If i remember correctly, lower bits of PORTB, ( PORTB.2 ) is also multiplexed with RX of the USART. And i don't remember if this PIC allow you to disable the RX part, so my guess would be...
    for value = 1 to 255
        RCSTA=0 ' Disable USART
        TRISB.2=0
        pause 25
        LCDout $FE,$C0, dec value
        pause 25
        RCSTA=$90 ' enable USART
        pause 25
        hserout [0,dec value]          ;  IF THIS LINE IS ENABLED, LCD DOESN NOT DISPLAY ANYTHING
        pause 50
        next value
sure enough there's few unecessary delay up here... not sure if this will help and work at all using the above... Maybe a good situation to use SEROUT/SEROUT2/DEBUG?
PS: Make sure of your DEFINES, must all be in UPPERCASE, unless, it may not work.
