Motor Stepper Example
Results 1 to 40 of 135
Threaded View
  1. #11
    Oct 2010
    Default Re: Motor Stepper Example
    I did it.
    '*  Author  : [Leonardo Bilalis]                                *
    '*  Notice  : Copyright (c) 2013                                *
    '*  Date    : 3/3/2013                                          *
    '*  Notes   : Stepper Motor                                     *
    @ DEVICE pic16F628A, intOSC_osc_noclkout, WDT_OFF, PWRT_OFF, BOD_OFF, MCLR_ON
    define osc 4
    Include "MODEDEFS.BAS"
    StepM var WORD     ; distance to move
    delay var word     ; time in ms between each step pulse
    i var word
    cmcon = 7
    PORTB = 0
    TRISB = %11110011
        but var PORTB.1            ; ASIGN THE PIC16F88 PORTB.2 AS A PUSH BUTTON
        Motor_Step VAR PORTB.2     ; ASIGN THE PIC16F88 PORTB.5 TO STEP PIN ON THE BIG EASY DRIVER
        DIRECTION VAR PORTB.3      ; ASIGN THE PIC16F88 PORT.4 TO DIR PIN ON THE BIG EASY DRIVER
    CW    con 0                    ;HERE WE GIVE A CONSTANT DIRECTION
    CCW   con 1                    ;HERE WE GIVE A CONSTANT DIRECTION
    BEGIN:
        LOW MOTOR_STEP ; WE CAN START BY MAKING LOW THE PORTB.4
        LOW DIRECTION ; WE CAN START BY MAKING LOW THE PORTB.5
        pAUSE 100 ; THEN WE GIVE 1 SECOND DELAY
        if but = 0 then            ; WE HAVE CONNECTED A PUSH BUTTON AT PORTB.2
            stepM = 3200            ; the number of the motor steps
            DELAY = 1           ; 1us between each step
            direction = CW         ; THE DIRECTION IS COUNTERWISE
            gosub Rotation
        goto begin
                                   ;THE FOLLOWING CODE SUPPOSE TO ROTATE THE SHAFT 1 STEP AT A TIME
    ROTATION:
        for i = 0 to (stepM - 1)
            gosub StepIt
            pauseUS delay
        next
    StepIt:
        motor_step = 1             ;generate a 1us wide pulse on the step pin
        pauseUS 1
        motor_step = 0
    	                       ;thanks to Henrik at Melabs forum.
    there are some problems though.
    i cannot sent one step pulse. i think i need to understand completely what is doing exactly through the Big easy driver.
Members who have read this thread : 5
