16f690 crashes
Results 1 to 9 of 9
Thread: 16f690 crashes
    Nov 2008
    Default noise reduction
    huh.. I tried that electrolytic 10 mf cap. works fine across unused line from the pic. but I started wondering what it might do to the waveform of the incoming pc. I put it accross the pic out, and it went from high/low pulsing to low pulsing. anotherwords the cap is too high. I recon I'm going to have to pull out the old cap box I salvaged some years back and try some various values. I recon its about time to re-stock on the salvaged caps, the goo inside is prolly starting to dry up on the old ones. man.. I sure hope I don't have to find a scope to do this with, that would be a pain in the rear.
    gotta hammer away some more and try to find some solutions. I think I am going to replace the wires with twisted pair cat 5 and see what that does.
    Wink
    Hi, Lincoln
    Why do you think ICs creators spend their efforts in creating LINE DRIVERS with as little as possible output impedance ???
    Good question ... don't you think ?
  1. HSERIN / SERIN Problem with 16f690
    By rborsuk in forum Serial
    Last Post: - 5th February 2010, 05:51
  2. Programmer for 16F690?
    By mrx23 in forum mel PIC BASIC Pro
    Last Post: - 2nd August 2007, 16:12
  3. Using HPWM in half bridge mode on 16f690
    By Chris Barron in forum mel PIC BASIC
    Last Post: - 29th December 2006, 12:18
  4. tmr1 on 16f690
    By dan gill in forum mel PIC BASIC Pro
    Last Post: - 25th November 2006, 22:58
  5. 16F690 Support
    By Ruben Pena in forum mel PIC BASIC Pro
    Last Post: - 5th September 2005, 23:35
