Help with a draft of a robóvia rf
Results 1 to 40 of 40
    The code is not complete. It is just an example on the flow of things.
    B0 for example is a variable bur is has not been declared
    B0 VAR BYTE
    And the use of SYMBOL needs to have a Variable declared before hand.
    So read trough the code from the web page and ONLY use it for a guide.
    Aug 2008
    Default ruf-bot
    B0 VAR BYTE
    You have to help me.
    In the service. The fightin '.
    Aug 2008
    Default ruf-bot
    Edit/Delete Message
    Is this the first time you have programmed a PIC?
    If so, then you need to start by making an LED blink.
    Aug 2008
    Default ruf-bot
    I did several projects in asm. I do not have much practice in picbasic. More
    do a very light flashes on facil.em asm.
    And my first project in picbasic.que I try fazer.mais not had much success.
    You could ajuda.impretada.ficarei me very grateful.
    Thank you
    Post
    start:
    0.50 pot, B0
    2.50 pot, B1
    PBP CAN'T understand that ...
    first good reason !!!
    Quote Originally Posted by cesar35 View Post
    Thank you
    OK, Lets get familiar with PBP.
    First read this thread
    It talks about setting the config bits in your code.
    Then read this
    Being that you have written in ASM I will assume you have MPASM installed.
    And I will also assume you are also using Micro Code Studio to write your PBP code in.
    In MCS go to view-Compiler Options and make sure the bos "use MPASM" is checked.
    Now the beginning of your code will look something this
    @__config _XT_OSC & _WDT_ON & _CP_OFF
    Aug 2008
    Default ruf-bot
    Dear mackrackit is the correct code to do
    Thank you
    'DEFINE OSC 4
    '@__config _XT_OSC & _WDT_ON & _CP_OFF
    'symbol trisb = 134
    'symbol trisa = 133
    'symbol portb = 6
    'symbol porta = 5
    'low 1
    'input 0
    'input 2
    'start:
    'pot 0,50,B0
    'pot 2,50,B1
    'B0 = B0 * 5
    'B1 = B1 * 5
    'y:
    'if B0 < 100 then yf
    'if B0 > 150 then yb
    'x:
    'if B1 < 100 then xr
    'if B1 > 150 then xl
    'serout 1,n9600,(5)
    'goto start
    'yf:
    'serout 1,n9600,(2)
    'goto start
    'yb:
    'serout 1,n9600,(1)
    'goto start
    'xl:
    'serout 1,n9600,(3)
    'goto start
    'xr:
    'serout 1,n9600,(4)
    'goto start
    'end
  1. Control NEXA 230V RF Switch
    By Fredrick in forum Code Examples
    Last Post: - 7th December 2009, 00:19
  2. Generic RF Receiver
    By dhouston in forum Code Examples
    Last Post: - 8th September 2009, 15:35
  3. Interfacing 16F88 to RF module
    By scomi85 in forum General
    Last Post: - 19th February 2009, 13:52
  4. RF Module
    By shahidali55 in forum General
    Last Post: - 9th March 2007, 10:00
  5. Interfacting RF Module
    By rastan in forum General
    Last Post: - 10th November 2004, 23:27
