Hey, this is my first post here to forgive me if I mess up. I am working with a 18f2550 running at 48 Mhz uising HSPLL. I succesfully used the CDC sample from PBP. MY problem is that I cant get it to work if I change the way I allocate the buffer array. I am simply taking a decimal number, converting it to a string, and sending it to the computer. Can someone tell me what I am doing wrong. It is the simplest thing and I dont understand whats wrong. The Terminal program just freezes as soon as I send something to the pic. I want to use this program to do ADC and send them to my computer.
Code:@ __CONFIG _CONFIG1L, _PLLDIV_1_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L define LOADER_USED 1 ' USB Boot loader define RESET_ORG 1000h Define OSC 48 buffer var byte[16] x var byte y var byte cnt Var Byte LED Var PORTB.0 Pause 10 USBInit Low LED ' LED off ' Wait for USB input idleloop: USBService ' Must service USB regularly cnt = 16 ' Specify input buffer size USBIn 3, buffer, cnt, idleloop Toggle LED y = 123 ; just a random number for test goto convert outloop: USBService ' Must service USB regularly USBOut 3, buffer ,6 , outloop Goto idleloop ' Wait for next buffer convert: for x = 2 to 0 step -1 buffer[x]=(y dig x) + $30' find digit & convert to ASCII next x end buffer[3]=13 buffer[4]=10 buffer[5]=0 goto outloop
