Sorry, I did not quite understand the last post.
Are you saying that you got the Ruff Bot code to compile but it is not working?
If so post your code that compiles and I will assume you have the hardware exactly as shown on the web page?
code asm:
; PicBasic Pro Compiler 2.46, (c) 1998, 2005 microEngineering Labs, Inc. All Rights Reserved.
PM_USED EQU 1
INCLUDE "16F84A.INC"
RAM_START EQU 0000Ch
RAM_END EQU 0004Fh
RAM_BANKS EQU 00001h
BANK0_START EQU 0000Ch
BANK0_END EQU 0004Fh
EEPROM_START EQU 02100h
EEPROM_END EQU 0213Fh
R0 EQU RAM_START + 000h
R1 EQU RAM_START + 002h
R2 EQU RAM_START + 004h
R3 EQU RAM_START + 006h
R4 EQU RAM_START + 008h
R5 EQU RAM_START + 00Ah
R6 EQU RAM_START + 00Ch
R7 EQU RAM_START + 00Eh
R8 EQU RAM_START + 010h
FLAGS EQU RAM_START + 012h
GOP EQU RAM_START + 013h
RM1 EQU RAM_START + 014h
RM2 EQU RAM_START + 015h
RR1 EQU RAM_START + 016h
RR2 EQU RAM_START + 017h
_PORTL EQU PORTB
_PORTH EQU PORTA
_TRISL EQU TRISB
_TRISH EQU TRISA
INCLUDE "TX.MAC"
INCLUDE "PBPPIC14.LIB"
:020000000128D5
:02400E00FD3F74
:00000001FF
Post the Pic Bacic code, not the ASM it generates.
Dear mackrackit I'm very difficulties of the code intend to do that.
which commands. that missing to set the program's peak. " I thank you for everything.![]()
Post the Pic Basic code so we can see where you are at.
Also, for testing, connect the two PICs with wires and not radio.
The problem may be in the radio setup. Get it working hardwired first.
The Modolo tws433mhz and rws433mhz ok.
The clerical error codes has or has not![]()
How do you know the radios are working?
The only way anyone will be able to help you is if you post your code.
Until then have fun.
