Dual 7-segment LED display counter
Results 1 to 5 of 5
    Apr 2008
    Default Dual 7-segment LED display counter
    hello,
    i'm a newbie in programming pic. I want make a dual 7-segment LED display counter and update it every 1 sec for show i the display 00 , 01 , 02 ecc. The code that i use found it in internet and is make for a 16F627 , i try this
    code with my 16F88 but the display update is very slow abuot every 2.5 sec
    and not every 1 sec. Why happened this?. I use a 4MHz external crystal like
    for the 16F627.
    please help me
    Thank
    Cnt VAR Byte ' Cnt is a byte variable
    Digit VAR Byte ' Digit is a byte variable
    Pattern VAR Byte ' Pattern is a byte variable
    Digit1 VAR PORTA.0 '' Digit 1 enable bit
    Digit2 VAR PORTA.1 ' Digit 2 enable bit
    First VAR Byte ' First is a byte variable
    Second VAR Byte ' Second is a byte variable
    i VAR Word ' i is a word variable
    CMCON = 7 ' RA0-RA3 are digital I/O
    TRISA = 0 ' Set PORTA as output
    TRISB = 0 ' Set all PORTB pins as outputs
    ' Enable TMR0 timer interrupts
    INTCON = %00100000 ' Enable TMR0 interrupts
    OPTION_REG = %00000111 ' Initialise the prescale
    TMR0 = 217 ' Load TMR0 register
    ON INTERRUPT GOTO ISR
    INTCON = %10100000 ' Enable Interrupts
    LOOP:
    Cnt = 0 ' Initialise Cnt to 0
    NXT:
    Digit = Cnt DIG 0 ' Get 10s digit
    GOSUB CONVERT ' Get segments to turn on
    First = Pattern ' Display 10s digit
    Digit = Cnt DIG 1 ' Get 1s digit
    Second = Pattern ' Display 1s digit
    FOR i = 1 to 1000
    Pause 1 ' Wait 1 second
    NEXT i
    Cnt = Cnt + 1 ' Increment Cnt
    IF Cnt > 99 THEN LOOP ' If Cnt > 99 then goto LOOP
    GOTO NXT ' Continue
    ' This is the Interrupt Service Routine (ISR). The program jumps to this
    ' routine whenever a timer interrupt is generated.
    DISABLE ' Disable further interrupts
    ISR:
    TMR0 = 217
    PORTB = First
    Digit2 = 0
    Digit1 = 1
    PAUSE 5
    Digit1 = 0
    PORTB = Second
    Digit2 = 1
    PAUSE 1
    INTCON.2 = 0 ' Re-enable TMR0 interrupts
    RESUME ' Return to main program
    ENABLE 'Enable interrupts
    CONVERT:
    LOOKUP Digit, [$01,$4f,$12,$06,$4c,$24,$60,$0f,$00,$0c], Pattern
    END ' End of program
    Read and understand this thread:http://www.picbasic.co.uk/forum/showthread.php?t=543
    The PIC you have chosen has a fail safe oscillator which works when the primary osc fails, like when it is not configured properly. Download the data sheets and study.
    Certainely not a bad idea to begin with a LED blink to see if it's only a crystal or config fuses setting problem.
    This PIC also have Analog to Digital converter, which needs to be disabled prior to use I/Os.
    Check the datasheet
    ANSEL=0
    Certainly not a bad idea to begin with a LED blink to see if it's only a crystal or config fuses setting problem.
    Check the datasheet
    ANSEL=0
    Yup! , he did say it was working, so I didn't look any farther, those are the problems you encounter when you copy / paste without any experience, GOOD IDEA to write a blinky.
    Apr 2008
    thank for help me!
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 07:14
  2. Single digit 7 Seg LED clock - PIC16F88
    By thirsty in forum Code Examples
    Last Post: - 17th July 2009, 09:42
  3. Weird compile issue 7 segment LED display
    By George in forum mel PIC BASIC Pro
    Last Post: - 21st June 2006, 03:12
  4. 7 segment digit problem (using Mister E's code)
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 9th September 2005, 21:25
  5. WRITE not working
    By servo260 in forum mel PIC BASIC Pro
    Last Post: - 29th December 2004, 03:02
