Detect fast movement using photodiode
Results 1 to 13 of 13
Threaded View
    Aug 2008
    Question Detect fast movement using photodiode
    I have used LDR and a LED to detect small objects moving across it ~ 1 cm.
    The object is 5mm x 5 mm.
    This design is useful to detect slow object.
    But I would like to detect very fast movement across LED and photodiode.
    However the output of a photodiode is analog. How do i go about interfacing this circuit to PIC16F877? To detect the photodiode input, I plan to enable PortB INTB interrupt so it will send a serial message to PC immediately. Is this circuit sufficient to detect fast movement or do I need IR or laser? The distance between tx and rx is ~1cm.
    Any suggestion is welcome.
  1. Replies: 1
    Last Post: - 7th November 2007, 21:36
  2. Possible to detect I2C Device?
    By Squibcakes in forum mel PIC BASIC Pro
    Last Post: - 30th March 2007, 11:13
  3. code conversion
    By saturnX in forum mel PIC BASIC
    Last Post: - 3rd October 2005, 18:17
  4. Detect baud rate
    By Dick M in forum mel PIC BASIC Pro
    Last Post: - 2nd July 2005, 22:10
  5. A/D on 16F877. How fast can I go?
    By atomski in forum mel PIC BASIC Pro
    Last Post: - 8th April 2004, 07:51
