10Bit ADCIN into 8-Bit WORD?
Results 1 to 4 of 4
    sinoteq's Avatar
    sinoteq Guest
    How about if a BYTE is 8 bits and a WORD is 16 bits. Would that make things easier? Now you are so lucky because a WORD is actually 16 bits and you are now less confused.
    Jul 2008
    Default Thanks!
    Immediate accurate information. You gotta love it. Thanks!
    sinoteq's Avatar
    sinoteq Guest
    Just make sure you use the LOW 10 bits of the Word variable, or you will get really funny results. There is a function in the PIC that makes the ADC result left or right justified but maybe you have found this already?
    Last Post: - 14th June 2016, 07:55
  2. Read/Write Problem
    Last Post: - 10th February 2010, 01:51
  3. Minimizing code space
    Last Post: - 30th May 2009, 07:25
  4. DS2760 Thermocouple Kit from Parallax in PicBasicPro
    By seanharmon in forum mel PIC BASIC Pro
    Last Post: - 8th July 2008, 23:19
  5. calculation problem
    Last Post: - 31st March 2006, 15:23
