10x4 matrix keyboard using only portB
Results 1 to 20 of 20
    May 2008
    Italy
    Default 10x4 matrix keyboard using only portB
    A 40 keys keyboard matrix using Pic16F84A @ 4 MHz.
    In this project I have used 40 keys but the system can be easily increased up to 60 keys (15 colums by 4 rows) with minor chance to the schematic and to the software (which is open source).
    The default layout of the keyboard can be changed modifying the ascii array accordingly.
    At startup characters are in upper case, they can be switched to lower case pressing key "Select". With the same key you can return to upper case.
    You will find in the attached file, the schematics,the source code (copy and paste it into PICBASIC PRO) all well documented. But if something will result unclear, please don't hesitate to post your doubts.
    Hope you will find the project useful.
    Al.
    Nice one !!!
    T.Jackson's Avatar
    T.Jackson Guest
    Thumbs up Nice
    Great documentation, and I particularly like the diode schema. As the old saying goes: "a real engineer is someone who can build something for 50 cents that any other dam fool can do for $2"
    Given the price of a diode these days Vs an integrated circuit-based equivalent solution, you my friend, place considerable emphasis on that old saying.
    Trent Jackson
    Hmm, the post is an excellent job on the matrix keyboard projects. I am just thinking to myself if it is worth to get in the trouble to built all these switch and wirings when a PC keybord has more keys, is very reliable and cost nothing!
    Of course you cannot embed it in your own shell, but that is another story.
    Just my thoughts, over a very nice project.
    T.Jackson's Avatar
    T.Jackson Guest
    I can see the schema being ideal for "custom membranes" ...
    It is a popular trend for even low-volume manufactures of electronic equipment to get membrane switches tailored to suit their own enclosures. They're DEAD cheap, and easy-to-install.
    Trent Jackson
    May 2008
    Italy
    Default 60 keys matrix keypad
    During the weekend I came to the conclusion that the project should be for 60 keys.
    The reason is that it is simpler to workout a smaller keypad from a larger one. (at least in this case)
    Just remove the unnecessary switches and diodes and you have the keypad already designed.
    The software has also been changed a bit in order to work around the fact that 16F84A could not accomodate an array of 61 bytes.
    So with this new solution I had it at work reducing also the code work space.
    Now the software works with all combination of keypad from 4x1 to 4x15 (Rows x Columns)
    I am attaching the file with the new version (Hardware & Software) sure that this will make life easier.
    Al.
    Hi Aratti,
    You're doing a good job here, but there are a couple issues I'd like to bring up.
    Don't shoot me.
    While scanning the first row, you set PortB =16 which puts RB4 high and RB5-7 low.
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=3010" /><!-- Name:  KeypadShort.JPG
Size:  18.2 KB -->
    If someone accidentally presses keys 1.1 and 2.1 at the same time, you have a dead short across RB4 and RB5. If you have a small power supply it won't last long because the PIC will reset as soon as the voltage drops low enough. But if you have a strong power supply, somethings likely to smoke.
    The problem can be overcome a couple ways, either by adding ~100 ohm resistors in series with each Row's pin. Or you can manipulate the TRIS register in your program instead of PORTB, and only allow 1 Row at a time to be in OUTPUT mode.
    And, it would be allot nicer to have the Outputs on the lower bits of PORTB, and the Inputs on RB4-7.
    Then you would be able to use the PortB Change interrupts to monitor the keypad, and you wouldn't have to keep scanning it all the time. You would then place all outputs to HIGH and when you get an interrupt, scan the rows 1 by 1 like normal.
    HTH,
    May 2008
    Italy
    Thank you Darel to have pointed out the problem, which I did noticed! I will modify the software to have only one output pin at the time on portB. The updated version will be posted tomorrow.
    Thank againg for your promp notification.
    Kind regards
    Al.
    May 2008
    Italy
    Here the updated version of software and hardware.
    It was necessary to pulldown the rows as well (4x5K resistors) in order to avoid floating inputs. It has been tested and it works.
    If you have downloaded the file from the previuos post please discard them and download the updated file from this post.
    Thank you again to Darel, and sorry for the inconvenience to all the members of the forum that have visited my post.
    Al.
    I like the concept, good job!
    Awwwwww! No RBC Interrupts. :(
    Such a nice little keypad scheme.
    If only it would ....
    May 2008
    Italy
    Darel be patient next release will be with "PORTB change interrupts". For that I need to build a new hardware prototype and it will take few days.
    I had to fix the bug you pointed out quickly, otherwise I could not sleep!
    Al.
    If I am looking at this correctly, the one drawback to this design is that you can't detect multiple keypresses in the sam row, right? In fact, holding two keys down in the same row could cause the wrong character code to be generated. Like holding down 1,1,and 1,8 gives you the code for 1,9, right? Not trying to nitpick. Just wanted to make sure I understood the advantages and disadvantages to the design.
    Tim Barr
    May 2008
    Italy
    Yes Tim, this is the price you have to pay for the extra keys!
    If the spacing of the keypad is done properly than chances to press two contiguous keys at the same time are really rare, but since number of keys available is no more an issue, you can dedicate one key to delate the possible unwanted input.
    Al.
    T.Jackson's Avatar
    T.Jackson Guest
    I believe that a protocol is possible to detect simultaneous key presses, BUT it would fail if both keys were pressed at exactly the same time (incredibly unlikely though). However, if it did occur -- the procedure would return the key that equated to the binary sum of the two keys held down.
    You would only need microseconds of a difference between the keys being pressed to come up with something that works.
    Trent Jackson
    Since we are talking about mechanical switch, that micro seconds might be to short time in my opinion. Debouncing is needed to read the switch correctly.
    T.Jackson's Avatar
    T.Jackson Guest
    Moreover ...
    I think if the columns were each given a unique, physical delay, say using an RC circuit -- you'd eliminate the possibility of two keys ever being processed as one.
    May 2008
    Italy
    Following T.Jackson suggestion, I removed the auto-repeat, now multiple keys have to close exactly at the same time to be decoded as the sum. This has been accomplished introducing a WHILE WEND which detect when you release the key.
    To follow the code.
    Al.
    '*  Name    : 60 Keys_Kpad.BAS                                  *
    '*  Author  : [a.ratti]                                         *
    '*  Notice  : Copyright (c) 2008                                *
    '*  Date    : 20/11/2008                                        *
    '*  Version : 2.2                                               *
    '*  Notes   :           Micro used: Pic 16F84a                  *
    '*          : The software will decode any matrix keypad 4 x n  *
    '*          :    where n is any columns number from 1 to 15     *
    TrisA = %00000000
    TRISB = %11111111
    Define OSC 4
    '--- EEprom ASCII code assignment to define keys response ---------
    '------------------- First Row --------------------
    Eeprom 1,[49,50,51,52,53,54,55,56,57,48,43,40,94,91,27]' (1,1)-(1,15)
    '--------------------Second Row --------------------
    Eeprom 16,[65,66,67,68,69,70,71,72,73,74,45,41,37,93,26]' (2,1)-(2,15)
    '--------------------- Third Row ------------------
    Eeprom 31,[75,76,77,78,79,80,81,82,83,84,47,64,36,60,62]' (3,1)-(3,15)
    '--------------------- Fourth Row ------------------
    Eeprom 46,[85,86,87,88,89,90,46,58,59,61,42,35,38,32,13]' (4,1)-(4,15)
    '--------------------------- Set variables and pins --------------------
    LED         VAR PortA.0     ' Heart beating led
    Buz         var PortA.1     ' got character acknowledgement
    Tx          var PortA.2     ' Serial out
    RTS         var portA.3     ' Ready to sent when low
    T9600       con 2           ' baud rate = 9600
    UCase       var byte
    KeyFlag     var byte
    KbOut       var Byte    [2] ' Buffer Array
    high Tx                     ' purge serial line (True Mode)
    High RTS                    ' disable RTS
    low Buz                     ' Bepper off
    KeyFlag = 0                 ' reset variable
    Ucase = 0                   ' set uppercase
    '-------------------------- Main program -------------------------------
     Loop:
     if KeyFlag>0 then           'If <> 0 then Tx ASCII character and Beep
     Low RTS                     'RTS flag enabled
     pause 20
     if KbOut[1]=26 then Loop    'Skip ascii code 26
     If KbOut[1]=>65 then        'Skip ascii code <> character
     KbOut[0] = KbOut[1] + UCase 'If UCase = 0 then UpperCase
     KbOut[0] = KbOut[1]
     Serout Tx,T9600,[KbOut[0]]  ' Tx ascii character
     '----- Choose one of the two serout comand DON'T SELECT BOTH !!! -----
     'Serout Tx,T9600,[#KbOut[0]]  ' Tx ascii code
     High RTS                   ' RTS flag disabled
     high buz                   ' Beep on
     pause 30                   ' time duration of the beep
     pause 150
     pause 50                   ' Heart beating frequency
     toggle Led                 ' Heart beating
     while KeyFlag>0            ' stop auto repeat
     KeyFlag = PortB
     KeyFlag=KeyFlag & %00001111
     wend
     '----------------------------- KeyScan routine ------------------------
     KeyFlag=0                  ' reset flag variable
     '------------------------ First Row - keys from 1 to 15  --------------
     TRISB = %11101111
     PortB =16
     If PortB>16 then           ' one key of the first row has been pressed
     KeyFlag=PortB
     KeyFlag=KeyFlag & %00001111  ' decode to which column the key belongs
     Gosub GetChar
     goto Loop
     '------------------------ Second Row - keys from 16 to 30 -------------
     TRISB = %11011111
     PortB =32
     If PortB>32 then           ' one key of the second row has been pressed
     KeyFlag=PortB
     KeyFlag = KeyFlag +15      ' decode to which column the key belongs
     gosub GetChar
     goto Loop
     '----------------------- Third Row - keys from 31 to 45 ---------------
     TRISB = %10111111
     PortB =64
     If PortB>64 then           ' one key of the third row has been pressed
     KeyFlag=PortB
     KeyFlag = KeyFlag +30      ' decode to which column the key belongs
     gosub GetChar
     goto Loop
     '------------------------ Fourth Row - keys from 46 to 60 -------------
     TRISB = %01111111
     PortB =128
     If PortB>128 then          ' one key of the fourth row has been pressed
     KeyFlag = PortB
     KeyFlag = KeyFlag +45      ' decode to which column the key belongs
     gosub GetChar
     goto Loop
     '------------------------ End of keyscan routine ----------------------
     '---------------- Select Uppercase or LowCase letters -----------------
     '------ (Ucase = 32 then lowerCase)  (UCase = 0 then UpperCase) -------
     GetChar: ' Read ASCII code from eeprom & set UCase or LCase
     Read KeyFlag, KbOut[1]
     If  KbOut[1]=26 then
     If UCase=0 then
     Ucase=32
     UCase=0
    I found this reference on another forum that was very interesting. I had never heard of Charlieplexing before but this is really cool. It not only applies to multiplexing outputs, but inputs as well. Since the guy that came up with this works at Maxim, there are even some Maxim parts that use charlieplexing to drive LEDs. It looks like aratti's design may be a variant of charlieplexing.
    Tim Barr
    Default Re: 10x4 matrix keyboard using only portB
    Just Brilliant
    You can't teach an old dog new tricks, but I'm always willing to try.
  1. PICs can do more if use others than delays instructions
    By hardcore in forum mel PIC BASIC Pro
    Last Post: - 24th February 2010, 20:52
  2. AT/PS2 Keybord - PIC Interface?
    By Kamikaze47 in forum Code Examples
    Last Post: - 9th August 2009, 17:10
  3. shifting problem
    By helmut in forum mel PIC BASIC Pro
    Last Post: - 31st August 2007, 07:11
  4. Output PIC module
    By freelancebee in forum mel PIC BASIC Pro
    Last Post: - 12th September 2005, 21:10
  5. Can anyone help a beginner in a struggle?
    By douglasjam in forum mel PIC BASIC
    Last Post: - 6th May 2005, 00:29
