Help with a draft of a robóvia rf
Results 1 to 40 of 40
    Default rufbot help
    hi
    bro i also tried to realise that rufbot and encountered the same problem
    please if you peopla can help me out with the code???????????
    thank u
    Aug 2008
    Default rufbot
    '* Name : RX.BAS *
    '* Notice : Copyright (c) 2008 [select VIEW...EDITOR OPTIONS] *
    '* : All Rights Reserved *
    '* Date : 18/11/2008 *
    '* Version : 1.0 *
    '* Notes : *
    include "modedefs.bas"
    @ DEVICE PIC16F84A 'iţlemci 16F628
    @ DEVICE PIC16F84A, WDT_On
    @ DEVICE PIC16F84A, PWRT_ON
    @ DEVICE PIC16F84A, PROTECT_OFF
    @ DEVICE PIC16F84A, XT_OSC
    PORTA=0
    TRISA=0
    PORTB=0
    TRISB=%00000010
    B0 var byte
    B1 var byte
    prestart: pause 400
    poke porta, 10 ' %00001010
    pause 200
    poke porta, 5 ' %00000101
    pause 200
    poke porta, 6 ' %00000110
    pause 200
    poke porta, 9 ' %00001001
    pause 200
    poke porta, 0 '
    pause 200
    start: serin PORTB.1,N9600,B0
    if B0 = 1 then forward
    if B0 = 2 then backward
    if B0 = 3 then left
    if B0 = 4 then right
    if B0 = 5 then nomove
    goto start
    forward: poke porta, 10
    goto start
    backward: poke porta, 5
    goto start
    right: poke porta, 6
    goto start
    left: poke porta, 9
    goto start
    nomove: poke porta, 0
    goto start
    '* Name : tx.BAS *
    '* Version : 1.0 *
    '* Notes : *
    trisb = %10000110 '134
    trisa = %10000101 '133
    portb = 6
    porta = 5
    low 1
    input 0
    input 2
    B0 var byte
    B1 var byte
    start: pot PORTB.0,50,B0
    pot PORTB.2,50,B1
    B0 = B0 * 5
    B1 = B1 * 5
    y: if B0 < 100 then GOSUB yf
    if B0 > 150 then GOSUB yb
    x: if B1 < 100 then GOSUB xr
    if B1 > 150 then GOSUB xl
    serout PORTB.1,n9600,[5]
    goto start
    yf: serout PORTB.1,n9600,[2]
    yb: serout PORTB.1,n9600,[1]
    xl: serout PORTB.1,n9600,[3]
    xr: serout PORTB.1,n9600,[4]
    cesar35 wrote;
    I'm using picbasic pro demo 250
    How do you get the PBP demo to compile programs longer than 31 lines & use include files?
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Aug 2008
    Wink
    Caro Bruce ME envia um email.
    Default help rufbot
    hi cesar first of all thanks a lot !!!!!!!!! brother
    now pls if u can provide me the stepper motor control program which i have to add with the main program
    then i can complete the code!!!!!!!!!!
    pls bro
    thank u
  1. Control NEXA 230V RF Switch
    By Fredrick in forum Code Examples
    Last Post: - 6th December 2009, 23:19
  2. Generic RF Receiver
    By dhouston in forum Code Examples
    Last Post: - 8th September 2009, 14:35
  3. Interfacing 16F88 to RF module
    By scomi85 in forum General
    Last Post: - 19th February 2009, 12:52
  4. RF Module
    By shahidali55 in forum General
    Last Post: - 9th March 2007, 09:00
  5. Interfacting RF Module
    By rastan in forum General
    Last Post: - 10th November 2004, 22:27
