MN1307 sample code problem
Results 1 to 7 of 7
    Wink The Jackpot ...
    Rip apart a cheap Digital watch, steal the xtal, it should work with the DS1307. Even an xtal cut with the wrong Capacitance will work, though it keeps rubbish time (ie could be out by as much as 30 minutes in a year).
    Hi, Mel
    I have a LOT of xtals from Watches and timers ( most unmarked, ... of course ) ... most work on 3.27 ... MHz and some are really "exotics" ...
    Without any verifying possibilities it's a bit ... risky.
    3.27MHz... for a timekeeping source??? Surely you mean 32.768kHz... as long as it's a rock of that frequncy, the DS1307 will drive it... but accuracy will depend on how close it is to the 'ideal' 12.5pF that the DS1307 is designed for. But slowing down to 1/6th of normal speed is abnormal.
    If there was a large capacitance I bet it would stop completely. Let's see some schematic along with the "sample" code.
    Then we will be stopping guesses...
    Feb 2005
    GREECE
    Finally I find where was the problem
    The time was too slow beacause of the 5v power.It was the PICKIT2 which power my pcb (it has this function)...and when I use psu 5vdc all was ok.
    Does enyone has any idea why this happend???
    By the way thanks to all.
    Nikos
    Not enough amps from the PICKIT2??
  1. Making Program Code Space your playground...
  2. PIC18F4525 & LCD simple code problem
    By aggie007 in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2007, 17:29
  3. sample code for M25P32
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 9th January 2007, 03:37
  4. Servo Code problem
    By ALFRED in forum General
    Last Post: - 2nd March 2006, 04:30
  5. Sample code for ML2036 DDS
    By Tim in forum mel PIC BASIC Pro
    Last Post: - 7th February 2004, 03:08
