Motor Stepper Example
Results 1 to 40 of 135
    Italy
    Very clever... using a standard four coil stepper too... must find out more how they've achieved this.
    Italy
    A tutorial.
    By Douglas W. Jones
    THE UNIVERSITY OF IOWA
    Department of Computer Science
    Control of Stepping Motors
    http://www.cs.uiowa.edu/~jones/step/index.html
    Chapter 5:
    Microstepping of Stepping Motors
    http://www.cs.uiowa.edu/~jones/step/micro.html
    Luciano
    hansknec's Avatar
    hansknec Guest
    Default John
    You are trying to compare apples to oranges. Melanies code (or anybodys code) will only be able to get you to half step mode. That's the digital limit. Anybody who talks about microstepping is in reality using a stepper motor as a magnetic voice coil between steps. By varying the amount of current to one energized coil vs the other energized coil you can get the N-S poles of the rotor to line up anywhere between the two energized poles of the stator. This is analog circuitry which is often programmed using an 8-bit DAC and thats where the 256 number fits into the equation as a step size.
    magand's Avatar
    magand Guest
    I agree with hansknec.
    I apologize for my english but..... is the stepper driver that give to the motor the right sequence for microsteps.
    Trickle is to reproduce a sine wave using a current sensor on the motor phase and an AtoD converter (high number of bit = high number of microsteps).
    Usually these devices are inside dedicated drivers for microsteps.
    See ALLEGRO A3972 for 1/16 steps.
    regards
    andrea
    mslaney's Avatar
    mslaney Guest
    Default On and Off topic - Stepper Motor
    Get it?
    On and off.... :-)
    I'm having a problem...
    In it's simplest form, would the following be a brute force method of driving a bi-polar motor?
    (PIC 16F876)
    (defines, includes, and OSC set....)
    (tris a, b, and c set to 0)
    speed var word
    speed = 100 'just an arbitrary number - will eventually ramp up to max
    Spin:
    porta = %00000001
    pause speed
    porta = %00000100
    pause speed
    porta = %00000010
    pause speed
    porta = %00001000
    pause speed
    goto Spin
    When testing this with LEDs, this seems to work fine - the LEDs flash separately. However, when I attach the motor, nothing moves and the LED's flash in pairs.
    Pinout:
    porta.0 -> IRL510 -> LED/CoilA
    porta.1 -> IRL510 -> LED/CoilB
    porta.2 -> IRL510 -> LED/CoilC
    porta.3 -> IRL510 -> LED/CoilD
    If it matters, it's a work project that is behind schedule. A quick answer would be truly appreciated. I might even send you a check for $5 USD!!! :-)
    Is there a single IC like the UCN5804 but for bi-polar motors instead of unipolar?
    mslaney's Avatar
    mslaney Guest
    I guess what I 'm asking is....Do I need an H bridge or is it a function of the program?
