Help with a draft of a robóvia rf
Results 1 to 40 of 40
    Aug 2008
    Default ruf-bot
    foto picbasic
    Everything is commented out " ' "
    At least it will compile nothing
    Aug 2008
    Red face ruf-bot
    Dear mackrackit I'm taking stick.
    At picbasic I'm very difficult to understand I'm using the English translator. Could make new code. For me.
    I will be grateful.
    I do not have time to write your code.
    But here is some old code you can look at to see how Pic Basic code is written.
    It basically is a test code for a POT.
    And read the threads I linked you to earlier.
    '16F877A
    DEFINE OSC 20
    'LCD SET UP
    DEFINE LCD_DREG     PORTB
    define LCD_DBIT     4
    DEFINE LCD_RSREG    PORTB
    DEFINE LCD_RSBIT    1
    DEFINE LCD_EREG     PORTB
    DEFINE LCD_EBIT     0
    DEFINE LCD_BITS     4
    DEFINE LCD_LINES    2
    DEFINE LCD_COMMANDUS    2000
    DEFINE LCD_DATAUS   50
    V1		VAR	BYTE
    LED	VAR	PORTD.2
    PAUSE 1000
    RUN:
    LCDOUT $FE,1,"POT"
    LCDOUT $FE,$C0,DEC V1
    PAUSE 100
    POT PORTC.7,127,V1
    IF V1 < 100 THEN
    GOTO LMP1
    GOTO LMP2
    GOTO RUN
    LMP1:
    HIGH LED
    GOTO RUN
    LMP2:
    LOW LED
    GOTO RUN
    Aug 2008
    Unhappy ruf-bot
    Dear mackrackit I am very grateful for pacincia.
    more just one more dica.Porque that picbasic Compiler without error. generates the hex normal. more pic does not send the data for the receiver. thank you again ..
    Sorry, I did not quite understand the last post.
    Are you saying that you got the Ruff Bot code to compile but it is not working?
    If so post your code that compiles and I will assume you have the hardware exactly as shown on the web page?
    Aug 2008
    Default ruf-bot
    code asm:
    ; PicBasic Pro Compiler 2.46, (c) 1998, 2005 microEngineering Labs, Inc. All Rights Reserved.
    PM_USED EQU 1
    INCLUDE "16F84A.INC"
    RAM_START EQU 0000Ch
    RAM_END EQU 0004Fh
    RAM_BANKS EQU 00001h
    BANK0_START EQU 0000Ch
    BANK0_END EQU 0004Fh
    EEPROM_START EQU 02100h
    EEPROM_END EQU 0213Fh
    R0 EQU RAM_START + 000h
    R1 EQU RAM_START + 002h
    R2 EQU RAM_START + 004h
    R3 EQU RAM_START + 006h
    R4 EQU RAM_START + 008h
    R5 EQU RAM_START + 00Ah
    R6 EQU RAM_START + 00Ch
    R7 EQU RAM_START + 00Eh
    R8 EQU RAM_START + 010h
    FLAGS EQU RAM_START + 012h
    GOP EQU RAM_START + 013h
    RM1 EQU RAM_START + 014h
    RM2 EQU RAM_START + 015h
    RR1 EQU RAM_START + 016h
    RR2 EQU RAM_START + 017h
    _PORTL EQU PORTB
    _PORTH EQU PORTA
    _TRISL EQU TRISB
    _TRISH EQU TRISA
    INCLUDE "TX.MAC"
    INCLUDE "PBPPIC14.LIB"
    :020000000128D5
    :02400E00FD3F74
    :00000001FF
  1. Control NEXA 230V RF Switch
    By Fredrick in forum Code Examples
    Last Post: - 7th December 2009, 00:19
  2. Generic RF Receiver
    By dhouston in forum Code Examples
    Last Post: - 8th September 2009, 15:35
  3. Interfacing 16F88 to RF module
    By scomi85 in forum General
    Last Post: - 19th February 2009, 13:52
  4. RF Module
    By shahidali55 in forum General
    Last Post: - 9th March 2007, 10:00
  5. Interfacting RF Module
    By rastan in forum General
    Last Post: - 10th November 2004, 23:27
