Calendar with PIC
Results 1 to 8 of 8
    Nov 2007
    Default Calendar with PIC
    Hello !
    Are somebody doing a " CALENDAR "( DAY, MOUNTH , YEAR ) with a PIC and LCD ?
    Thank you !
    There's some easy route to use if you want to.
    DS1307 RTC.
    http://www.melabs.com/resources/samp...ted/MN1307.txt
    Nov 2007
    Thank you very much for this link . Is usefully .
    Nov 2007
    Tell me please , has DS1307 only a single address code for all with this type ? In datasheet write :
    "The slave address byte contains the 7-bit DS1307 address, which is 1101000, followed by the direction bit (R/W),"
    If they have everyone a unique code , how can I know it ?
    Thanks !
    Don't worry, they all have the same... but you can't stack few of them on the same BUS like most I2C device who have those A0, A1, A2 lines on.
    Nov 2007
    ......but you can't stack few of them on the same BUS like most I2C device who have those A0, A1, A2 lines on.
    Only , becose is not necessary , yes ?
    Maybe, I don't know a situation where someone would need more than one RTC for a single project... possible, but probably not very common...
    You can add some other I2C device on the same I2C bus line though... just not another DS1307.
    Nov 2007
    .........You can add some other I2C device on the same I2C bus line though... just not another DS1307.
    Thank you very much , Steve , was , very impportant for me . I am reading much documents to understand this , and I was not sure yet . Now I am !
  1. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 10:00
  2. HSERIN & Interupts (aka controlling PIC programs from a remote PC)
    Last Post: - 17th June 2009, 14:46
  3. Digital clock thermometer Calendar PIC 16F628
    By valdirdf in forum Code Examples
    Last Post: - 31st May 2009, 01:52
  4. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 21:01
