I tried to display decimal value to LCD, it works.
How to display the value to LCD while sending the value with HSEROUT ?
Everytime I enable the HSEROUT command , the LCD do not display anything , not even the "HELLO" at the beginning
If the HSEROUT line is disabled, the LCD works again
Please take a look at my code below. Thanks
Code:'**************************************************************** '* Name : UNTITLED.BAS * '* Author : [select VIEW...EDITOR OPTIONS] * '* Notice : Copyright (c) 2008 [select VIEW...EDITOR OPTIONS] * '* : All Rights Reserved * '* Date : 14/11/2008 * '* Version : 1.0 * '* Notes : 16F88 20 Mhz * '* : PBP 2.50b MPASM * '**************************************************************** ASM __config _CONFIG1, _HS_OSC & _WDT_OFF & _LVP_OFF & _CP_ALL & _CCP1_RB3 __config _CONFIG2, _IESO_OFF & _FCMEN_OFF endasm define osc 20 define hser_rcsta 90h define hser_txsta 20h define hser_baud 9600 define hser_spbrg 25 DEFINE HSER_CLROERR 1 DEFINE LCD_DREG PORTB ' LCD data port DEFINE LCD_DBIT 0 ' LCD data starting bit DEFINE LCD_RSREG PORTA ' LCD register select port DEFINE LCD_RSBIT 3 ' LCD register select bit DEFINE LCD_EREG PORTA ' LCD enable port DEFINE LCD_EBIT 4 ' LCD enable bit DEFINE LCD_BITS 4 ' LCD data bus size DEFINE LCD_LINES 2 ' Number lines on LCD DEFINE LCD_COMMANDUS 2000 ' Command delay time in us DEFINE LCD_DATAUS 50 ' Data delay time in us CLEAR TRISA = %00000000 TRISB = %00000000 ANSEL = %00000000 value var byte lcdout $FE,1 start: LCDOUT $FE,1, " Hello" pause 50 for value = 1 to 255 LCDout $FE,$C0, dec value pause 50 ;hserout [0,dec value] ; IF THIS LINE IS ENABLED, LCD DOESN NOT DISPLAY ANYTHING pause 50 next value pause 5000 goto start
