timing equation
Results 1 to 7 of 7
Thread: timing equation
    Jan 2007
    Exclamation timing equation
    I have found this little bit of code from the forum and am trying to do something similar to this with the TMR0 module on a 12F675. I was just wondering how tey came up with the 16.384ms for the time between interrupts.
    I would like to know the equation so i can make it work for my timer application. Any help would be much appreciated.
    ' Set TMR0 to interrupt every 16.384 milliseconds
    OPTION_REG = $55 ' Set TMR0 configuration and enable PORTB pullups
    INTCON = $a0 ' Enable TMR0 interrupts
    On Interrupt Goto tickint
    When you use Timer, you have to take in account at least the OSC and the Timer Prescaler. The datasheet should explain it a little bit.
    This link should also help
    http://www.sxlist.com/techref/microchip/timer.htm
    My PICMultiCalc should help you a little bit too.
    http://www.picbasic.co.uk/forum/atta...7&d=1225550328
    Jan 2007
    Default timer0 test
    i have written this test program to become more familiar with the timer0 module. The only problem is that according to my calulations from the calculator that was posted on this thread the timer should throw and interrupt every 1 ms and then every 1000 roll overs it should increment the seconds variable +1 so my counter counts in seconds. with the code below this should keep the led on for 5 seconds. but im only getting the led to stay on for 320ms. Why is the timing so far off from what i calculated?
    'Definitions'
    DEFINE OSC 3
    DEFINE ADC_BITS 10 ' set number of bits in result
    DEFINE ADC_CLOCK 3 ' set clock source
    DEFINE ADC_SAMPLEUS 50 ' set sampling time for microseconds
    'Definitions'
    'Register Initializations'
    ADCON0 = %10001011 ' set as right justified and turn on AD
    ANSEL = %01001100 ' A to D on AN2 and AN3
    CMCON = %00000111 ' set all pins to digital
    TRISIO = %00011111 ' define Inputs and Outputs
    GPIO = %00000000 ' set all pin states to off
    WPU = %00000000 ' shut off weak pull ups
    OPTION_REG = %01010001 ' set the tmr 0 to prescale of 1:4 for 1ms roll over
    INTCON = %10100000 ' ENABLE THE TMR0 INTERRUPTS
    'Variables'
    LED VAR GPIO.5
    i var word
    ROLLCOUNT VAR WORD
    ROLLOVER_COUNTER VAR WORD
    SECONDS VAR WORD
    'Variables'
    ON INTERRUPT GOTO ROLL_OVER
    INITIALIZE:
    for i = 0 to 50
    pause 10
    next i
    LED = 1
    ROLLOVER_COUNTER = 0
    SECONDS = 0
    MAIN:
    IF SECONDS = 5 THEN LED_OFF
    GOTO MAIN
    LED_OFF:
    LED = 0
    SECONDS = 0
    GOTO INITIALIZE
    DISABLE
    ROLL_OVER:
    ROLLOVER_COUNTER = ROLLOVER_COUNTER + 1 ' INCREMENT ROLL COUNT 1 EVERY 1 ms
    IF ROLLOVER_COUNTER >= 1000 THEN 'created to count seconds instead of ms
    SECONDS = SECONDS + 1
    INTCON.2 = 1
    RESUME
    ENABLE
    It would help to get rid of the pause 10. With your timer0 interrupt happening every 1mS
    you can miss up to 10 interrupt counts. Using BASIC interrupts your pause command will
    have to complete before it jumps to your interrupt handler.
    What speed crystal are you using?
    Edit: If you're using GPIO.5 as the LED output, then I suspect you're uisng the internal osc.
    DEFINE OSC 3 is going to throw timing off since the internal osc freq is 4MHz.
    DEFINE OSCCAL_1K 1
    Would help get your timing a lot closer.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    INTCON
    bit 2 T0IF: TMR0 Overflow Interrupt Flag bit(2)
    1 = TMR0 register has overflowed (must be cleared in software)
    0 = TMR0 register did not overflow
    Everything works as written ... program loops in interrupt ( I make it short ... lol ) after a first "regular" TMR0 interrupt !!!
    may be should CLEAR the TMR0 Flag ... instead of setting it ... ???
    Just an idea
    Yep that would help too....;o}
    -Bruce
    tech at rentron.com
    Untested, but try something like this;
    DEFINE OSCCAL_1K 1 ' load factory osccal value
    ANSEL = 0          ' all digital
    'Variables'
    LED VAR GPIO.5
    SECONDS VAR BYTE
    LED = 0 ' LED off on boot
    MAIN:
      IF SECONDS = 5 THEN
         SECONDS = 0
         TOGGLE LED
      GOTO MAIN
    DISABLE
    ROLL_OVER:
      INTCON.2 = 0
      RESUME
      ENABLE
    -Bruce
    tech at rentron.com
  1. 12F683 serout timing
    By Hobie Cat in forum mel PIC BASIC Pro
    Last Post: - 21st December 2009, 16:57
  2. 18F2550 timing
    By sstt1976 in forum mel PIC BASIC Pro
    Last Post: - 22nd August 2008, 00:30
  3. Timing inaccuracy - any ideas?
    By Optech in forum General
    Last Post: - 7th February 2008, 09:37
  4. Questions on timing
    By malc-c in forum mel PIC BASIC Pro
    Last Post: - 6th July 2006, 22:38
  5. HSEROUT buffering and timing - 16F88
    By picster in forum mel PIC BASIC Pro
    Last Post: - 5th March 2006, 17:52
