Elapsed Timer Demo in a PIC12F675
Results 1 to 17 of 17
    Default Elapsed Timer Demo in a PIC12F675
    Hello,
    How to use the Elapsed Timer Demo in a PIC12F675 to maintain a on led by 5 days and then goes off. ¿It is possible to do this?
    Sep 2005
    Campbell, CA
    If you just want 5 days then -
    LED = ON
    For X = 1 to 7200 (60 minutes/hour X 24 hours/day X 5 days)
    PAUSE 60000 ; one minute
    Next X
    LED = OFF
    Charles Linquist
    Quote Originally Posted by Charles Linquis View Post
    LED = ON
    Next X
    LED = OFF
    Hey Charles,
    Thanks for your answer but my concern is whether you can do with the Elapsed Timer because it seems to me a good idea.
    Wink
    Hi, Leonardo
    looks Still some way to reach Leonard's code ...
    ALL you have to do is check each second ( or min, if not so precise required !!!) Days-hours-mins-secs ( which are already existing variables ) and match your own values.
    But forget the // LCD screen ...
    Hi, Leonardo
    Hello Acetronics,
    You can give me an idea or an example to start.
    Thank you
    LED = ON
    Next X
    LED = OFF
    Hello,
    This is the code I've tested with 1 minute and works well, then put 7200 can achieve the 5 days with a good presicion?.
    [HTML]led1 var portb.0
    x var word
    HIGH LED1
    Top:
    For X = 1 to 1 '(60 minutes/hour X 24 hours/day X 5 days)
    Next X
    LOW LED1
    goto Top[/HTML]
    Thank you
    Sep 2005
    Campbell, CA
    The accuracy will be good if you are not using the internal oscillator. You need a crystal or external "can" oscillator for better than 2-3%. If you need really good accuracy, you can (temporarily) shorten the time interval to one day (or so) and compare it to a clock. For example: if you are 1.3% "fast" then increase the value after the PAUSE by 1.3% (60780). That should get you close enough.
    Charles Linquist
    Yup, that'll work.
    As long as it's the only thing the chip will be doing.
    But to answer the original question...
    CLEAR
    LED        VAR GPIO.0
    CMCON = 7
    ANSEL = 0
    Include "Elapsed.bas"
    Gosub ResetTime                ' Reset Time to  0d-00:00:00.00
    Gosub StartTimer               ' Start the Elapsed Timer
    HIGH LED                         ; Start with LED on
    Loop:
        if DaysChanged then
           DaysChanged = 0
           if Days = 5 then LOW LED  ; Turn off LED
    Goto Loop
    Or you can add a blinky LED to show that it's still counting...
    CLEAR
    LED        VAR GPIO.0
    StatLED    VAR GPIO.1
    CMCON = 7
    ANSEL = 0
    Loop:
        if DaysChanged then
           DaysChanged = 0
        IF SecondsChanged then
           SecondsChanged = 0
           Toggle StatLED
        ; Rest of the program goes here
    Goto Loop
    And you can still do other stuff at the same time.
    Yup, that'll work.
    CLEAR
    LED        VAR GPIO.0
    CMCON = 7
    ANSEL = 0
    Loop:
        if DaysChanged then
           DaysChanged = 0
    Goto Loop
    CLEAR
    LED        VAR GPIO.0
    StatLED    VAR GPIO.1
    CMCON = 7
    ANSEL = 0
    Loop:
        if DaysChanged then
           DaysChanged = 0
           SecondsChanged = 0
           Toggle StatLED
    Goto Loop
    Hey Darrel,
    In compiling I get this error because it will be.
    <a href="http://imageshack.us"><img src="http://img231.imageshack.us/img231/9863/errorcv5.jpg" border="0" alt="Image Hosted by ImageShack.us"/></a><br/><a href="http://g.imageshack.us/img231/errorcv5.jpg/1/"><img src="http://img231.imageshack.us/img231/errorcv5.jpg/1/w626.png" border="0"></a>
  1. Elapsed Timer Demo
    Last Post: - 29th October 2012, 17:39
  2. Get elapsed time while TIMER samples pulses
    By RodSTAR in forum mel PIC BASIC Pro
    Last Post: - 27th March 2009, 16:27
  3. Totally Baffled with Elapsed Timer
    By CocaColaKid in forum mel PIC BASIC Pro
    Last Post: - 11th June 2008, 21:01
  4. SPWM and Elapsed Timer
    Last Post: - 8th May 2008, 03:16
  5. Darrel Taylor Elapsed Timer
    By rwskinner in forum mel PIC BASIC Pro
    Last Post: - 13th March 2008, 01:22
