I2C Slave with a PIC
Results 1 to 40 of 130
    Oct 2008
    Southern California
    Unhappy Still not working here
    Guys,
    I've been working this problem for nearly a year now. I've tried Soubie's code with no luck, and the code from this thread isn't working either. I'm using the 18F4620 as the master talking to an 18F2620, the little brother of the 4620 as the slave. I've RTFM to the point I can recite it, and the Errata sheets, and I've tried countless logical, and even illogical options to trying to get it working.
    The best I can get so far is the master sends the address byte and the slave accepts it when it matches its own address and ignores addresses not matching its own. When the address matches, the slave sets the Buffer Full and the Interrupt Flags, but for some reason won't send an ACK back to the master (at least that's what this thread's code [and my own polls of the master's ACK flag] are saying). I've made sure to clear all flags as the datasheet clearly directs, and still no luck. If the slave would ACK, the master would send the next byte and so on.
    I'm operating both chips on their internal crystal (8 MHz) and using the 4x PLL (= 32MHz). Before you go there, I'm already successfully talking to an I2C real-time clock chip with no problems and I'm saving data to an external I2C EEPROM regularly with no problems. The I2C network is working with the PICs at 32 MHz. I'm on the right pins; I'm using the pull external pull-up resistors...
    I've had this exact hardware working in the past when using MikroElektronika Basic, but I'm much happier in PBP. This one problem is holding up the entire project. Trying to get two 18F's to ping-pong data back and forth is a killer.
    If someone has even a bit more success than what I've had, please post it and maybe together we can chip away at this challenge.
    Quote Originally Posted by rswain View Post
    Well, the code provided by Al (aratti) and the one I posted works great both ways!
    I don't know what to tell you without looking at your code, but I modified the one provided by Al just a little and worked right away!
    Can you post your code? Maybe we can see something that you're not seeing.
    Sep 2005
    Campbell, CA
    I'll be able to devote some time to a group project in about two weeks. I will also have another issue - I'm forced to work with 10-bit addresses.
    Charles Linquist
    Oct 2008
    Southern California
    Default Code for 18F2620 that doesn't ACK for some reason
    Here's my slave code that's not sending back the ACK. I appologize for the "dead code" and commented out parts in advance. Maybe you'll see something I'm missing...
    'Oscillator Initialization
        DEFINE OSC 32               ' Osc. in MHz
        OSCCON = %01110000
        OSCTUNE.6 = 1
        ADCON0.0 = 0                ' Turns off A-to-D module
        ADCON1 = $0F                ' Makes 100% port A digital
        TRISA = %00000000
        CMCON = 7 ' Comparators Off
    DEFINE I2C_HOLD 1
    'DEFINE I2C_SLOW 1
    ' Define used register flags
    SSPIF    VAR PIR1.3 ' SSP (I2C) interrupt flag
    SSPIE    VAR PIE1.3 ' SSP Int Enable
    BF       VAR SSPSTAT.0 ' SSP (I2C) Buffer Full
    R_W      VAR SSPSTAT.2 ' SSP (I2C) Read/Write
    D_A      VAR SSPSTAT.5 ' SSP (I2C) Data/Address
    CKP      VAR SSPCON1.4 ' SSP (I2C) SCK Release Control
    SSPEN    VAR SSPCON1.5 ' SSP (I2C) Enable
    SSPOV    VAR SSPCON1.6 ' SSP (I2C) Receive Overflow Indicator
    WCOL     VAR SSPCON1.7 ' SSP (I2C) Write Collision Detect
    'STRETCH  VAR SSPCON2.0 ' SSP (I2C) Clock stretch
    A        var byte      ' my counter variable for testing
    '---------------- Alias pins -----------------------------------
    TRISC.3 = 1         ' input
    TRISC.4 = 1         ' input
    '--------------- Define used register flags -------------------
    'STAT_BF             VAR SSPSTAT.0           ' SSP (I2C) Buffer Full
    'STAT_RW             VAR SSPSTAT.2           ' SSP (I2C) Read/Write
    'STAT_DA             VAR SSPSTAT.5           ' SSP (I2C) Data/Address
    CKE                 VAR SSPSTAT.6           ' SSP (I2C) Data/Address
    '------------------- Rx Buffer definition --------------------
    RxBufferLEN         con 3
    RxBuffer            var byte[Rxbufferlen]
    RxBufferIndex       var byte
    '------------------ Tx Buffer definition ----------------------
    TxBufferLEN         con 3
    TxBuffer            var byte[txbufferlen]
    TxBufferIndex       var byte
    '------------------ Define constants ------------------------
    'I2Caddress          CON $2                  ' Make address = 2
    I2Caddress          CON $06                  ' Make address = 2
    ' Define constants
    U8       var byte
    U17      var byte
    InByte   var byte
    OutByte  var byte
    readcnt  VAR BYTE
    'U8 = $06
    U17 = $08
    'STRETCH = 1
    WRData var byte
    ' Initialize I2C slave mode
    'SSPCON2 = 0 ' General call address disabled
    'SSPADD = My_I2C_address                     ' Set our address
    SSPADD = I2Caddress                         ' Set our address
    SSPCON2.7 = 0                               ' General call address disabled
    SSPCON1 = $36                               ' Set to I2C slave with 7-bit address
    SSPSTAT = 0
    SSPIE = 1
    SSPIF = 0
    RxBufferIndex = 0
    TxBufferIndex = 0
    bf = 0
    SSPOV = 0
        'Port C harware UART settings
        DEFINE HSER_RCSTA 90h
        DEFINE HSER_TXSTA 20h
        DEFINE HSER_BAUD 9600
        DEFINE HSER_CLROERR 1
    '----------------- Initialization Done! -----------------------------
    rxbuffer[0] = 0
    rxbuffer[1] = 0
    rxbuffer[2] = 0
    GoTo main
    I2C_Slave:                                  ' I2C slave subroutine
      hserout ["SSPIF = ",#SSPIF,"  BF = ",#bf,13,10]
      hserout ["R_W = ",#R_w,"  D_A = ",#D_A,13,10]
      hserout ["SSPBUF = ",#SSPBUF,13,10]
      SSPIF = 0                                 ' Clear interrupt flag
      SSPov = 0                                 ' Clear interrupt flag
      bf = 0                                      ' clear buffer full
      IF R_W = 1 Then
        hserout ["R_W = 1, Read data from U8",13,10]
        goto I2C_Read                  ' Read data from us
      IF SSPBUF = I2Caddress Then
        hserout ["It's to me! ",#SSPBUF," = ",#I2Caddress,13,10]
      IF D_A = 1 Then
        hserout ["Data (not address)",13,10]
        goto I2C_Write                 ' Data for us (not address)
      GoTo I2C_Exit
    I2C_Write:                                      ' I2C write data to us
      InByte = SSPBUF                             ' Put buffer data into array
      Rxbuffer[Rxbufferindex] = InByte
      rxbufferindex = rxbufferindex + 1
      hserout ["SSPBUF Write = ",#SSPBUF,13,10]
      GoTo i2c_exit
    I2C_Read:                                 ' I2C read data from us
      hserout ["SSPBUF Read = ",#SSPBUF,13,10]
      IF D_A = 0 Then
        TxBufferIndex = 0
      EndIF
    while BF : wend                        ' loop while buffer is full
    wcol = 0                                    ' clear collision flag
    SSPBUF = TxBuffer[TxBufferIndex]
    while wcol
    wcol = 0
    wend
      hserout ["SSPBUF Outbyte = ",#SSPBUF," should be outbyte 16 or 31",13,10]
    CKP = 1                                     ' release clock, allowing read by master
    TxBufferIndex = TxBufferIndex + 1           ' increment index
    if TxBufferIndex = TxBufferlen then         ' all bytes have been tx
    TxBufferIndex = 0                           ' reset index
    I2C_Exit:
      pause 300
      hserout [13,10,"Start of program U8",13,10]
      hserout ["RxBuffer = "]
      for a = 0 to 2
        hserout [dec rxbuffer[a],"  "]
      next a
      hserout [13,10]
    loop:
    '  IF SSPIF = 1 Then
      IF BF = 1 Then
        hserout [13,10,"Went into I2C_Slave routine",13,10]
        GoSub i2c_slave
        for a = 0 to 2
        next a
        hserout [13,10]
        hserout ["SSPCON1 = ",hex sspcon1,"  ",bin sspcon1,13,10]
        hserout ["SSPCON2 = ",hex sspcon2,"  ",bin sspcon2,13,10]
        hserout ["SSPSTAT = ",hex sspstat,"  ",bin sspstat,13,10]
        hserout ["SSPBUF = ",#sspbuf,13,10]
        if rxbufferindex = RxBufferLEN then           ' end of buffer transfer
          WrData = 1
          rxbufferindex = 0
          rxbuffer[0] = 0
          rxbuffer[1] = 0
          rxbuffer[2] = 0
          hserout ["RxBuffer Cleared = "]
          for a = 0 to 2
          next a
          hserout [13,10]
      SSPOV = 0
      WCOL = 0
      IF RxBuffer[0] = 15 Then
        hserout ["Got a 15",13,10]
        hserout ["  Readcount is: ",#readcnt,13,10]
        hserout ["Have a 16 to send if asked",13,10]
        TxBuffer[0] = 16
      EndIF
      IF RxBuffer[0] = 30 Then
        hserout ["Got a 30",13,10]
        hserout ["Have a 31 to send if asked",13,10]
        TxBuffer[0] = 31
      EndIF
    WrData=0
    pause 50
    GoTo loop
    Last edited by ScaleRobotics; - 22nd October 2010 at 13:24. Reason: added code tags
    One thing I learn these days is that you cannot mess with the I2C timing.
    Looking at your code, I guess those hserouts are killing the protocol.
    I'll take a closer look at everything else tomorrow.
    Try this code, I cleaned it up a lot. Slave address is 2.
    1) From the master, try to read 12 from the slave
    2) Try to send one byte (zero) to the slave and do something.
    I don't have MPASM so, it could be some small errors, check them.
    OSCCON = %01110000
    OSCTUNE.6 = 1
    TRISA = %00000000
    DEFINE I2C_HOLD 1
    TRISC.3 = 1 ' input
    TRISC.4 = 1 ' input
    RxBufferLEN CON 1
    RxBuffer VAR BYTE[Rxbufferlen]
    RxBufferIndex VAR BYTE
    TxBufferLEN CON 1
    TxBuffer VAR BYTE[txbufferlen]
    TxBufferIndex VAR BYTE
    ' Define constants
    datain VAR BYTE
    readcnt VAR BYTE
    WRData VAR BYTE
    SSPSTAT = 0
    SSPIE = 1
    SSPIF = 0
    RxBufferIndex = 0
    TxBufferIndex = 0
    bf = 0
    SSPOV = 0
    GoTo main
              sspif = 0                            ' clear interrupt flag
              IF r_w = 1 Then I2C_Read                ' read data from us
              IF bf = 0 Then I2C_Exit               ' nothing in buffer so exit
              IF d_a = 1 Then I2C_Write                ' data for us (not address)
              IF sspbuf != i2caddress Then I2C_Exit ' clear the address from the buffer
              readcnt = 0                          ' mark as first read
              GoTo I2C_Exit
           datain = sspbuf                   ' put buffer data into array
           rxbuffer[rxbufferindex] = datain
           rxbufferindex=rxbufferindex + 1
           IF rxbufferindex = rxbufferlen Then ' end of buffer transfer
              wrdata = 1
              rxbufferindex = 0
           EndIF
    GoTo i2c_exit
           IF d_a = 0 Then
              txbufferindex = 0
           EndIF
           While stat_bf : Wend                        ' koop while buffer is full
           sspbuf = txbuffer[txbufferindex]
           While wcol
                 wcol = 0
           Wend
           ckp = 1                                     ' release clock, allowing read by master
           txbufferindex = txbufferindex + 1           ' increment index
           IF txbufferindex = txbufferlen Then         ' all bytes have been tx
              txbufferindex = 0                        ' reset index
           EndIF
    GoTo i2c_exit
    I2C_Exit:
             sspov = 0
             wcol = 0
             wrdata = 0
          txbuffer[0] = 12 ' test value
          rxbuffer[0] = 0
          IF sspif = 1 Then
             GoSub i2c_slave
          EndIF
          Select Case rxbuffer[0]
                 Case 0
                       ' do something here, turn on LED for example.
          End Select
          GoTo main
    Hangover, Germany
    Exclamation
    You have to set the CKP-bit even after a WRITE-operation.
    Try to disable the HSEROUT-lines.
    Maybe this command will alter the TRISC-register, which will kill the I2C-engine.
    Sometime, you should clear the OV-bit...
    Mar 2008
    Gerogetown, Texas
    I have been trying to get a 18F2620 to run as a slave. i ran across this in the ERRATA for this device.
    43. Module: MSSP (I2C Slave)
    The MSSP module operating in I2C, 7-Bit Slave
    mode (SSPM3:SSPM0 = 0110) may not send a
    NACK bit (/ACK) in response to receiving the slave
    address loaded in SSPADD<7:1>. Addresses are
    in one of these ranges:
    • 0x00 to 0x07
    • 0x78 to 0x7F
    These addresses were reserved by Philips® Semiconductors
    in “The I2C Specification”, Version 2.1,
    released January 2000. Section 10.1 “Definition of
    bits in the first byte” defines the purposes of these
    addresses.
    This specification can be found at:
    http://www.semiconductors.philips.com/i2c
    Work around
    This version of the silicon does not respond to
    slave addresses in the ranges previously listed.
    Use either of these work arounds:
    • Change the 7-bit slave address in SSPADD to
    an address in the range of 0x08 to 0x77.
    • Use Revision B silicon. This version of silicon
    removes this issue’s addressing restrictions.
    I have gotten sporadic results for the master reading the slave in the following code.
    Darrell's Instant Interrupt
        '   Interrupt definition
            '   USB interrupt used to keep USB connection alive
    INCLUDE "DT_INTS-18.bas"    ' Base Interrupt System
    INCLUDE "ReEnterPBP-18.bas"     ' Include if using PBP interrupts
    INT_LIST  macro    ; IntSource,         Label,  Type, ResetFlag?
            INT_Handler    SSP_INT,  _I2C_Int,   PBP,  yes
    endasm
    ''----------------- Initialization Done! -----------------------------
    @ INT_ENABLE  SSP_INT     ; Master Synchronous Serial Port Interrupt Flag bit. The transmission/reception is complete
    'txbuffer = 0
    The Interrupt handler
    I2C_Int:
    If R_W = 0 then
        if D_A = 0 then
           address = SSPBUF
    Still working on master to slave write
    '        if bf = 1 then
    '           if rxcnt <= rxbufferlen then
    '              datain[rxcnt] = SSPBUF
    '              rxcnt = rxcnt + 1
    '              if rxcnt = rxbufferlen then rxcnt = 0
    '           endif
            EndIF
        dataout = SSPBUF     'dummy read
        if txcnt > 0 then
           SSPBUF = txbuffer[txoutptr]
           txoutptr = txoutptr + 1
                  if txoutptr = txbufferlen then txoutptr = 0
           txcnt = txcnt - 1
        'no byte to send
    CKP = 1
    @ INT_RETURN
    and the main loop. I want to send three bytes to the master. In this case "three sevens".
    SSPOV = 0
    WCOL = 0
         if txcnt < txbufferlen - 1 then
                TxBuffer[txinptr] = 7
                txinptr = txinptr + 1
                if txinptr = txbufferlen then txinptr = 0
                txcnt = txcnt + 1
    WrData=0
    I did the same slave program in "C" and it works well.
    The Master is reading and writing to a RTC module and a bank of 4 24lc256 EEProms and a I2C Port expander with out any problems.
    It is getting close
    Take care
  1. Problem with PICto PIC I2C MASTER-SLAVE
    By juanen19 in forum mel PIC BASIC Pro
    Last Post: - 11th June 2013, 02:58
  2. PIC as I2C Slave
    By Mainul in forum General
    Last Post: - 5th January 2013, 13:23
  3. I2C Slave, config Vref - + in pic with ADC
    By sebapostigo in forum PBP Wish List
    Last Post: - 5th March 2007, 03:21
  4. Pic as an i2c slave
    By Robert Soubie in forum mel PIC BASIC Pro
    Last Post: - 25th January 2007, 21:11
  5. Use pic as slave in I2C
    By robert0 in forum General
    Last Post: - 3rd February 2006, 19:26
