Detect fast movement using photodiode
Results 1 to 13 of 13
    Wink
    Word on the street is: Use a PIC with Schmitt trigger inputs for better results. Better results due to Schmitt triggers hysteresis's gives input port a snap action, dampens analog effect.
    Yesss Joe ...
    Much better, as comparators directly can generate the interrupt ...
    Over that I'd try to use a compensation stage to correct for ambiant light ... look at the attached scheme ... left side of Transistor T2.
    Along the same lines, the data sheet for the part Alain points out has on page 11 another nice way of doing it.
    http://www.google.com/url?sa=t&sourc...SILdHEv5RRcHYQ
    Hi, Dave
    Not so nice ...
    as the goal, here, is to take care the detectors are not saturated by light ...
    Hi, Dave
    Not so nice ...
    Maybe... but if the OPs part was to pass the two detectors causing the differential ?? then saturation may not be a problem ??
    I am going to try it some day. Just an idea.
    Lightbulb
    Halas !!!
    when saturated ... your detectors won't "see" anything ... both of them !!!
    no differential signal nor ...
    Halas !!!
    I am thinking along the lines of both detectors being saturated but spaced maybe a centimeter or so apart. When the piece being detected cast a shadow on one and not the other then the differential. I guess it would only work if the light source was coming from one direction only........Darn, now I am back to square one
    Aug 2008
    Halas !!!
    From that datesheet, it said that the circuit will not be sensitive to changes in light as the source ages, this means saturate right?
    That means I can't connect IR TX continously?
    Post
    Quote Originally Posted by Pic2008 View Post
    That means aging will modify BOTH sources ... but "saturate" means the sensors ( not the source ...) cannot make any difference in light changes.
    just as if you look straight at the sun ... you can't distinguish anything more in the sky , even in front of you !!! ( the model plane you should fly is a "good" example here ... lol : little chanche for you to keep it in the air ... )
  1. Replies: 1
    Last Post: - 7th November 2007, 20:36
  2. Possible to detect I2C Device?
    Last Post: - 30th March 2007, 10:13
  3. code conversion
    By saturnX in forum mel PIC BASIC
    Last Post: - 3rd October 2005, 17:17
  4. Detect baud rate
    By Dick M in forum mel PIC BASIC Pro
    Last Post: - 2nd July 2005, 21:10
  5. A/D on 16F877. How fast can I go?
    By atomski in forum mel PIC BASIC Pro
    Last Post: - 8th April 2004, 06:51
