serial data to LCD
Results 1 to 9 of 9
    Default serial data to LCD
    I am trying out an experiment where one pic16f84 sends out serial data, whilst another receives the data on an LCD. I can only get the LCD to display a 0 for the received data with my code. Any suggestions?
    transmitter
    INCLUDE "modedefs.bas"
    pause 1500
    START
    SEROUT PORTB.4,N2400,["1234"]
    PAUSE 50
    GOTO START
    receiver
    START
    M VAR BYTE
    SERIN PORTB.5,N2400,[M]
    lcdout $FE,1,#M
    LCDOUT $FE,$C0,"HELLO"
    PAUSE 300
    GOTO START
    Me thinks this will be of interest to you.
    http://www.picbasic.co.uk/forum/show...erial+backpack
    And changing
    START
    to
    START
    N = 1234
    SEROUT PORTB.4,N2400,[DEC N]
    might help
    Much simple... your SERIN line is wrong
    SERIN PorPin, Mode, Variable
    Using the square bracket says you want to wait a specific character..
    M VAR BYTE
    START
            SERIN PORTB.5,N2400,#M
            lcdout $FE,1,#M
            GOTO START
    if you send 1234... it will never fit in a BYTE variable.. max=255...
    Leave your transmitter code as is, but change 1234, to 123 for now to see what happen.
    PS: DEC modifier should not work for SEROUT, but for SEROUT2 .
    Thanks to everyone for the quick replies. I havent had chance to try the corrected code as yet, Ill post back when I get chance.
    Regards, John
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 04:47
  2. Nokia 3310 display text
    Last Post: - 26th August 2007, 03:39
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 02:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 14:50
  5. Sinus calculating !
    Last Post: - 28th November 2004, 23:56
