Anyone do a comparison of the ASM code generated by PBP??
Results 1 to 2 of 2
    Aug 2008
    Default Anyone do a comparison of the ASM code generated by PBP??
    Has oneone done a comparison between the final Assembly Code generated by PBP and other higher level languages say C for example? What make the fastest/most efficient code with out directly writing Assembly?
    Hard to tell, there's so many different compilers on the market, for each compiler command there's many different iteration, and then, there's many different way to do the same thing with different approach.
    However, you could do some benchmark test using something like...
    http://www.picbasic.co.uk/forum/show...33&postcount=9
    http://www.picbasic.co.uk/forum/show...9&postcount=13
  1. Making Program Code Space your playground...
  2. Changing Swordfish code to PBP
    By Ron Marcus in forum mel PIC BASIC Pro
    Last Post: - 29th April 2008, 02:28
  3. ASM Interrupt
    By mikep in forum mel PIC BASIC Pro
    Last Post: - 22nd November 2004, 21:06
  4. asm and pbp
    By pic beginner in forum mel PIC BASIC Pro
    Last Post: - 24th October 2004, 06:33
  5. ASM Interrupts with BASIC code?
    By Desterline in forum mel PIC BASIC Pro
    Last Post: - 31st October 2003, 20:21
