Dual 7-segment LED display counter
Results 1 to 5 of 5
    Read and understand this thread:http://www.picbasic.co.uk/forum/showthread.php?t=543
    The PIC you have chosen has a fail safe oscillator which works when the primary osc fails, like when it is not configured properly. Download the data sheets and study.
    Certainely not a bad idea to begin with a LED blink to see if it's only a crystal or config fuses setting problem.
    This PIC also have Analog to Digital converter, which needs to be disabled prior to use I/Os.
    Check the datasheet
    ANSEL=0
    Certainly not a bad idea to begin with a LED blink to see if it's only a crystal or config fuses setting problem.
    Check the datasheet
    ANSEL=0
    Yup! , he did say it was working, so I didn't look any farther, those are the problems you encounter when you copy / paste without any experience, GOOD IDEA to write a blinky.
    Apr 2008
    thank for help me!
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 07:14
  2. Single digit 7 Seg LED clock - PIC16F88
    By thirsty in forum Code Examples
    Last Post: - 17th July 2009, 09:42
  3. Weird compile issue 7 segment LED display
    By George in forum mel PIC BASIC Pro
    Last Post: - 21st June 2006, 03:12
  4. 7 segment digit problem (using Mister E's code)
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 9th September 2005, 21:25
  5. WRITE not working
    By servo260 in forum mel PIC BASIC Pro
    Last Post: - 29th December 2004, 03:02
