Elapsed Timer Demo in a PIC12F675
Results 1 to 17 of 17
    Quote Originally Posted by Charles Linquis View Post
    If you just want 5 days then -
    LED = ON
    For X = 1 to 7200 (60 minutes/hour X 24 hours/day X 5 days)
    PAUSE 60000 ; one minute
    Next X
    LED = OFF
    Hello,
    This is the code I've tested with 1 minute and works well, then put 7200 can achieve the 5 days with a good presicion?.
    [HTML]led1 var portb.0
    x var word
    HIGH LED1
    Top:
    For X = 1 to 1 '(60 minutes/hour X 24 hours/day X 5 days)
    Next X
    LOW LED1
    goto Top[/HTML]
    Thank you
    Sep 2005
    Campbell, CA
    The accuracy will be good if you are not using the internal oscillator. You need a crystal or external "can" oscillator for better than 2-3%. If you need really good accuracy, you can (temporarily) shorten the time interval to one day (or so) and compare it to a clock. For example: if you are 1.3% "fast" then increase the value after the PAUSE by 1.3% (60780). That should get you close enough.
    Charles Linquist
    Yup, that'll work.
    As long as it's the only thing the chip will be doing.
    But to answer the original question...
    > How to use the Elapsed Timer Demo in a PIC12F675 to maintain a on led by 5 days and then goes off
    CLEAR
    LED        VAR GPIO.0
    CMCON = 7
    ANSEL = 0
    Include "Elapsed.bas"
    Gosub ResetTime                ' Reset Time to  0d-00:00:00.00
    Gosub StartTimer               ' Start the Elapsed Timer
    HIGH LED                         ; Start with LED on
    Loop:
        if DaysChanged then
           DaysChanged = 0
           if Days = 5 then LOW LED  ; Turn off LED
    Goto Loop
    Or you can add a blinky LED to show that it's still counting...
    CLEAR
    LED        VAR GPIO.0
    StatLED    VAR GPIO.1
    CMCON = 7
    ANSEL = 0
    Loop:
        if DaysChanged then
           DaysChanged = 0
        IF SecondsChanged then
           SecondsChanged = 0
           Toggle StatLED
        ; Rest of the program goes here
    Goto Loop
    And you can still do other stuff at the same time.
    Yup, that'll work.
    CLEAR
    LED        VAR GPIO.0
    CMCON = 7
    ANSEL = 0
    Loop:
        if DaysChanged then
           DaysChanged = 0
    Goto Loop
    CLEAR
    LED        VAR GPIO.0
    StatLED    VAR GPIO.1
    CMCON = 7
    ANSEL = 0
    Loop:
        if DaysChanged then
           DaysChanged = 0
           SecondsChanged = 0
           Toggle StatLED
    Goto Loop
    Hey Darrel,
    In compiling I get this error because it will be.
    <a href="http://imageshack.us"><img src="http://img231.imageshack.us/img231/9863/errorcv5.jpg" border="0" alt="Image Hosted by ImageShack.us"/></a><br/><a href="http://g.imageshack.us/img231/errorcv5.jpg/1/"><img src="http://img231.imageshack.us/img231/errorcv5.jpg/1/w626.png" border="0"></a>
    open ASM_INTS.bas file, there you'll discover ..
    ' --- IF any of these three lines cause an error ??  Simply Comment them out to fix the problem ----
    wsave1      var byte    $A0     SYSTEM          ' location for W if in bank1
    wsave2      var byte    $120    SYSTEM          ' location for W if in bank2
    wsave3      var byte    $1A0    SYSTEM          ' location for W if in bank3
    Steve,
    Did not take into account the memory banks and compiles well, will do some tests and the results then I said.
    Thank you
    Steve,
    Perform tests on a 4-MHz external crystal setting 1 hour and was led off in 56:41 minutes of taking a delay time of 3:06 minutes. Is it normal that delay?.
    Thank you
    Steve,
    I've done some testing with minutes and works extremely well using a 4-MHz crystal, the oscillator's internal PIC12F675 is not very accurate there is any way to use it with good presicion?.
    Thank you
    Try adding ...
    DEFINE OSCCAL_1K 1
    when using the internal OSC.
  1. Elapsed Timer Demo
    Last Post: - 29th October 2012, 17:39
  2. Get elapsed time while TIMER samples pulses
    By RodSTAR in forum mel PIC BASIC Pro
    Last Post: - 27th March 2009, 16:27
  3. Totally Baffled with Elapsed Timer
    By CocaColaKid in forum mel PIC BASIC Pro
    Last Post: - 11th June 2008, 21:01
  4. SPWM and Elapsed Timer
    Last Post: - 8th May 2008, 03:16
  5. Darrel Taylor Elapsed Timer
    By rwskinner in forum mel PIC BASIC Pro
    Last Post: - 13th March 2008, 01:22
