Help with a draft of a robóvia rf
Results 1 to 40 of 40
    Aug 2008
    Default ruf-bot
    Post the code as you have it along with your configs and chip ID.
    I have a lot esperincia in picbasic could help me to compile the code.o brigado ..
    One last time...
    I can not compile what I do not see. And I do not even know what chip to compile for.
    Aug 2008
    Default ruf-bot
    One last time...
    Receiver Code:
    RX CODE:
    trisb symbol = 134
    Tris symbol = 133
    Portbou symbol = 6
    symbol port = 5
    poke Tris, 0
    poke port, 0
    low 0
    Input 1
    prestart:
    pause 400
    poke port, 10
    pause 200
    poke door, 5
    pause 200
    poke port, 6
    pause 200
    poke door, 9
    pause 200
    poke port, 0
    pause 200
    start:
    Serin 1, n9600, B0
    if B0 = 1 then forward
    if B0 = 2 then backward
    if B0 = 3 then left
    B0 = 4 if then right
    if B0 = 5 then nomove
    goto start
    Forward:
    poke port, 10
    goto start
    backward:
    poke door, 5
    goto start
    right:
    poke port, 6
    goto start
    left:
    poke door, 9
    goto start
    nomove:
    poke port, 0
    goto start
    Transmitter Code:
    TX CODE:
    trisb symbol = 134
    Tris symbol = 133
    Portbou symbol = 6
    symbol port = 5
    1 low
    Input 0
    Input 2
    start:
    0.50 pot, B0
    2.50 pot, B1
    B0 = B0 * 5
    B1 = B1 * 5
    y:
    if B0 <100 then YF
    if B0> 150 then yb
    x:
    if B1 <100 then xr
    if B1> 150 then xl
    serout 1, n9600, (5)
    goto start
    YF:
    serout 1, n9600, (2)
    goto start
    yb:
    serout 1, n9600, (1)
    goto start
    xl:
    serout 1, n9600, (3)
    goto start
    xr:
    serout 1, n9600, (4)
    goto start
    The pic16f84a
    I can not generate the hex to save the pic
    The code is not complete. It is just an example on the flow of things.
    B0 for example is a variable bur is has not been declared
    B0 VAR BYTE
    And the use of SYMBOL needs to have a Variable declared before hand.
    So read trough the code from the web page and ONLY use it for a guide.
    Aug 2008
    Default ruf-bot
    B0 VAR BYTE
    You have to help me.
    In the service. The fightin '.
    Aug 2008
    Default ruf-bot
    Edit/Delete Message
    Is this the first time you have programmed a PIC?
    If so, then you need to start by making an LED blink.
  1. Control NEXA 230V RF Switch
    By Fredrick in forum Code Examples
    Last Post: - 6th December 2009, 23:19
  2. Generic RF Receiver
    By dhouston in forum Code Examples
    Last Post: - 8th September 2009, 14:35
  3. Interfacing 16F88 to RF module
    By scomi85 in forum General
    Last Post: - 19th February 2009, 12:52
  4. RF Module
    By shahidali55 in forum General
    Last Post: - 9th March 2007, 09:00
  5. Interfacting RF Module
    By rastan in forum General
    Last Post: - 10th November 2004, 22:27
