Hello Steve,
Thank you for your reply. I was not sure if i need those first two lines of code. I will apply your recommendations when i get home.
Using HSERIN, will it read data @ 38.4K assuming I DEFINE the correct BAUD and SPBRG?
Hello Steve,
Yes it will work. In fact you can change the baudrate on the fly if you need. If you do so, you'll need to change the SPBRG value.
Have a look at my PicMultiCalc, kinda handy stuff to calculate the SPBRG register
Download it here
Hello Steve,
Your advice was right on. Thank you for taking the time to respond. Wihile i am fairly new to this forum, I have learned a lot from you and others who contribute to this forum regularly. The PicMultiCalc tool was very useful i will make good use of it. Thanks again.![]()
