson in forum USB
    Last Post: - 4th January 2007, 23:10
  5. Microcode studio can't find MPASM
    By DynamoBen in forum General
    Last Post: - 26th September 2006, 01:47
