Blinky not working with TOGGLE
Results 1 to 4 of 4
    Brussels, Belgium
    Default Blinky not working with TOGGLE
    Now I'm stumped. My usual simple BLINKY is:
    [code]
    LED VAR PORTB.0
    Loop:
    Pause 1000
    toggle LED
    Goto Loop
    [\code]
    Usually works fine but seemingly not on a 16F777. the LED just stays on. This does work:
    [code]
    LED VAR PORTB.0
    LOOP:
    LED = 1
    LED = 0
    goto LOOP
    [\code]
    So what no doubt blindingly obvious simple thing am I overlooking ?
    Andrew
    Jul 2008
    TURKIYE-KONYA
    Default simply "xor"
    Quote Originally Posted by AndrewC View Post
    [code]
    LED VAR PORTB.0
    Loop:
    Pause 1000
    toggle LED
    Goto Loop
    [\code]
    [code]
    LED VAR PORTB.0
    LOOP:
    LED = 1
    LED = 0
    goto LOOP
    [\code]
    Andrew
    i usually work with " xor " instead of toggle command.
    for example ;
    main :
    led = led xor 1 ; working better than toggle
    it's not going to work with XOR... ^1 would work.
    AndrewC, post your Whole code, sure enough you have something else on the top of it. As usual check for multiplexed stuff on the offending I/O.
    Brussels, Belgium
    Thanks for the replies - turns out it was a naff PIC. After some more tinkering last night I started getting programming errors. Tried an 877A to check my programmer, no problems. Pulled a new 777 and voila, success. Phew - just goes to prove - don't assume anything !
  1. Toggle command
    By mr.sneezy in forum mel PIC BASIC Pro
    Last Post: - 16th December 2011, 03:07
  2. Blink.Bas on 18f45k20 Newbie seeks working example.
    By DiscoEd in forum mel PIC BASIC Pro
    Last Post: - 29th December 2009, 04:36
  3. Simple LCD code not working!...WHY?
    Last Post: - 29th November 2009, 20:48
  4. TOGGLE code space and ICD
    By duncan303 in forum mel PIC BASIC Pro
    Last Post: - 25th October 2006, 17:08
  5. Hserin not working...
    By robert0 in forum mel PIC BASIC Pro
    Last Post: - 22nd August 2005, 13:25
