PIC16F887 Config problem
Results 1 to 6 of 6
    Seems good, you have it left justified, but you read the highbyte.. that's not the problem here. So the question are
    1) what doesn't work?
    2) Expected to work on Internal or external OSC?
    3) Config fuses?
    PS: PBP 2.47 had some issue with that PIC about ADCIN and default clock. Problem solved in 2.50. Sur we had found a workaround in here somewhere...
    Cambridge UK
    When I run the debug I can see the registers with either FF or 0 depending where the pot is, the output on portc is the same value as these viewed registers. The program acts like a comparator been left enabled on the a2d pin.
    I am using the internal osc, I have tried to replicate one of the sample asm demo files to make sure I understand whats happening. I can also blink the LEDs without a problem.
    This is the code
    TRISC = %00000000
    loop:
    high portd.3
    pause 250
    high portd.2
    pause 250
    low portd.3
    pause 250
    low portd.2
    pause 250
    goto loop
    3) Config fuses?
    I think this may be the problem, if I set config fuses in the code I get duplicate label errors.
    I have not set any in the code or changed them in the inc files as the blinky code above works.
    Cambridge UK
    Mister e,
    Thanks very much for the info on that work around!!!! I had only searched the forum using pic16f887. This little test program works fine now. Its only taken me three days to sort this.
    Kind regards Nick
    I see you have it working... anywho, this method is very reliable if you want to play with another way.
    http://rentron.com/PICX2.htm
  1. A/D conversion with PIC18F67J50
    By ScaleRobotics in forum mel PIC BASIC Pro
    Last Post: - 8th May 2009, 02:48
  2. 18F4550 Bootloader enter via eeprom setting
    By bradb in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2008, 00:51
  3. Error 0X0000008E when connecting a 18F2550 USB HID
    By FranciscoMartin in forum USB
    Last Post: - 16th October 2008, 18:20
  4. PortE problems (PIC18F4455)
    By RubenR in forum mel PIC BASIC Pro
    Last Post: - 12th July 2006, 16:26
  5. Installation sequence
    By Demon in forum General
    Last Post: - 11th July 2006, 04:56
