16f690 crashes
Results 1 to 9 of 9
Thread: 16f690 crashes
    You are trying to do a timing-critical function (Serial Comms) on a PICs crappy internal oscillator, and you're wondering why it's not working?
    But that (and other horrible things) aside... you should have a GOTO POLL, not a GOSUB POLL. You're filling up your stack and promptly dissapearing destined never to RETURN...
    Also... when you have a problem and you jump to NXT (I haven't checked the syntax of your SERIN command btw), it performs a GOTO and NOT a GOSUB... therefore it's NOT a subroutine so the RETURN statement is not valid.
    Nov 2008
    Default cleanup
    ok.. I'll go ahead and clean that up and post it again..
    Nov 2008
    heres the new cleaned up version of the old code. I haven't hooked it up to the pc but this one seems to work just great (it pulses the pin selected for output). I did that stuff you were talking about with the goto command. thanks for the help.
    as for the xtal, yeah, I'm going to have to condede to that. I was hoping to see if I could just get by without one, but I'm going to probably have to give those pins back to the xtal. I was kinda getting away without needing an xtal due to the fact that nothing else was hooked to it whilst I was testing this code.
    I've also been looking for a tutorial on setting all pins on the device to digital. it seems the settings I have do that, but I really don't have a clear understanding off the following ansel, anselh and adcon. I looked in the microchip pdf but it was rather confusing.
    thanks for the help with the code.
    INCLUDE "modedefs.bas"
    define osc 4
    @ device PIC16f690, MCLR_OFF
    info var byte[5]
    trisa = %00000000
    trisb = %00000000
    trisc = %00000000
    ansel = 0
    anselh = 0
    poll:
            SERIN portc.5, N2400, 1000, nxt, ["r"], info[0] 'Get input
            SERIN portc.5, N2400, info[1] 'get the word "relay"
            SERIN portc.5, N2400, info[2]
            SERIN portc.5, N2400, info[3]
            SERIN portc.5, N2400, info[4]
            SEROUT portb.7, N2400, [info[1], info[2], info[3], info[4] ]
    goto poll
    nxt:
        serout portb.7, N2400, ["timeout"]
    goto poll
    A tutorial for the analog settings would be great, but this should help some
    and here is a way to use the ADC that is a little different than the manual, I still prefer this method.
    http://rentron.com/PICX2.htm
    Read through the above example, when you understand how it works it should really help you understand the inner workings.
    Post your questions.
    Nov 2008
    Default noise reduction
    hey, my code is working great, but I have been running into some problems with noise. I geuss I should state the problem first. I am trying to get both input and output working on about a 1 foot long straight (four wires untwisted parrallel) serial cable to a PC. it worked ok before when I was just using on line and a ground, but now that I have input and output lines going to the pc, I get noise on the other line everytime I use the serout command from the pic. tried using 10k pulldowns (not being sure about the connection on that I ran 10k from data line to ground and the unused in from the pc as well). that didn't work. then I tried a 10 mf electrolytic on the unused line with neg side going to ground. this worked but it didn't quite seem kosher to be putting a 10mf electrolytic on a line of this sort, especially going to a PC serial line.
    is there perhaps a post here with few help hints and some schematics showing how to reduce noise on straight cabling? I been looking for quite some time for some info to glean.
    also worth noting, when I ran this pic (16f690).. just on the protoboard with intosc and nothing but power, I got no noise, so it is the parrallel capacitance of those wires doing it. recon I could try some cat5 I have lying around.. would be interested in all things noise reduction however.
    I added an xtal btw. specs say +- 1 but in the area of millions of cycles per second, that could be a deal breaker.
    thanks for any help. thanks for the help you allready gave me.
    Capacitors are the best way to reduce noise. I would guess the unused line is acting like an antenna and the cap is suppressing it.
    Nov 2008
    huh.. I tried that electrolytic 10 mf cap. works fine across unused line from the pic. but I started wondering what it might do to the waveform of the incoming pc. I put it accross the pic out, and it went from high/low pulsing to low pulsing. anotherwords the cap is too high. I recon I'm going to have to pull out the old cap box I salvaged some years back and try some various values. I recon its about time to re-stock on the salvaged caps, the goo inside is prolly starting to dry up on the old ones. man.. I sure hope I don't have to find a scope to do this with, that would be a pain in the rear.
    gotta hammer away some more and try to find some solutions. I think I am going to replace the wires with twisted pair cat 5 and see what that does.
  1. HSERIN / SERIN Problem with 16f690
    By rborsuk in forum Serial
    Last Post: - 5th February 2010, 05:51
  2. Programmer for 16F690?
    By mrx23 in forum mel PIC BASIC Pro
    Last Post: - 2nd August 2007, 16:12
  3. Using HPWM in half bridge mode on 16f690
    By Chris Barron in forum mel PIC BASIC
    Last Post: - 29th December 2006, 12:18
  4. tmr1 on 16f690
    By dan gill in forum mel PIC BASIC Pro
    Last Post: - 25th November 2006, 22:58
  5. 16F690 Support
    By Ruben Pena in forum mel PIC BASIC Pro
    Last Post: - 5th September 2005, 23:35
