2' Slave - 16F88 - Internal 8Mhz
Code:'------------------------------------------------------------------------------ '------------------------------------------------------------------------------ ' Slave '------------------------------------------------------------------------------ '------------------------------------------------------------------------------ @ device pic16f88, intrc_osc_noclkout ' system clock options @ device pic16f88, wdt_on ' watchdog timer @ device pic16f88, pwrt_on ' power-on timer @ device pic16f88, mclr_off ' master clear options (internal) @ device pic16f88, protect_off ' code protect off '--- set device --------------------------------------------------------------- DEFINE OSC 8 OSCCON = %01110001 '8mhz '------------------------------------------------------------------------------ CMCON = 7 ADCON1 = 0 ' Disable A/D converter ADCON0 = 0 ANSEL = 0 ' all analog pins to digital '--- tris port config here (don't use SCL & SDA pins other than I2C) ---------- DEFINE I2C_HOLD 1 TRISB.1 = 1 TRISB.4 = 1 '--- Alias pins --------------------------------------------------------------- SDADIR VAR TRISB.1 SCLDIR VAR TRISB.4 '--- Define here your variables and alias ------------------------------------- LEDT VAR PORTA.2 LEDL VAR PORTB.7 LEDM VAR PORTB.6 LEDR VAR PORTB.5 readcnt VAR BYTE datain VAR BYTE WrData VAR BYTE '--- Define used register flags ------------------------------------------------ SSPIF VAR PIR1.3 ' SSP (I2C) interrupt flag SSPIE VAR PIE1.3 BF VAR SSPSTAT.0 ' SSP (I2C) Buffer Full R_W VAR SSPSTAT.2 ' SSP (I2C) Read/Write D_A VAR SSPSTAT.5 ' SSP (I2C) Data/Address CKP VAR SSPCON.4 ' SSP (I2C) SCK Release Control SSPEN VAR SSPCON.5 ' SSP (I2C) Enable SSPOV VAR SSPCON.6 ' SSP (I2C) Receive Overflow Indicator WCOL VAR SSPCON.7 ' SSP (I2C) Write Collision Detect STAT_BF VAR SSPSTAT.0 ' SSP (I2C) Buffer Full STAT_RW VAR SSPSTAT.2 ' SSP (I2C) Read/Write STAT_DA VAR SSPSTAT.5 ' SSP (I2C) Data/Address CKE VAR SSPSTAT.6 ' SSP (I2C) Data/Address '--- Rx Buffer defintion ------------------------------------------------------ RxBufferLEN CON 1 RxBuffer VAR BYTE[Rxbufferlen] RxBufferIndex VAR BYTE '--- Tx Buffer defintion ------------------------------------------------------ TxBufferLEN CON 1 TxBuffer VAR BYTE[txbufferlen] TxBufferIndex VAR BYTE '--- Define constants --------------------------------------------------------- I2Caddress CON $5 ' Make address = 5 '--- Initialize I2C slave mode ------------------------------------------------ SCLDIR = 1 ' SCL must be an input before enabling interrupts SDADIR = 1 SSPADD = I2Caddress ' Set our address SSPCON = $36 ' Set to I2C slave with 7-bit address SSPSTAT = 0 SSPIE = 1 SSPIF = 0 RxBufferIndex = 0 TxBufferIndex = 0 '--- Initialization Done! ----------------------------------------------------- GoTo main '--- I2C subroutine ---------------------------------------------------------- i2cslave: ' I2C slave subroutine SSPIF = 0 ' Clear interrupt flag IF R_W = 1 Then i2crd ' Read data from us IF BF = 0 Then i2cexit ' Nothing in buffer so exit IF D_A = 1 Then i2cwr ' Data for us (not address) IF SSPBUF != I2Caddress Then i2cexit ' Clear the address from the buffer readcnt = 0 ' Mark as first read GoTo i2cexit i2cwr: ' I2C write data to us datain = SSPBUF ' Put buffer data into array Rxbuffer[Rxbufferindex]=datain Rxbufferindex=rxbufferindex+1 IF rxbufferindex=RxBufferLEN Then ' end of buffer transfer WrData=1 rxbufferindex=0 EndIF GoTo i2cexit i2crd: ' I2C read data from us IF D_A = 0 Then TxBufferIndex = 0 EndIF While STAT_BF : Wend ' loop while buffer is full wcol = 0 ' clear collision flag SSPBUF = TxBuffer[TxBufferIndex] While wcol wcol = 0 SSPBUF = TxBuffer[TxBufferIndex] Wend CKP = 1 ' release clock, allowing read by master TxBufferIndex = TxBufferIndex + 1 ' increment index IF TxBufferIndex = TxBufferlen Then ' all bytes have been tx TxBufferIndex = 0 ' reset index EndIF i2cexit: Return '--- End I2C subroutine ------------------------------------------------------ Main: txbuffer = 24 IF SSPIF = 1 Then GoSub i2cslave EndIF SSPOV = 0 WCOL = 0 Select Case RxBuffer[0] Case 4 High LEDT Case 10 Low LEDT End Select WrData=0 GoTo Main '------------------------------------------------------------------------------ End '------------------------------------------------------------------------------ '------------------------------------------------------------------------------
