Motor Stepper Example - Page 3
Page 3 of 4 FirstFirst 1234 LastLast
Results 81 to 120 of 135
  1. #81
    Oct 2010
    Default Re: Motor Stepper Example
    Dear All,
    I dont Know if the following Code will MAKE the Motor To rotate.
    I would like to have your opinion.
    '*  Author  : [Leonardo Bilalis]                                *
    '*  Notice  : Copyright (c) 2013                                *
    '*  Date    : 3/3/2013                                          *
    '*  Notes   : Stepper Motor                                     *
    define osc 4
    Include "MODEDEFS.BAS"
    ANSEL = 0
    cmcon = 7
    TRISB = %1111011
        but var PORTB.2
        Motor_Step VAR PORTB.5 ; ASIGN THE PIC16F88 PORTB.5 TO STEP PIN ON THE BIG EASY DRIVER
        DIRECTION VAR PORTB.4  ; ASIGN THE PIC16F88 PORT.4 TO DIR PIN ON THE BIG EASY DRIVER
    BEGIN:
        LOW PORTB.4 ; WE CAN START BY MAKING LOW THE PORTB.4
        LOW PORTB.5 ; WE CAN START BY MAKING LOW THE PORTB.5
        PAUSE 1000 ; THEN WE GIVE 1 SECOND DELAY
        if but = 0 then ;WE HAVE CONNECTED A PUSH BUTTON AT PORTB.2
        goto rotation   ;IF WE PRESS IT THEN PROGRAM GOES TO ROTATION LABEL
        else            ;IF WE DO NOT PRESS IT THE PROGRAM RETURN TO BEGIN
        goto begin
      ;THE FOLLOWING CODE SUPPOSE TO ROTATE THE SHAFT 500 STEPS
      ;AS FROM THE CALCULATION THE SECOND HAS 1000 MILI SECONDS
      ;AND WE ONLY GIVE 2 MILI SECONDS DELAY, SO WE GET 500 STEPS.
      ;IN CASE WE WOULD LIKE TO HAVE ONE REVOLUTION, THE WE NEED
      ;TO GIVE EXACTLY 200 STEPS FOR THIS SPECIFIC MOTOR.
      ;IN THIS CASE WE NEED WE NEED 5 MILI SECONDS FOR A PAUSE OF HIGH AND LOW TOGETHER
    ROTATION:
        HIGH MOTOR_STEP ; HERE WE MAKE HIGH THE PORT.B WHICH IS CONNECTED TO step PIN ON THE BED
        PAUSE 1         ; DELAY ONE ms
        low MOTOR_STEP ; HERE WE MAKE low THE PORT.B WHICH IS CONNECTED TO step PIN ON THE BED
        GOTO BEGIN
    If you want to move the motor 500 steps you need to send 500 pulses. The frequency of the pulsetrain, ie the delay between pulses, controls the speed of the motor.
    The way you currently have it will move ONE step when the button is pressed, then it will start over, wait a second, move ONE step and so on - as long as the button is pressed.
    Finally, you should try to avoid using GOTO. As the program grows it tends to get really hard to follow when there's a lots of GOTOs all over. Instead make your program into subroutines and use GOSUB/RETURN.
      If But = 0 THEN
         GOSUB StepIt
    Goto Main
    StepIt:
      High Motor_Step
      Pause 1
      Low Motor_Step
      Pause 1
    Oct 2010
    Hi Henrik,
    thanks a lot for the advice.
    in order to send for example 200 pulses for one revolution, do i need to give for i = 200 to do the revolution label so many times as the i ?
  4. #84
    Yes, exactly!
    By the way, you seem to have your TRIS settings backwards, a set bit makes the pin an input, a cleared bit makes it an output.
    I haven't actually tested the following so please see it as an overall idea and not verified/working code:
    StepCount VAR WORD   ' Distance to move
    Delay VAR WORD          ' Time, in us, between each step-pulse
    i VAR WORD                 ' General purpose index/counter variable
    But VAR PortB.2
    Dir_Pin VAR PortB.4
    Step_Pin VAR PortB.5
    CW CON 0
    CCW CON 1
    CMCON = 7
    ANSEL = 0
    TRISB = %11001111   ' PortB4-5 outputs, rest are inputs.
      If But = 0 THEN
         StepCount = 200   ' Distance to move motor
         Delay = 2000        ' 2000us between each step
         Dir_Pin = CCW
         Gosub MoveMotor
    Goto Main
    MoveMotor:
      For i = 0 to (StepCount - 1)
        Gosub StepIt
        PauseUs Delay
      NEXT
    StepIt:
        Step_Pin = 1     ' Generate a 10us wide pulse on the step pin.
        PauseUs 10
        Step_Pin = 0
    Oct 2010
    ops my bad, you are right, TRISB must be otherway round.
    1 is inpupt and 0 is output.
    Apart from than i will compile the code and try to run it and test it tomorrow.
    will keep you updated. Let me print first the jig and fixture models so i can test the steps easier.
    thanks a lot.
  6. #86
    Oct 2010
    today i will try to build the models but will be ready for testing tomorrow. So please give me some time. thanks a lot.
  7. #87
    Oct 2010
    I have promised you to show you the jig and fixture Mode for the stepper Motor with 1.8* degree and 200 steps per revolution. I have ONLY built 2 parts from the assembly.
    For your reference checking the design on the Page 2.
    Please find attached pictures. The other 2 parts which is the Base and the columns will be ready tomorrow.
  8. #88
    Wow! I don't know much about 3d-printing but those pieces looks very profesional, nice work!
    What's the end application, is it only for experimenting/learning about step-motors or are these pieces going to be used for some specific application?
    Again, nice work indeed!
    /Henrik
  9. #89
    Oct 2010
    hi Henrik,
    thanks a lot. the models are from a Fortus 400mc system designed in a 3D CAD.
    The specific model is only a jig and fixture part. I designed it for helping me to learn how to move step by step the motor.
    But the end application will be based on the following.
    a small gear is attached on the small gear and will drive the big gear.
  10. #90
    Oct 2010
    "a small gear is attached on the small gear and will drive the big gear."
    sorry i used my smart phone to upload the previous.....i meant:
    a small gear is attached on the motor and will drive the big gear.
    The following picture is let's say version 2. little changes are made.
    So now i have only the columns to print and i will start testing the code.
  11. #91
    DEFINE OSC 4              ' not compulsory because default value ...
    StepCount VAR BYTE   ' Distance to move ' No need a word as Stepcount is < 255 !
    Delay VAR WORD          ' Time, in 2ms steps, between each step-pulse
    But VAR PortB.2
    Dir_Pin VAR PortB.4
    CW CON 0
    CCW CON 1
    CMCON = 7
    ANSEL = 0
    PORTB = 0                'Reset PortB to be sure
      If But = 0 THEN
         Delay = 2      ' 2ms between each step
         Dir_Pin = CCW
         Gosub MoveMotor
    Goto Main
    MoveMotor:
         PULSOUT Step_Pin, 1 'Gosub StepIt
        PauseUs Delay
      NEXT
    Here are some ideas ...
  12. #92
    Oct 2010
    Hi Acetronics,
    first of all, thanks a lot for the help as well.
    On the code you have reset the PORTB but you make it all 0, why do we reset the port?
    And then at the bottom you used the PULSEOUT command. What is the different between the following codes?
    MoveMotor:
        Gosub StepIt
        PauseUs Delay
      NEXT
    StepIt:
        PauseUs 10
        Step_Pin = 0
    and this one?
    MoveMotor:
        PauseUs Delay
      NEXT
    StepIt:
        PauseUs 10
        Step_Pin = 0
    Pulsout really toggles the output. So if it was at '1' it makes it '0' and then '1' again.
    Thats why Alain made sure port B was reset in the first place.
    Besides the exact timing of the Subroutine version of the program, they should perform the same.
    Many ways to do the same thing.
    Oct 2010
    nice, now i need to collect all my components and start playing with the software.
    It might take a bit longer because i do not have mounting screw terminals for the big easy driver.
    For your reference i have completed the model so everything is ready apart from the electronic connections.
  15. #95
    Alain,
    Thanks for editing my code. One small note though.
    You changed the delay from 2000 to 2 but I think you missed that I was using PauseUS. If you want 2ms between steps then it should be Delay=2000. Also, using Pulsout takes more program space than manually toggling the pin. But, as have been said, many ways to do the same thing.
    Astanapane,
    One last note, when you get to running the motor, make sure you start running it slow. If the speed of the pulses are two fast the motor won't be able to follow and will stall. No harm done but it might look like something is wrong. If you want to run at high speed you need to provide some acceleration/deceleration ramp instead of simply starting at the desired velocity.
    Keep up the nice work!
    Oct 2010
    Henrik,
    you can call me Leonardo.
    As from the time and the speed then i need to give longer time for a revolution. That will make the motor to run slower.
    Regarding the acceleration and deceleration i would like to do that YES. But i will do simple staff in the beggining.
    Let me get a soldering iron and some small components i need because here in Dubai there is nothing to find.
    I ordered all the components from US but didnt have in mind that i would need something to connect them. (all my electronic staff and my lab is back home in Hellas)
    thanks all of you for your help and time these days.
  17. #97
    Oct 2010
    i think i will change the microcontroller to PIC16f628A because i have spare.
    I only have at the moment one PIC16f88 and 3 PIC16F688.
    '*  Name    : STEPPER MOTOR.BAS                                                      *
    '*  Author  : GOT a HELP FROM HENRIK, Acetronics and Ioannis at (MELABS forum)       *
    '*          : All Rights Reserved                                                    *
    '*  Version : 1.0        *
    	   'we are going to use the PIC16F628A for controling BIG EASY DRIVER
    define osc 4
    StepCount var word      ; distance to move
    delay var word     ; time in ms between each step pulse
    i var word
        but var PORTB.1            ; ASIGN THE PIC16F628A PORTB.1 AS A PUSH BUTTON
        Motor_Step VAR PORTB.2     ; ASIGN THE PIC16F628A PORTB.2 TO STEP PIN ON THE BIG EASY DRIVER
        DIRECTION VAR PORTB.3      ; ASIGN THE PIC16F628A PORT.3 TO DIR PIN ON THE BIG EASY DRIVER
    CW    con 0                    ;HERE WE GIVE A CONSTANT DIRECTION
    CCW   con 1                    ;HERE WE GIVE A CONSTANT DIRECTION
    ANSEL = 0
    cmcon = 7
    PORTB = 0                      ;Reset PORT B (thanks to Acetronics from MELabs
    TRISB = %11110011              ;Make Portb.2 and Portb.3 O/P and rest I/P
    BEGIN:
        LOW Motor_Step ; WE CAN START BY MAKING LOW THE PORTB.2
        LOW DIRECTION ; WE CAN START BY MAKING LOW THE PORTB.3
        if but = 0 then            ; WE HAVE CONNECTED A PUSH BUTTON AT PORTB.1
            StepCount = 200        ; the number of the motor steps
            delay = 100            ; 100us between each step
            direction = CW         ; THE DIRECTION IS COUNTERWISE
            gosub Rotation
        goto begin
                                   ;THE FOLLOWING CODE SUPPOSE TO ROTATE THE SHAFT with a pulse of 200
    ROTATION:
        for i = 0 to (StepCount - 1)
            PULSEOUT Motor_Step, 1  ;gosub StepIt
            pauseUs delay
        next
    ;StepIt:
    ;    motor_step = 1             ;generate a 10us wide pulse on the step pin
    ;    pauseus 10
    ;    motor_step = 0
    ;    RETURN
    	                       ;thanks to Henrik at Melabs forum.
    Do i need to add the code marked in RED? I think i need to say some how to the motor_step to be 1 or 0
    I havent compiled the code yet because i'm at work but hopefully tonight i will do the first tests. So i might need your help.
  18. #98
    The red lines are for the version of the code using subroutine. You can delete them.
    I recommend using the port toggle instead of the Pulsout command though.
    Oct 2010
    thanks Ioanni.
    I'm building up the test board now. Once i go home after work i will try to make the first test with the code.
    lets see.
  20. #100
    Oct 2010
    I did it.
    @ DEVICE pic16F628A, intOSC_osc_noclkout, WDT_OFF, PWRT_OFF, BOD_OFF, MCLR_ON
    define osc 4
    StepM var WORD     ; distance to move
    i var word
    cmcon = 7
    PORTB = 0
    TRISB = %11110011
        but var PORTB.1            ; ASIGN THE PIC16F88 PORTB.2 AS A PUSH BUTTON
        Motor_Step VAR PORTB.2     ; ASIGN THE PIC16F88 PORTB.5 TO STEP PIN ON THE BIG EASY DRIVER
        DIRECTION VAR PORTB.3      ; ASIGN THE PIC16F88 PORT.4 TO DIR PIN ON THE BIG EASY DRIVER
    BEGIN:
        LOW MOTOR_STEP ; WE CAN START BY MAKING LOW THE PORTB.4
        LOW DIRECTION ; WE CAN START BY MAKING LOW THE PORTB.5
        pAUSE 100 ; THEN WE GIVE 1 SECOND DELAY
        if but = 0 then            ; WE HAVE CONNECTED A PUSH BUTTON AT PORTB.2
            stepM = 3200            ; the number of the motor steps
            DELAY = 1           ; 1us between each step
            gosub Rotation
        goto begin
                                   ;THE FOLLOWING CODE SUPPOSE TO ROTATE THE SHAFT 1 STEP AT A TIME
    ROTATION:
        for i = 0 to (stepM - 1)
            gosub StepIt
            pauseUS delay
        next
    StepIt:
        motor_step = 1             ;generate a 1us wide pulse on the step pin
        pauseUS 1
        motor_step = 0
    there are some problems though.
    i cannot sent one step pulse. i think i need to understand completely what is doing exactly through the Big easy driver.
  21. #101
    Hi, astanapane ...
    the problem is Pauseus 1 gives a ... 24µs pulse @ 4Mhz !!! ( see manual p.185 ) - I found 23µs @ scope !
    so, you might need to use ... assembler and absolutely avoid the Stepit sub ...!
    so, try this piece of code ...
    ROTATION:
            @ bsf PORTB,2 ; This gives ON pulse for 1µs ...
            @ bcf PORTB,2
    pauseUS delay
        next
  22. #102
    When you set Delay = 1 it tries to delay 1us between each pulse. As Alain wrote the shortest dealy you'll get with the PauseUs command (which is used by the code) is 24uS. So, the step pulse will be 24uS when using a 4MHz clock. Then there will be another 24us delay before the next pulse, add to that perhaps another 50us for the actual code executed between steps for a total of 100us. That equals a step frequency of 10kHz and there's no way the motor will be able to follow that without accelerating it up to speed.
    Leave the StepIt routine alone for now and change the Delay value to 2000 as I had in the original code I posted. That should step the motor at ~500Hz which it should be able to follow without accelerating.
    Oct 2010
    it didnt work it is my fault
    actually i'm tired really for today. Here is midnight. I will try tomorrow morning.
    thanks a lot for your time and interest. i really apreciated
    I will keep going testing the software.
  24. #104
    Oct 2010
    this morning i was playing with the code but i could only do some movements. Not microstepping though.
    I actually moved the shaft and pointer 16 times per revolution in an angle of 22.5 degrees with 200 steps per loop and then backwards to 3200 steps for one revolution.
    It does not looks like so many steps but is what from the code i had to do.
    First of all i used the MS1 MS2 and MS3 from the big easy driver to control the mictosteps.
    I couldnt really make it work but the point is that i turned the motor with half microsteps at 400 steps per revolution so 0.9 degrees each step.
    here is a small video that i could add any comments because i was at work.
    I promise you on my next viideo will explain the code and the model.
    thanks a lot.
    My next goal is to try and control microsteps. If anyone has the easy driver and any stepper motor, would be nice to share ideas.
    Not that i can do a lot but i can test and play with that. Now i have set up everything and it is easier for me.
  25. #105
    Hi, Astanapane
    I do not know if it can really Help you ...
    but Some years ago, I wrote THAT to play with a stepper motor ...
      * Project name:
          Demo for MkE Stepper card
      * Copyright:
          (c) Acetronics
      * Revision History:
          0.0
      * Status: Operationnal
      * Description:
          Demonstrate Stepper Commands.
          Maximum frequency limited by the 40µs dead time to ~ 2.5 rpm / s @ 400 steps/rev ...
          max clock Frequ is limited to 1100 x MS0 x MS1 Hz ...
          Add 2 volts to supply for 3967 internal drop ...
      * Test configuration:
          MCU:             Pic 16F877A
          Dev.Board:       EasyPic5
          Oscillator:      8 Mhz
          Ext. Modules:    Stepper card on PortC
                           LCD 2x16 on PortB - Legacy Wiring
          SW:              MkC Pro 4.15
      * NOTES:
        Command Connexions:
        PortA.0 : Accel rate - Analog
        PortA.1 : Decel rate - Analog
        PortA.2 : Unlock Motor
        Porta.3 : DO NOT USE
        Porta.4 : Emergency Stop @ Maximum rate
        Porta.5 : Stop @ PortA.1 deceleration rate
        Porta.6 : Increase Speed
        PortA.7 : Decrease Speed
        Pullups on PortA.2 to PortA.7
        PortD.5 : Invert Rotation
        Pullup  on PortD.5
        BUTTONS : GND when Pushed
        Display connexions:
        PortB   : STD 2x16 LCD Connexions
        Stepper card Connexions:
        PortC.0 : Enable
        PortC.1 : Step
        PortC.2 : Reset
        PortC.3 : Sleep
        PortC.4 : MS1
        PortC.5 : MS2
        PORTC.6 : Dir
        PortC.7 : Free
    //  Display :
        First line displays Motor Status
        Second line displays 1) Speed in % , 2) Acceleration Rate , 3) Deceleration Rate.
        ENJOY ...
      # include "built_in.h"
      //   Port Aliases
      # define  Accel rate   PortA.B0
      # define  Decel rate   PortA.B1
      # define  Run          PortA.B2
    // # define  Free        PortA.B3                                                // A/D reserved
      # define  Emergency_B  PortA.B4
      # define  Stop         PortA.B5
      # define  Increase     PortB.B6
      # define  Decrease     PortB.B7
      # define Enable        PortC.B0
      # define Step          PortC.B1
      # define Reset         PortC.B2
      # define Sleeep        PortC.B3
      # define MS1           PortC.B4
      # define MS2           PortC.B5
      # define Dir           PORTC.B6
      # define Alive         PortC.B7
    //  # define Enable        PortD.B0
    //  # define Step          PortD.B1
      # define Locked        PortD.B2
    //  # define Sleeep        PortD.B3
    //  # define MS1           PortD.B4
      # define Reverse       PortD.B5
      # define Accen         PortD.B6
      # define Decen         PortD.B7
    // Variables
      # define LoSpeedLimit 500 // (6µs)                                                // Deadband 40µs !!!
      # define HiSpeedLimit 20000
      # define Debounce 20
    // Lcd pinout settings *********************************************************
    sbit LCD_RS at RB4_bit;
    sbit LCD_EN at RB5_bit;
    sbit LCD_D7 at RB3_bit;
    sbit LCD_D6 at RB2_bit;
    sbit LCD_D5 at RB1_bit;
    sbit LCD_D4 at RB0_bit;
    // Pin direction ***************************************************************
    sbit LCD_RS_Direction at TRISB4_bit;
    sbit LCD_EN_Direction at TRISB5_bit;
    sbit LCD_D7_Direction at TRISB3_bit;
    sbit LCD_D6_Direction at TRISB2_bit;
    sbit LCD_D5_Direction at TRISB1_bit;
    sbit LCD_D4_Direction at TRISB0_bit;
    // Types ***********************************************************************
     bit oldstate, lock, Emergency, Rev ;
     unsigned int Acc, Dec, Speedo, OldSpeed ,Speed , Speeds;
     char text[7];
    // Messages ********************************************************************
     const char txt0[] = "                ";                                        // Blank Line
     const char txt1[] = "mikroElektronika";
     const char txt2[] = "EasyPIC5";
     const char txt3[] = "Stepper Demo";
     const char txt4[] = "Dir :";                                                  // First Row
     const char txt5[] = "Forward";
     const char txt6[] = "Reverse";
     const char txt7[] = "Speed :";                                                // Second Row
     const char txt8[] = "Acc :";
     const char txt9[] = "Dec :";
     const char txt10[] = "Emerg. Brake lock";                                       // Third Row
     const char txt11[] = "Locked";
     const char txt12[] = "Decelerating  ";
     const char txt13[] = "Accelerating";
     const char txt14[] = "Stopped";
     const char txt15[] = "Waiting Start";
     const char txt16[] = "Steady running";
     const char txt17[] = "Auto Decelerate";
     const char txt18[] = "Auto Accelerate";
     const char txt19[] = "Invert Rotation";
      void interrupt()
        if ( PIR1.B0 == 1)                                                          // Timer Period ended
           Step = ! Step;                                                           // Toggle Output
           Speedo = 65550 - Speed ;                                                 // 15 units for interrupt
           TMR1H = Hi(Speedo);
           TMR1L = Lo(Speedo);
           PIR1.B0 = 0;                                                             // Reset Flag
      void Text_To_LCD (unsigned Row, unsigned Col, const unsigned char *m)         // Write ROM Messages to LCD
          unsigned i = 0;
          Lcd_Out(Row, Col,"");
          while(m[i] != 0)
             Lcd_Chr_Cp(m[i]);
             i++;
      void Showstatus()                                                             // Show Motor Status
        Text_to_LCD ( 1,1,txt0 );
        Text_to_LCD ( 1,1,txt14 );
        delay_ms(500);
      void Showspeed()                                                              // Show actual parameters
        Lcd_Cmd(_LCD_RETURN_HOME );
        if ( Emergency == 1 )
           Text_to_LCD(1,1,txt0);
           Text_To_LCD(1,1,txt10);
           if (speed == HiSpeedLimit)
             Speeds = 0;
            Speeds = LoSpeedLimit*100/Speed;
           WordtoStr(Speeds, text);
           Lcd_Out(2,1,text);
           WordtoStr(Acc, text);
           Lcd_Out(2,6,text);
           WordtoStr(Dec, text);
           Lcd_Out(2,11,text);
        delay_ms(500);
      void Read_Accel()                                                             // Read Acceleration rate
       Acc = ADC_Read(0);
       if (Acc == 0)Acc = 1 ;                                                       // Floor value = 1
       Dec = ADC_Read(1);
       if (Dec == 0)Dec = 1 ;                                                       // Floor value = 1
    void Decell()        // Deceleration routine
        if( Speed <= (HiSpeedLimit - Dec))                                          // Care for Underspeed
         Speed += Dec ;
         delay_ms(10);
         Showspeed();
        else        // Motor will stop ...
          T1CON.B0 = 0 ;                                                            // Stop TMR1 if motor Stopped
          Step = 0;        // Low Step Output
          Speed = HiSpeedLimit;
          ShowSpeed();
          Showstatus();
    void Accell()        // Acceleration routine
        if( Acc < (Speed - LoSpeedLimit))
         Speed -= Acc ;
         Speed = LoSpeedLimit ;                                                     // Respect Speed Limit
         delay_ms(10);
         ShowSpeed();
    void main()
    // Registers Setup: ************************************************************
     /*ANSEL  = 0;                                    // Configure AN pins as digital I/O
      ANSELH = 0;
      C1ON_bit = 0;                                  // Disable comparators
      C2ON_bit = 0;*/
     CMCON = 7;        // Comparators OFF
     CVRCON = 0b00000000;                                                           // Vref OFF
     ADCON0 = 0b1100001;                                                            // Adc Config 10 Bits ch 0,1,2 Analog.
     ADCON1 = 0b1100100;
     T1CON = 0b00010000;                                                            // Config Timer 1 : prescaler 1/2, Osc off, - off
     CCP1CON = 0;        // "CCPM" Config ( Disable all )
     CCP2CON = 0;
     // Interrupts *****************************************************************
     INTCON = 0b11000000;                                                           // GIE and PIE Enabled
     PIE1   = 0b00000001;                                                           // CCP1 int Enabled
     PIR1   = 0;
     PIE2   = 0;
     PIR2   = 0;
     // Config Ports ***************************************************************
     PORTA = 0b11111111;                                                            // Input Control + pots
     PORTB = 0b11000000;                                                            // LCD Display
     PORTC = 0b00000000;                                                            // Stepper module control
     PORTD = 0b00100000;                                                            // Led status display
     PORTE = 0b00000000;
     TRISA = 0b11111111;
     TRISB = 0b11000000;
     TRISC = 0b00000000;
     TRISD = 0b01100000;
     TRISE = 0b00000000;                                                            // PortD Digital I/O
    // Variables Setup *************************************************************
     OldState    = 0;
     Lock        = 0;                                                               // Start in Locked Status
     Emergency   = 0;
     Speed       = HiSpeedLimit;                                                    // Reset to min Speed
     OldSpeed    = HiSpeedLimit;
     Rev         = 0;                                                               // Forward
     T1CON.B0    = 0;                                                               // TMR1 Stopped
     TMR1H       = 0;                                                               // Reset TMR1
     TMR1L       = 0;
     delay_ms(500);        // LCD Power up delay
    // LCD Initialization **********************************************************
     LCD_Init();
     Lcd_Cmd(_LCD_CLEAR);                                                           // Clear Lcd display:
     Lcd_Cmd(_LCD_CURSOR_OFF);                                                      // Cursor OFF
     Text_to_LCD ( 1,1,txt11 );                                                        // Show Starting Status
     // Output Setup ***************************************************************
     Enable =  0;        // PortC.B0
     Step   =  0;        // PortC.B1
     Reset  =  1;        // PortC.B2
     Sleeep =  1;        // PortC.B3
     MS1    =  0;        // PortC.B4
     MS2    =  0;        // PortC.B5
     Dir    =  0;        // PORTC.B6
      while(1)
     /*Alive = 1 ;        // Show it's alive
         delay_ms(300);
         Alive = 0;
         delay_ms(300);*/
     //    Read_Inputs();
      //void Read_Inputs()                                                            // Check Commands
     // Lock check***********************************************************
            if ( Lock == 1 )                                                        // if Unlocked
              // 1) Check Emergency Stop *******************************************
                 if (Button(&PORTA, 4, Debounce, 0))                                // Check Emergency Stop demand - Stops motor
                 oldstate = 1;                                                      // Update flag
                 Emergency = 1;
                 Dec = 1023;                                                        // Full Brake ( 64 Steps @ 10 ms)
                 while ( Speed < HiSpeedLimit )
                    Decell();
                 Step = 0;                                                          // Low Step Signal
                 Lock = 0;                                                          // Lock Motor
                 Locked = 0;                                                        // Show locked
                 Text_to_LCD ( 1,1,txt10 );                                         // Lcd_Out(1,1,"Emerg. Brake Lock");
                 Text_to_LCD ( 2,1,txt0 );
                 while (oldstate && Button(&PORTA, 4, Debounce, 0)){}               // Loop until button released
                 oldstate = 0;                                                      // Button released - Update flag - Restart authorized
                 goto bailout;
             // 2) Check for Direction when stopped ********************************
                if ( Speed == HiSpeedLimit )
                    while (Button(&PORTD, 5, Debounce, 0))                          // Check for Reverse Demand
                      oldstate = 1;
                      Text_to_LCD ( 1,1,txt19 );                                    // Show " Invert Rotation
                      delay_ms(500);
                    if (oldstate && Button(&PORTD, 5, Debounce, 1))                 // Reverse Button Released
                      T1CON.B0 = 0;                                                 // TMR1 Stopped to be sure
                      Alive = 1;
                      Rev = ~ Rev;                                                  // invert rotation
                      Dir = ~ Dir;
                      if ( Dir == 0 )
                          Text_to_LCD ( 1,1,txt5 );                                 // Lcd_Out(1,1,"Forward");
                          Text_to_LCD ( 1,1,txt6 );                                 // Lcd_Out(1,1,"Reverse");
                      delay_ms(500);
                      oldstate = 0;
                      Alive = 0;
    // Now we can do something else
             // 2) Check for Increase Speed IF Unlocked*****************************
                if  (Speed >= LoSpeedLimit)
                   PortD.B0 = 1;                                                    // show accel / Decel  enabled
                   while (Button(&PORTB, 6, Debounce, 0))                           // Check Increase demand - Increases motor until released
                     if ( Speed == HiSpeedLimit)                                    // If motor stopped
                          T1CON.B0 = 1;                                             // Restart TMR1 @ Slow Speed;
                          PortD.B6 = 1;                                             // Show Accel Led
                     Read_Accel();                                                  // Read Accel Value
                     //Acc = Acc << 6;                                              // Scale to 16 Bits
                     if( Speed > LoSpeedLimit )
                         Text_to_LCD ( 1,1,txt13 );                                 // Lcd_Out(1,1,"Accelerating");
                         Accell();
                         Text_to_LCD ( 1,1,txt16 );                                 // Lcd_Out(1,1,"Steady running");
                         delay_ms(200);
                   if (oldstate && Button(&PORTB, 6, Debounce, 1))                  // Accel Released
                     oldstate = 0;                                                  // Update flag
                     PortD.B6 = 0;                                                  // Clear Accel Led
                     delay_ms(200);
    // Decrease Speed Only if motor running !!!
                if ( Speed < HiSpeedLimit )
                    // 3) Check for Slow Stop demand *******************************
                    if (Button(&PORTA, 5, Debounce, 0))                                   // Check Stop demand - Stops motor slowly
                     Read_Accel();                                                  // Read Brake Value
                     //Dec = Dec << 6;                                              // Scale to 16 Bits
                     while( Speed < HiSpeedLimit )
                        Text_to_LCD ( 1,1,txt17 );                                  // Lcd_Out(2,1,"Auto Decelerate");
                        Decell();
                        delay_ms(200);
                     Text_to_LCD ( 1,1,txt14 );                                     // Lcd_Out(1,1,"Stopped         ");
    //                 Lock = 0;                                                    // Lock Motor once stopped - not compulsory
                    if (oldstate && Button(&PORTA, 5, Debounce, 1))                 // Stop Released
                  // Check for Direction *******************************************
                     delay_ms(500);
                     oldstate = 1;
                          OldState = 0;
                          OldSpeed = Speed;                                         // memorize current Speed
                          Read_Accel();
                          while( Speed < HiSpeedLimit )                             // Decelerate to stop
                              Text_to_LCD ( 1,1,txt17 );                            // Lcd_Out(1,1,"Auto Decelerate");
                              Decell();
                              delay_ms(200);
                          delay_ms(500);
                          Dir = ~ Dir;
                      if ( Dir == 0 )
                          delay_ms(500);
    //                      Locked = 1;                                             // Show Motor Unlocked
                          T1CON.B0  = 1;
                          Read_Accel();
                          while( Speed > OldSpeed )                                 // Accelerate to OldSpeed
                              Text_to_LCD ( 1,1,txt18 );                            // Lcd_Out(1,1,"Auto Accelerate");
                              Accell();
                              delay_ms(200);
                    // 4) Check for Decrease Speed *********************************
                    while (Button(&PORTB, 7, Debounce, 0))                          // Check Slow demand - Slows motor until released
                     if( Speed < HiSpeedLimit )                                     // is Motor Running ???
                        Text_to_LCD ( 1,1,txt12 );                                  // Lcd_Out(1,1,"Decelerating");
                        Decell();
                        delay_ms(200);
                        PortD.B7 = 1;
                       else                                                         // NO Motor Stopped
                        Text_to_LCD ( 1,1,txt14 );                                  // Lcd_Out(1,1,"Stopped");
                   if (oldstate && Button(&PORTB, 7, Debounce, 1))                  // Stop Released
                     if ( Speed != HiSpeedLimit)                                    // IF motor Stopped
                     delay_ms(200);
                     PortD.B7 = 0;
             bailout:
             // If Motor Locked ... Check for Start !!! ****************************
           if (Lock == 0)                                                           // if locked
                 if (Button(&PORTA, 2, Debounce, 0))                                // Check for Start Demand
                     Oldstate = 1;
                 if (oldstate && Button(&PORTA, 2, Debounce, 1))                    // Start Button Released - Motor unlocked
                   Speed = HiSpeedLimit;                                            // Slow Speed
                   Emergency = 0;                                                   // Disengage Emergency
                   Text_to_LCD ( 1,1,txt15 );                                       // Lcd_Out(1,1,"Waiting Start");
                   Lock = 1;                                                        // Unlock Motor
                   delay_ms(500);                                                   // Min Delay to read
      }                                                               // Process inputs
    I do agree it's not PicBasicPro ( MikroCPro ... )
    But may show you how to use the functions of your card ...
  26. #106
    Oct 2010
    Hehehe it very kind of you shearing the code.
    For many hours this morning i was playing with the BIG EASY DRIVER and only succeed to disable the power To the motor when not in use.
    I will checking the code but for me it is easier to control the easy driver.
    Keep you updated.
    Thanks a lot.
  27. #107
    Since you need 3200 pulses to move one revolution the driver is already set to its highest resolution, ie. 16 microsteps per fullstep, 200*16=3200. If you look at the schematic for the Big Easy Driver you'll see that MS1, MS2 and MS3 are all tied high thru 20k resistors and if you look at table 1 in the A4983 datasheet you'll see that that indeed means 16 microsteps. If you want to run at fullstep (200 steps/rev) then connect MS1-MS3 to GND.
    Oct 2010
    All thanks a lot.
    I made it. I did microsteps. It was easier than i thought.
    I will the Code in a bit.
  29. #109
    Oct 2010
    '*  Author  : [Leonardo Bilalis] GOT a HELP FROM HENRIK, Acetronics and Ioannis (MELABS forum)               *
    '*  Version : 1.0        *
           'we are going to use the PIC16F628a for controling BIG EASY DRIVER
    define osc 4
    i var word
    j var word
    cmcon = 7
    PORTB = 0
    PORTA = 0
    TRISB = %11110011
    TRISA = %00100011
        MS1 VAR PORTA.2            ;big easy driver microstep contro
        MS2 VAR PORTA.3            ;big easy driver microstep contro
        MS3 VAR PORTA.4            ;big easy driver microstep contro
        ENABLE_BED VAR PORTA.6     ;use this in order to cut current to the stepper motor
    BEGIN:
    HIGH MS1   ; MS1
    HIGH MS2   ; MS2
    HIGH MS3   ; MS3
    PAUSE 100
        IF BUT = 1 THEN
                ENABLE_BED = 1
            PAUSE 100
            for j = 0 to 16
                ENABLE_BED = 0
                stepM = 1          ; the number of the motor steps
                DELAY = 200           ; 100us between each step
                gosub Rotation
                PAUSE 200
            NEXT
            stepM = 200          ; the number of the motor steps
                gosub Rotation
                PAUSE 200
            stepM = 216          ; the number of the motor steps
                direction = cCW         ; THE DIRECTION IS COUNTERWISE
                gosub Rotation
                PAUSE 200
                DELAY = 50          ; 100us between each step
                direction = CCW         ; THE DIRECTION IS COUNTERWISE
                PAUSE 2000
               gosub Rotation
        goto BEGIN
    ROTATION:
        ;@ BSF PORTB,2
        ;@ BCF PORTB,2
            gosub StepIt
            pauseUS delay
        next
    ;ROTATION2:
       ;for i = 0 to stepM
        ;@ BSF PORTB,2
        ;@ BCF PORTB,2
            gosub StepIt
        ;    pauseUS delay
        ;next
       ; return
    StepIt:
        pauseUS 10
        motor_step = 0
  30. #110
    Oct 2010
    on the code above i havent changed the comments to pic16f628a.
    as the first time the code was written for the pic16f88 and the comments are only for this one.
    in any case i will upload an clean code tomorrow . SORRY ABOUT THAT.
  31. #111
    Congratulations Leonardo.
    Oct 2010
    Hi Robert,
    thanks a lot, i didnt do much, Henrik Acetronics and Ioannis helped me with the code a lot. Now it is easier to understand some things. But as i dont have much knowledge with programming language i'm moving slow and i know that i make you some times to lough with my stupid questions. Hehehehe. I hope with this small jig and fixtire model i will have some more practice.
    At the end i compiled the following code which is working just fine. Please have a look at the code and the video.
    '*  Author  : [Leonardo Bilalis] GOT a HELP FROM HENRIK, Acetronics and Ioannis      *
    '*  Version : 1.0        *
    define osc 4
    i var word
    j var word
    cmcon = 7
    PORTB = 0
    PORTA = 0
    TRISB = %11110011  ;we are setting the ports to inputs or outputs
    TRISA = %00100001  ;we are setting the ports to inputs or outputs
        led var porta.1            ; I just put a power led for the PIC16f628 at porta.1
        MS1 VAR PORTA.2            ;big easy driver microstep control
        MS2 VAR PORTA.3            ;big easy driver microstep control
        MS3 VAR PORTA.4            ;big easy driver microstep control
        ENABLE_BED VAR PORTA.6     ;use this in order to cut current to the stepper motor, it is very important when motor is not doing anything
        for j = 0 to 2             ; this is just a loop for flashing the LED
        pauseus 100
        low led ; power led for the pic in porta.1
        high led
        pause 1
        next
    BEGIN:
        LOW MOTOR_STEP ; WE CAN START BY MAKING LOW THE PORTB.2
        HIGH MS1   ; MS1, as from the datasheet when all are high 16 microsteps can be applied
        HIGH MS2   ; MS2, as from the datasheet when all are high 16 microsteps can be applied
        HIGH MS3   ; MS3, as from the datasheet when all are high 16 microsteps can be applied
        PAUSE 100
        IF BUT = 1 THEN            ;there is a button at PORTB.1, so if we do not push it
                ENABLE_BED = 1     ; the enable port on the big easy driver will remain high.
                                   ;as from the datasheed of the BED when high the output to the motor is dissabled.
            PAUSE 100
            for j = 0 to 15        ;loop
                ENABLE_BED = 0     ; will activate the PORTA.6 on the pic16f628A which is connected to enable pin on the Big Easy Driver
                pause 500          ; every step takes 500us
                DELAY = 500        ; 500us between each step
                gosub Rotation     ; check ROTATION routin
                next  j
                PAUSE 200
            for j = 0 to 199       ;loop of 200
            pause 1
                DELAY = 300        ; 300us between each step
                gosub Rotation
                PAUSE 5
            next j
            pause 200
            pause 1
                gosub Rotation
                PAUSE 5
            next j
            pause 200
            stepM = 800            ; the number of the motor steps
                DELAY = 100        ; 100us between each step
                gosub Rotation
                PAUSE 2000
                gosub Rotation
                PAUSE 200
            for j = 0 to 1599
            pause 1
                DELAY = 4000       ; 100us between each step
                gosub Rotation
                next j
                PAUSE 2000
            stepM = 1600           ; the number of the motor steps
                DELAY = 50         ; 500us between each step
                gosub Rotation
                PAUSE 2000
                gosub Rotation
                PAUSE 200
            for j = 1 to 15
            pause 1
                stepm = 1
                delay = 300
                direction = cw
                gosub rotation
                next j
            pause 200
        goto BEGIN
    ROTATION:
        ;@ BSF PORTB,2
        ;@ BCF PORTB,2
            gosub StepIt
            pauseUS delay
        next
    ;ROTATION2:
       ;for i = 0 to stepM
        ;@ BSF PORTB,2
        ;@ BCF PORTB,2
            gosub StepIt
        ;    pauseUS delay
        ;next
       ; return
    StepIt:
        pauseUS 10
        motor_step = 0
    	                       ;thanks to Henri
    I hope the video and the code will help you to understand why i designed and build this jig and fixture model
  33. #113
    Oct 2010
    here is an addition code which controllig the enable and sleep modes on the Big Easy Driver.
    Now everything is safe when the motor is not working.
    Now i need to play with the code for making some linear accelerations. Any help of how can i start that?
    '*  Version : 1.0        *
    '********************************* PIC16F628A *******************************************
    '                                                     ______________________________    *
    '                                                   / _____________________________/|   *
    '                                                  | PIN 1   : RA2/AN2/VREF       | |   *
    '                                                  | PIN 2   : RA3/AN3/CMP1       | |   *
    '                                                  | PIN 3   : RA4/TOCKI/CMP2     | |   *
    '          9   8   7   6   5   4   3   2   1       | PIN 4   : RA5/MCLR/VPP       | |   *
    '         ------------------------------------     | PIN 5   : VSS                | |   *
    '        | R   R   R   R   V   R   R   R   R *|    | PIN 6   : RB0/INT            | |   *
    '        | B   B   B   B   S   A   A   A   A  |    | PIN 7   : RB1/RX/DT          | |   *
    '        | 3   2   1   0   S   5   4   3   2  |    | PIN 8   : RB2/TX/CK          | |   *
    '        |                                    |    | PIN 9   : RB3/CCP1           | |   *
    '        |             PIC16F628A             |    |______________________________|/    *
    '        |                                    |     /_____________________________ /|   *
    '        | R   R   R   R   V   R   R   R   R  |    | PIN 10  : RB4/PGM            | |   *
    '        | B   B   B   B   D   A   A   A   A  |    | PIN 11  : RB5                | |   *
    '        | 4   5   6   7   D   7   6   0   1  |    | PIN 12  : RB6/T10SO/T1CKI/PGC| |   *
    '         ------------------------------------     | PIN 13  : RB7/T1OSI/PGC      | |   *
    '          10  11  12  13  14  15  16  17  18      | PIN 14  : VDD                | |   *
    '                                                  | PIN 15  : RA6/OSC2/CLOCKOUT  | |   *
    '                                                  | PIN 16  : RA7/OSC1/CLOCKIN   | |   *
    '                                                  | PIN 17  : RA0/AN0            | |   *
    '                                                  | PIN 18  : RA1/AN1            | |   *
    '                                                  |______________________________|/    *
    define osc 4
    i var word
    j var word
    cmcon = 7
    PORTB = 0
    PORTA = 0
    TRISB = %11100011  ;we are setting the ports to inputs or outputs
        led var porta.1            ; I just put a power led for the PIC16f628 at PORTA.1
        SLEEP_THE_BED VAR PORTB.4  ;WE DO MAKE THE BED GO LOW POWER MODE
    CCW         con 0              ;HERE WE GIVE A CONSTANT DIRECTION
    ACTIVATED   con 0              ;THIS IS AN ACTIVATION SIGNAL FROM PORTA.6 TO ENABLE PIN ON BED (IS RELATED TO ENABLE_BED VAR PORTA.6)
    DEACTIVATED con 1              ;THIS IS A DEACTIVATION SIGNAL FROM PORTA.6 TO ENABLE PIN ON BED (IS RELATED TO ENABLE_BED VAR PORTA.6)
    SLEEP_BED   CON 0              ;BIG EASY DRIVER IS GOING TO SLEEP
    WAKEUP      CON 1              ;BIG EASY DRIVER IS AWAKE
        pauseus 100
        high led
        pause 1
        next
    BEGIN:
        PAUSE 100
                ENABLE_BED = DEActivated     ; the enable port on the big easy driver will remain high.
                SLEEP_THE_BED = SLEEP_BED
            PAUSE 100
                ENABLE_BED = Activated       ; will activate the PORTA.6 on the pic16f628A which is connected to enable pin on the Big Easy Driver
                SLEEP_THE_BED = WAKEUP
                next  j
                PAUSE 200
            pause 1
                gosub Rotation
                PAUSE 5
            next j
            pause 200
            pause 1
                gosub Rotation
                PAUSE 5
            next j
            pause 200
                gosub Rotation
                PAUSE 2000
                gosub Rotation
                PAUSE 200
            for j = 0 to 1599
            pause 1
                DELAY = 5000       ; 100us between each step
                gosub Rotation
                next j
                PAUSE 2000
                gosub Rotation
                PAUSE 2000
                gosub Rotation
                PAUSE 200
            for j = 1 to 15
            pause 1
                stepm = 1
                delay = 300
                direction = Ccw
                gosub rotation
                next j
            pause 200
        goto BEGIN
    ROTATION:
        ;@ BSF PORTB,2
        ;@ BCF PORTB,2
            gosub StepIt
            pauseUS delay
        next
    ;ROTATION2:
       ;for i = 0 to stepM
        ;@ BSF PORTB,2
        ;@ BCF PORTB,2
            gosub StepIt
        ;    pauseUS delay
        ;next
       ; return
    StepIt:
        pauseUS 10
        motor_step = 0
  34. #114
    Oct 2010
    On the following code you can make the motor to run fast in the beggining and slow at the end.
    I did have high all the MS on the Big Easy driver so lets thing with 3200 microsteps per rev.
    So what i'm trying to do is to give form low speed to high from 0 degrees home possition to 45 degrees and then from 45 to end of travel high speed to low.
    Then back the same way to home possition.
    Is there any other way to make it?
    apart from that i would like to design a very small stupid cnc machine that i can give very basic shapes like square and cyrcle.
    Then i will write a data base with all the letters and i will try to call them each time i need them from a file or lookup.
    I know that i'm going to far now, i really dont know yet the basic of the PICBASIC. hehehhe.
    '*  Version : 1.0        *
    define osc 4
    i var word
    j var word
    a var word
    q var word
    w var word
     cmcon = 7
     PORTB = 0
     PORTA = 0
        pauseus 100
        high led
        pause 1
        next
    BEGIN:
        PAUSE 100
                SLEEP_THE_BED = SLEEP_BED    ;WILL DEACTIVATE THE PORTB.4 ON THE PIC16F628A WHICH IS CONNECTED TO SLEEP PIN ON THE BIG EASY DRIVER
            PAUSE 100
                SLEEP_THE_BED = WAKEUP       ; WILL ACTIVATE THE PORTB.4 ON THE PIC16F628A WHICH IS CONNECTED TO SLEEP PIN ON THE BIG EASY DRIVER
            stepM = 16                      ; the number of the motor steps
                DELAY = 300                  ; 500us between each step
                PAUSE 200
           a = 0
           for j = 0 to 400
            pause 1
             if a < 1200 THEN          ; here we secure the a not to be negative value
                DELAY = 1200 - a       ; we put delay and substract a which in our case is a = a+3
                a = a+3                ; we give a variable a for controlling the delay
                gosub Rotation
               next j
                a=0
                for q = 0 to 400
            pause 1
                if a < 1200 then
                a = a+3
                DELAY = a             ; between each step
                gosub Rotation
                next q
                a=0
                for j = 0 to 400
            pause 1
                gosub Rotation
               next j
                a=0
                for q = 0 to 400
            pause 1
                if a < 1200 then
                a = a+3
                gosub Rotation
                next q
                a=0
        goto BEGIN
    ROTATION:
            gosub StepIt
            pauseUS delay
        next
    StepIt:
        pauseUS 10
        motor_step = 0
    Oct 2010
    the jig and fixture model is ready.
  36. #116
    Nice job. Very detailed 3d Printing indeed!
    Oct 2010
    The Stratasys Fortus 400mc is one of the Best for 3D print. For design i used Catia V6. Programming the stepper motor used PICBASIC 2.50B
    And got all the help from you guys.
  38. #118
    Oct 2010
    a small video for you guys
  39. #119
    Wow that sucker moves so fast! Impressive.
    I was impressed too by the speed of the motor. Wow!
