I2C Slave with a PIC
Results 1 to 40 of 130
    Oct 2008
    Southern California
    Default Most any 18F will do
    Daniel - I'd be happy if any 18F would work. I'm starting to think something's wrong with PBP and 18F.
    Thanks for your continued attempts to beat this problem into submission!
    I'm going to switch to 16F877A (the old standby to see if I can get them to talk - once I get that, then we'll come back here and try again!
    I played all night with a 16F88 as a master and a 16F877 as a slave (the other way around I was playing these days)...
    I can send commands to the slave (16F877) and this is working fine, but something is wrong because I cannot read from the slave.
    I mean, I can read from the slave, but I'm not getting the value I wanted. For example, I'm supposed to read 12, but I'm reading 1.
    The code is the same I'm using for the 16F88 as a slave, so, that code is working fine. This is really strange.
    PS: today is my birthday, and it's almots 7am and I need some sleep... I'll continue later in the afternoon...
    Hangover, Germany
    Exclamation
    I has gone through this hell too.
    I bought a cheap LA (Po.Scope) in order to debug my code. I was looking for errors in PBP too, but at least the error was im my code (and maybe in PBP)...
    Please, post your code again.
    I use the 16F872 and 16F876 and 18F252 as I2C-slaves. They work all !!!
    Look at this page: http://www.astrosurf.com/soubie/pic_as_an_i2c_slave.htm
    I saw that page and talked to Robert, but, to be honest, I don't understand how to use his code...
    Hangover, Germany
    Exclamation
    Again ... post your code !
    Hangover, Germany
    Exclamation
    Quote Originally Posted by danielhr77 View Post
    What ?
    It's PBP !
    Mar 2008
    Gerogetown, Texas
    Default Pic18F2620 Slave working
    Here is the code that is working for me. I am sending three bytes to the slave. In this example 10, 20 and 30. The slave adds 1 and sends back 11, 21 and 31.
    Here is a snipit of the master portion.
     I2Caddress = $0A
     I2CWrite i2cdat,i2cclk,I2Caddress,[10,20,30],NoGo
     pauseus 5
     i2cread i2cdat,i2cclk,i2caddress,[tp_x, tp_y, tp_dp],NoGo2
     pauseus 5
           USBBuffer[0] = tp_x
           USBBuffer[1] = tp_y
           USBBuffer[2] = tp_dp
           USBBuffer[3] = 0
           gosub dousbout        ' I am using USB as a debugger
    goto mainmenu
    NoGo:
           USBBuffer[0] = 1
           USBBuffer[1] = 2
           USBBuffer[2] = 3
           USBBuffer[3] = 0
           gosub dousbout
    goto mainmenu
    NoGo2:
           USBBuffer[0] = 4
           USBBuffer[1] = 5
           USBBuffer[2] = 6
           USBBuffer[3] = 0
           gosub dousbout
    goto mainmenu
    Here is the full slave. Pic18F2620 @ 20Mhz
    asm
            __CONFIG    _CONFIG1H, _OSC_HS_1H
            __CONFIG    _CONFIG2H, _WDT_OFF_2H & _WDTPS_512_2H
            __CONFIG    _CONFIG3H, _PBADEN_OFF_3H
            __CONFIG    _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
    endasm
    DEFINE OSC 20
    'DEFINE ADC_BITS 10
    'DEFINE ADC_CLOCK 3
    'DEFINE ADC_SAMPLEUS 50
    Define I2C_SLOW 1
    DEFINE I2C_HOLD 1
    'OSCCON = %01110001 '8mhz
    'OSCTUNE.6 = 1  ' PLL selected 32mhz clock
    ' PicBasic Pro I2C slave program
    ' Alias pins
    scl     VAR     PORTC.3         ' I2C clock input
    sda     VAR     PORTC.4         ' I2C data input
    'ADCON2.7=1
    ADCON1 = $F     '$B       'an1-an3 analog remainder digital
    CMCON = 7         'PortA Digital
    '---------------- Alias pins -----------------------------------
    'SCLDIR              var TRISC.3
    'SDADIR              var TRISC.4
    '--------------- Define used register flags -------------------
    SSPIF               VAR PIR1.3    ' SSP (I2C) interrupt flag
    SSPIE               VAR PIE1.3
    BF                  VAR SSPSTAT.0 ' SSP (I2C) Buffer Full
    R_W                 VAR SSPSTAT.2 ' SSP (I2C) Read/Write
    D_A                 VAR SSPSTAT.5 ' SSP (I2C) Data/Address
    CKP                 VAR SSPCON1.4  ' SSP (I2C) SCK Release Control
    SSPEN               VAR SSPCON1.5  ' SSP (I2C) Enable
    SSPOV               VAR SSPCON1.6  ' SSP (I2C) Receive Overflow Indicator
    WCOL                VAR SSPCON1.7  ' SSP (I2C) Write Collision Detect
    STAT_BF             VAR SSPSTAT.0 ' SSP (I2C) Buffer Full
    STAT_RW             VAR SSPSTAT.2 ' SSP (I2C) Read/Write
    STAT_DA             VAR SSPSTAT.5 ' SSP (I2C) Data/Address
    CKE                 VAR SSPSTAT.6 ' SSP (I2C) Data/Address
    WrData              var byte
    j                   var byte
    '------------------- Rx Buffer defintion --------------------
    RxBufferLEN         con 3
    RxBuffer            var byte[Rxbufferlen]
    RxBufferIndex       var byte
    RxCnt               var byte
    rxcnt = 0
    '------------------ Tx Buffer defintion ----------------------
    TxBufferLEN         con 3
    TxBuffer            var byte[txbufferlen]
    TxBufferIndex       var byte
    TxCnt               var byte
    txcnt = 0
    '------------------ Define constants ------------------------
    rxinptr             var byte
    rxoutptr            var byte
    txinptr             var byte
    txoutptr            var byte
    rxinptr = 0
    rxoutptr = 0
    txinptr = 0
    txoutptr = 0
    I2Caddress          CON $0A                  ' Make address = 2
    ' Allocate RAM
    result	VAR		BYTE			' ADC result
    DataIn 	VAR     BYTE[8]			' Data in
    DataOut	VAR     BYTE[8]			' Data out array
    readcnt	VAR     BYTE            ' I2C read count
    readcnt = 0				' Zero counter
    '       Variables used in the program.
    transdata              var byte
    transbit7              var transdata.7
    Tdata                  var word
    txdata                 var word
    tydata                 var word
    txcomp                 var word
    tycomp                 var word
    tx                     var word
    ty                     var word
    tvalue                 var word
    txcomp=0
    tycomp=0
    tx=0
    ty=0
    tvalue=0
    PD      var            bit 'pen down flag
    address var            byte
    ' -------------- Initialize I2C slave mode ------------------------
    'SCLDIR = 1          ' SCL must be an input before enabling interrupts
    'SDADIR = 1
    SSPADD = I2Caddress ' Set our address
    SSPCON1 = $36        ' Set to I2C slave with 7-bit address
    SSPCON2.0 = 1
    SSPSTAT = 0
    SSPIE = 1
    SSPIF = 0
    RxBufferIndex = 0
    TxBufferIndex = 0
    'LED1  var PORTC.1
        '   Interrupt definition
            '   USB interrupt used to keep USB connection alive
    INCLUDE "DT_INTS-18.bas"    ' Base Interrupt System
    INCLUDE "ReEnterPBP-18.bas"     ' Include if using PBP interrupts
    INT_LIST  macro    ; IntSource,         Label,  Type, ResetFlag?
            INT_Handler    SSP_INT,  _I2C_Int,   PBP,  yes
    endasm
    ''----------------- Initialization Done! -----------------------------
    @ INT_ENABLE  SSP_INT     ; Master Synchronous Serial Port Interrupt Flag bit. The transmission/reception is complete
    txbuffer = 0
    portc.1 = 1'high led1
    goto Main
    '------------------------- I2C subroutine  --------------------------------
    I2C_Int:
    If R_W = 0 then     'Write from master
        if D_A = 0 then  ' It's address from master
           address = SSPBUF ' do nothing
           rxcnt = 1
           rxinptr = 0
           rxoutptr = 0
           txinptr = 0
           txoutptr = 0
            WCOL = 0
            sspov = 0
            if bf = 1 then   'There is data in buffer
               if rxcnt < rxbufferlen  then
                  rxbuffer[rxinptr] = SSPBUF
                  rxinptr = rxinptr + 1
                  if rxinptr = rxbufferlen then rxinptr = 0
               rxcnt = rxcnt + 1
            EndIF
    else   ' Read by master
            dataout = SSPBUF     'dummy read
    if bf = 0 then   ' if buffer is empty
            if txcnt > 0 then  ' Is there a byte to transfer
               SSPBUF = txbuffer[txoutptr]   'get the byte abd send it
               txoutptr = txoutptr + 1
                      if txoutptr = txbufferlen then txoutptr = 0
               txcnt = txcnt - 1
            'no byte to send
    sspif = 0
    CKP = 1
    @ INT_RETURN
    ' -------------------------end I2C subroutine  --------------------------------
    '--------------------[ main program loop]---------------------------------------
    'SSPOV = 0
    'WCOL = 0
         'INTCON.7 = 0   'trrn off interrupt
         if txcnt < txbufferlen  then
                TxBuffer[txinptr] = rxbuffer[txinptr] | %00000001     ' add "1" to the data in
                txinptr = txinptr + 1
                if txinptr = txbufferlen  then txinptr = 0
                txcnt = txcnt + 1
                'INTCON.7 = 1   'turn on interrupt
        if rxcnt != 0 then
           datain = rxbuffer[rxoutptr]
           rxoutptr = rxoutptr + 1
           if rxoutptr = rxbufferlen  then
              rxoutptr = 0
           rxcnt = rxcnt - 1
    WrData=0
    Disregard all the extra stuff, I am using this slave a Touch Screen controller.
    Oct 2008
    Southern California
    Thumbs up Making some headway now
    Group,
    I'm back using the 18F4685, one in Master and one in Slave. I'm now able to read from the Slave, 3 digits (and their even the right ones!). I set up a fast loop to read the digits on the Master side and do nothing but send the data in a fast loop on the Slave side. (Will post both sides soon).
    The problem is still the same on sending data from the Master to the Slave. The address gets there, matches, sets the SSPIF and BF, but also I get the SSPOV (overflow) bit set. Even on the first attempt to read the buffer, the OV is already set. There must be some "slow it down" handshaking not happening just right. Has anyone had luck sending multiple bytes to the Slave?
    rswain
    Oct 2008
    Southern California
    The attachments are the latest code (starting to work on the 18F4685). Still not able to send Master to Slave - Slave gets OVERFLOW flag.
    Rswain
    Jun 2011
    Philippines
    Default Re: I2C Salve with a PIC
    Hi, I'm interested to try the master-slave(I2C) worked by Daniel and other members, sorry if it is not obvious for me in the code given, but can someone share the schematic used in the example?
    I'm using Pic16877(master) and Pic16F88(salve).
    tacbanon
    Jun 2011
    Philippines
    From the code provided, here is how I interpret the pin connection between pics.
    Master(Pic16F877A) Slave(Pic16F88)
    (SCL)RB5 <---> RB4
    (SDA)RB7 <---> RB1
    but with this connection, LCD displays "Time out", can anyone help me what I'm missing?
  1. Problem with PICto PIC I2C MASTER-SLAVE
    By juanen19 in forum mel PIC BASIC Pro
    Last Post: - 11th June 2013, 03:58
  2. PIC as I2C Slave
    By Mainul in forum General
    Last Post: - 5th January 2013, 14:23
  3. I2C Slave, config Vref - + in pic with ADC
    By sebapostigo in forum PBP Wish List
    Last Post: - 5th March 2007, 04:21
  4. Pic as an i2c slave
    By Robert Soubie in forum mel PIC BASIC Pro
    Last Post: - 25th January 2007, 22:11
  5. Use pic as slave in I2C
    By robert0 in forum General
    Last Post: - 3rd February 2006, 20:26
