PIC 18F2220 from hell
Results 1 to 5 of 5
    Oct 2008
    Default PIC 18F2220 from hell
    Hello Folks,
    I am a noob when it comes to pic programin. so i am hoping to enlist the help from some of the experts of this forum. I have been having a heck of a time trying to compile a program using PBP 2.50B and MCS+ 3.0.05. I am trying to receive a serial 8N1 formated string @ 38.4K baud and output it at 9.6K baud. When i attempt tocompile i get the following errors:
    Error[108] c:pbp\pbppic18.lib 55 : Illeagal character (=)
    Error[124] c:pbp\pbppic18.lib 55 : Illeagal argument
    Error[108] c:pbp\pbppic18.lib 61 : Illeagal character (=)
    Error[124] c:pbp\pbppic18.lib 61 : Illeagal argument
    Error[108] c:pbp\pbppic18.lib 67 : Illeagal character (=)
    Error[124] c:pbp\pbppic18.lib 67 : Illeagal argument
    Error[108] c:pbp\pbppic18.lib 73 : Illeagal character (=)
    Error[124] c:pbp\pbppic18.lib 73 : Illeagal argument
    Error[108] c:pbp\pbppic18.lib 79 : Illeagal character (=)
    Error[124] c:pbp\pbppic18.lib 79 : Illeagal argument
    Error[108] c:pbp\pbppic18.lib 85 : Illeagal character (=)
    Error[124] c:pbp\pbppic18.lib 85 : Illeagal argument
    Error[108] c:pbp\pbppic18.lib 91 : Illeagal character (=)
    Error[124] c:pbp\pbppic18.lib 91 : Illeagal argument
    Error[108] c:pbp\pbppic18.lib 97 : Illeagal character (=)
    Error[124] c:pbp\pbppic18.lib 97 : Illeagal argument
    Error[108] c:pbp\pbppic18.lib 103 : Illeagal character (=)
    Error[124] c:pbp\pbppic18.lib 103 : Illeagal argument
    Error[108] c:pbp\pbppic18.lib 109 : Illeagal character (=)
    Error[124] c:pbp\pbppic18.lib 109 : Illeagal argument
    I would appreciate any help and comments.
    thank you
    here is the code:
    'Configuration Bits
    @ INCLUDE "P18F2220.INC"	 ;processor specific variable definitions
    @	LIST P=18F2220 ;directive to define processor and file format
     @      __CONFIG  _CONFIG1H, _IESO_OFF_1H & _FSCM_OFF_1H & _ECIO_OSC_1H
     @     __CONFIG  _CONFIG2L, _PWRT_OFF_2L & _BOR_ON_2L & _BORV_27_2L
     @     __CONFIG  _CONFIG2H, _WDT_OFF_2H & _WDTPS_32K_2H
     @     __CONFIG  _CONFIG3H, _MCLRE_ON_3H & _PBAD_DIG_3H & _CCP2MX_C1_3H
     @     __CONFIG  _CONFIG4L, _DEBUG_OFF_4L & _LVP_OFF_4L & _STVR_OFF_4L
    ' Define Oscilator speed
    DEFINE OSC = 20
    RCSTA = $FAB
    TXSTA = $FAC
    SPBRG = $FAF
    ' Disable Analog Ports
    ADCON1 = %00001111				' Set all ports for digital operation
    ' Setup Imterups
    INTCON = %01000000
    data_ready_to_send		var	bit
    UVSSIN				var	byte
    RCTOUT 				var	byte
    'Use any spare port bits for flow control.
    flow_control_input 		var 	PORTB.4
    flow_control_output 	var 	PORTB.5
    ' Configure the flow-control pins as one input and one output.
    TRISB.4 = 1
    TRISB.5 = 0
    TRISC.6 = 0         ' Setup pin RC6 to transmit
    TRISC.7 = 1
    ' Assert the flow-control output to enable receiving data on the serial port.
    flow_control_output = 0
    data_ready_to_send = 0
    loop:
    ' The main program loop.
    gosub receive_serial_data
    gosub transmit_serial_data
    GOTO loop
    receive_serial_data:
    if (PIR1.5 = 1) then
    ' Tell the remote computer to stop sending data .
    flow_control_output = 1
    Poke SPBRG, 32
    ' A byte has arrived at the serial port. Read it.
    SERIN2 PORTC.6,32774,[RCTOUT]
    data_ready_to_send = 1
    transmit_serial_data:
    if (data_ready_to_send = 1) then
    ' A byte is ready to send on the serial port.
    if (flow_control_input = 0) then
    ' The flow control input is asserted.
    Poke SPBRG, 129		' Set baud rate to 9600
     SEROUT2 PORTC.7\PORTC.4,84,[RCTOUT]
    ' Tell the remote computer it's OK to send more data.
    Hi and welcome here.
    There's a few things you have to change and delete. Let's see
    you don't need them, PBP do it for you, just delete those lines above
    DEFINE OSC = 20
    must be written like
    DEFINE OSC 20
    However, with this changed, you'll also need to change your OSC mode in your config fuses... and then you'll probably have a list of Error[118]... read the following thread (at least post 1 and 5)
    RCSTA = $FAB
    TXSTA = $FAC
    SPBRG = $FAF
    kinda hard to fit a 12bit result in a 8bit register Your program don't use the USART as it use a bit-banged solution (SERIN2/SEROUT2). If you want to use the USART, have a look in your manual for HSEROUT/HSERIN
    HTH
    Oct 2008
    Hello Steve,
    Thank you for your reply. I was not sure if i need those first two lines of code. I will apply your recommendations when i get home.
    Using HSERIN, will it read data @ 38.4K assuming I DEFINE the correct BAUD and SPBRG?
    Yes it will work. In fact you can change the baudrate on the fly if you need. If you do so, you'll need to change the SPBRG value.
    Have a look at my PicMultiCalc, kinda handy stuff to calculate the SPBRG register
    Download it here
    Oct 2008
    Hello Steve,
    Your advice was right on. Thank you for taking the time to respond. Wihile i am fairly new to this forum, I have learned a lot from you and others who contribute to this forum regularly. The PicMultiCalc tool was very useful i will make good use of it. Thanks again.
  1. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 11:00
  2. Replies: 67
    Last Post: - 8th December 2009, 03:27
  3. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 22:01
  4. Trouble with PIC 18F2220
    Last Post: - 19th August 2005, 14:17
